So, I'm getting this error whenever I try to open a scripting shell:
- Code: Select all
Nov 11, 2018 at 11:29:52 AM
Interactive Shell Error Error in plugin execution InitializeMain:
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/IndigoPluginHost.app/Contents/Resources/PlugIns/plugin_base.py", line 9, in <module>
File "/usr/local/Cellar/python@2/2.7.15_1/Frameworks/Python.framework/Versions/2.7/lib/python2.7/logging/__init__.py", line 26, in <module>
File "/usr/local/Cellar/python@2/2.7.15_1/Frameworks/Python.framework/Versions/2.7/lib/python2.7/weakref.py", line 14, in <module>
ImportError: cannot import name _remove_dead_weakref
I use the shell quite often, but can't remember if I've even tried since I upgraded to 7.2.
Any thoughts on how to address this?
thanx!
