finding methods.
Mon Jul 30, 2018 10:02 am
finding methods.
I recall that in ~ version 7 there was a new method introduced that is getting called envy few seconds (to refresh / give the option to update valuesDict parameters etc) in menus.
I looked at the API section but can not find it .. anyone recalls that one ..
Mon Jul 30, 2018 10:35 am
Colorado4Wheeler offline
Re: finding methods.
I think you are referring to callback as outlined here/
Mon Jul 30, 2018 10:51 am
Added support for valuesDict['refreshCallbackMethod'] attribute which allows plugins to specify a UI refreshing callback method that is called approximately every second for updates. The callback method has the same signature as UI button actions and can return both a modified valuesDict and errorsDict for dynamic UI updating.
Mon Jul 30, 2018 12:30 pm
yes , but it does not solve the problem.
Filter methods get an empty valuesDict at creation of devices/ events.
if I add a "CLICKme" button at the top and just call a dummy method that returns valuesDict, THEN filters get the populated valuesDict.
** eg
            <Field     id="selectExistingDevice" type="menu" defaultValue="" visibleBindingId="newOrExistingDevice" visibleBindingValue="existing,delete">
                <Label>select devices in Event:</Label>
                <List class="self" filter="existing" method="filterDevicesEvent"  dynamicReload="true"/>
            </Field>
and then
    def filterDevicesEvent(self, filter, valuesDict, typeId, targetId):
        xList =[]
        indigo.server.log("filterDevicesEvent:  typeId: "+ unicode(typeId)+"  targetId:"+ unicode(targetId)+"  valuesDict:"+unicode(valuesDict))
        if len(valuesDict) == 0:
            indigo.server.log("filterDevicesEvent:  vd empty returning")
            return xList
if i add:
             <Field    id="startCheck"       type="checkbox"  defaultValue="true"  hidden ="yes">  </Field>
            <Field    id="start" type="button"  visibleBindingId="startCheck" visibleBindingValue="true"  >
                <Label>To populate the fields hit start once</Label><Title> CLICKme </Title> <CallbackMethod> CLICKme </CallbackMethod>
            </Field>
    def CLICKme(self, valuesDict, typeId, targetId):
        valuesDict["startCheck"] = False
        return valuesDict
populates everything .. but the user needs to press the button at least once... and then the button disappears...
BUT IT WOULD BE REALLY NICE IF FILTERS COULD GET A POPULATED VALUESDIC AT START !
Mon Jul 30, 2018 12:40 pm
If you have to have the user click a button to force the start of populating your valuesDict then I think you are wanting:
 getMenuActionConfigUiValues(self, menuId)
That's for the menu actions, it's different for actions, devices, etc. This lets you prepop the form values before the user gets the UI. Just create and return the valuesDict.
Mon Jul 30, 2018 4:04 pm
Ah, but that wasn't the question you asked. I answered the question that you asked... ;)
I think it would be very useful if you could tell us what you're trying to do rather than just throw out code with little context. A full description of the problem is always the best place to start.
Mon Jul 30, 2018 4:26 pm
I've always wanted to be able to update valuesDict from lists but pre-populating the UI before the user sees it has been a viable enough solution for me and then I just add a lot of conditions on the dynamic list fields so they don't error out when attempting to initially load (if I don't fix it via the get[insert_method_here]ConfigUiValues).
Mon Jul 30, 2018 7:52 pm
This does the trick for me for EVENTS menu:
    def getEventConfigUiValues(self,valuesDict, typeId, targetId):
        if targetId ==0:
            valuesDict["abc"] = initvalue
            self.someOther ="this is init"
            self.someOther ="this is after init"
        return super(Plugin, self).getEventConfigUiValues(valuesDict, typeId, targetId)
ps
sorry for my poor communications skills .. not my bright point
Anyway, always wanted to try that method "valuesDict['refreshCallbackMethod'] "
