Plugins and their movement between folders in 7.2
Thu Oct 04, 2018 8:53 pm
susan.elizabeth offline
I am seeing plugins enable and disable in 7.2, but they do not seem to move between directories anymore.
Much to my dislike I had gotten used to myPlugin.indigoPlugin folders moving between Indigo's /Plugins/ and /Plugins (Disinclined)".
Suddenly, with 7.2, it doesn't seem to happen. I have plugins that are enabled and running but are in the (Disabled) folder. I have disabled plugins in the main Plugins folder.
I didn't see the note about this changing.... I'm new at finding this kind of information. If anyone knows, please say if this is a bug or a feature.
Susan Elizabeth
Thu Oct 04, 2018 8:55 pm
Re: Plugins and their movement between folders in 7.2
I suspect it is related to the "run in interactive shell' feature being introduced. How could some processes see the plugin enabled, but others see it as disabled if the O/S's location for the file needed to change?
Thu Oct 04, 2018 9:33 pm
OOPS. I figured this out. I told you I was new here.
I forgot to move to the "indigo 7.2" Application Support folder.
Everything works as expected. Sorry for the distraction.
Fri Oct 05, 2018 5:46 am
Do not worry about it at all. There are no silly questions here.
