Continual "status request failed" errors
Fri Aug 31, 2018 8:25 pm
chrisfromthelc offline
I have a device that every few minutes (it varies from 2 or 3 minutes to up to 20 minutes), posts a "status request failed" in the log;
Aug 31, 2018 at 6:19:20 PM
   Z-Wave Error                    send "Back Porch String Lights" status request failed
   Z-Wave                          received "Back Porch String Lights" status update is on
The device works absolutely fine, and as you can see, it receives back the status request. It's also the correct status.
Any ideas on what could be causing this?
Sat Sep 01, 2018 1:14 pm
MarcoGT offline
Re: Continual "status request failed" errors
I am having the same problem since 7.1 (or 7.1.1, do not remember exactly)
Sat Sep 01, 2018 1:18 pm
Re: Continual
Now that you mention it, it seems like it might've started with a recent update.
Mon Sep 03, 2018 1:30 pm
Can you turn on Indigo's debug logging checkbox (via the Interfaces->Z-Wave->Configure... menu item) and capture the problem happening, then copy/paste the results into a reply for me? I'd like to see what is occurring at a lower level.
