Z-wave (missing or disabled):
Sat Dec 15, 2018 7:40 am
CliveS offline
Re: Z-wave (missing or disabled):
siclark wrote:
Cheers. I have a script that runs on schedule to re-enable devices so will get it to message me when it finds one. (if I can)
I also run the script and was hoping someone can help filter it further.
for dev in indigo.devices.iter("indigo.zwave"):
   if not dev.enabled:
      indigo.device.enable(dev.id, value=True)
I have a device directory of 'Z_Not_Used' where all devices are disabled, is their any way of filtering out those devices so they stay disabled sort of like
for dev in indigo.devices.iter("indigo.zwave") and not dev directory ( "Z_Not_Used"):
CliveS
Indigo 2021.1.0 : MacOS Catalina 10.15.1 : Mac mini Server (Mid 2011) : 2 GHz Core i7. : 8 GB. : 2 x 256GB Samsung EVO SSD
Sun Dec 16, 2018 2:42 pm
Roughly something like:
ignoreFolderId = indigo.devices.folders.getId("Z_Not_Used")
   if not dev.enabled and dev.folderId != ignoreFolderId:
Mon Dec 17, 2018 3:32 am
CliveS offline
Correction Matt, not roughly, ........... 100% perfect!!!
CliveS
Wed Dec 26, 2018 3:56 pm
RAID5 offline
Hi
I have some similar problems to that you have in this thread.
I have an Aeon Labs Z-Stick Series 2 (https://aeotec.freshdesk.com/helpdesk/a ... 6009584533), is that the same as Gen 2 mentioned here?
This summer I changed hardware from a Mac Mini Late 2009 to a Mac Mini 2014.
Before this I never experienced this problem.
After the hardware upgrade, the z-wave network suddenly dies without any explanation.
A reload of the interface solves the problem.
This autumn the problems have got more and more frequent, now almost every week.
Other changes might also be an upgrade to 7.1.1 this summer when I upgraded the hardware.
I tried to upgrade again now last week to 7.2.2
But the problem remains
Here are the last minute of the logfile if it can be any help
2018-12-25 00:04:03.758 Z-Wave received "Cinema - HVAC" mode is heat
2018-12-25 00:04:04.068 Z-Wave received "Cinema - HVAC" fan mode is always on
2018-12-25 00:04:04.378 Z-Wave received "Cinema - HVAC" temperature update to 24 °C
2018-12-25 00:04:04.693 Z-Wave received "Cinema - HVAC" heat setpoint is 18.0 °C
2018-12-25 00:04:05.006 Z-Wave received "Cinema - HVAC" cool setpoint is 23.0 °C
2018-12-25 00:04:07.188 Z-Wave received "073 - Cinema - HVAC" status update battery level 100%
2018-12-25 00:04:09.712 Z-Wave received "Cinema - HVAC" temperature update to 24 °C
2018-12-25 00:05:00.741 Schedule CPV1-Internet Connection Check
2018-12-25 00:05:01.859 Z-Wave sent "Tims Room Floor Heating" on
2018-12-25 00:05:09.760 Z-Wave Error rcvd packet checksum mismatch: 01 00
2018-12-25 00:05:09.760 Z-Wave Error calculated checksum FF, received 00 (sent NAK)
The reason I found this thread is because of error messages after reload
These devices are removed but still report missing 47,49, 50, 66, 79 how do I remove these?
43, 56 Are disabled by me becase they are broken and needs to be replaced, no need to change anything here.
53 "Kitchen Ceiling Light" and 54 "Master Bedroom Ceiling Light" always reports that they "needs re-sync", but they don't, I just turn on and off them from my Control page and they are normal.
Reloading interface "Z-Wave 2.0.119"
Stopping interface "Z-Wave 2.0.119" (pid 48157)
Z-Wave closed connection to Z-Wave 2.78 static controller
Stopped interface "Z-Wave 2.0.119"
Starting interface "Z-Wave 2.0.119" (pid 57475)
Started interface "Z-Wave 2.0.119"
Z-Wave Error rcvd unexpected bytes (sent ACK): 14 01 00 04 00 62 0E 32 02 21 64 00 00 02 0D 00 03 00 00 02 0D F5
Z-Wave connected to Z-Wave 2.78 static controller interface on /dev/cu.SLAB_USBtoUART (firmware 26.157)
Z-Wave found module included in controller with no matching device (missing or disabled): 001 - Indigo Z-Wave Interface
Z-Wave found module included in controller with no matching device (missing or disabled): 043 - Binary Sensor (routing)
Z-Wave found module included in controller with no matching device (missing or disabled): 047 - Binary Sensor (routing)
Z-Wave found module included in controller with no matching device (missing or disabled): 049 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 050 - Relay Power Switch
Z-Wave Error device "Kitchen Ceiling Light" should be re-synced using the "Define and Sync..." button in the device edit dialog (the internal device definition has been revised)
Z-Wave Error device "Master Bedroom Ceiling Light" should be re-synced using the "Define and Sync..." button in the device edit dialog (the internal device definition has been revised)
Z-Wave found module included in controller with no matching device (missing or disabled): 056 - Relay Power Switch
Z-Wave found module included in controller with no matching device (missing or disabled): 066 - Binary Sensor (routing)
Z-Wave found module included in controller with no matching device (missing or disabled): 079 - Motor Control Class B
Z-Wave found module included in controller with no matching device (missing or disabled): 093 - Relay Power Switch
RAID5 "A happy Swede addicted to automation"
Fri Dec 28, 2018 3:19 pm
This could be a malfunctioning Z-Stick or could be a USB communication problem. Try plugging it into different USB ports to see if it becomes more reliable.
The device communication being disabled by Indigo is because the Z-Stick is reporting bad/bogus information to Indigo about the modules. The next release of Indigo will try to better handle this bad information.
Use the Interfaces->Z-Wave->Remove Failed Modules from Controller menu item. If that doesn't work, then temporarily create a new Indigo device and select the that node ID (so 47) then have Indigo try to sync the device. That should fail, presuming the module doesn't really exist, but then the controller will flag the module as failed internally. Next re-try the menu item to remove the failed modules and the controller will hopefully succeed in removing them (internally).
Sun Jan 06, 2019 5:17 pm
Bildhauer1963 offline
Hello al,
using
"ignoreFolderId = indigo.devices.folders.getId("Z_Not_Used")
indigo.device.enable(dev.id, value=True)"
on a German Mac OS with Indigo 7.2 returns the following error code:
"Traceback (most recent call last):
File "/Users/smerckens/Desktop/ZWaveAktivieren.py", line 1, in <module>
ignoreFolderId = indigo.devices.folders.getId("unbenutzt")
NameError: name 'indigo' is not defined
What do I need to do?
Thanks in advance!
Sun Jan 06, 2019 8:11 pm
How are you running the script? It must be run from an Execute Script action (either an embedded script or a file) or from an interpreter launched via the Plugins->Open Scripting Shell menu item because it needs access to the indigo module. Running it directly from Python won't work.
Wed Jan 09, 2019 4:05 pm
Thanks, that was the solution. I ran it directly from Python!
Sun May 12, 2019 3:47 pm
Indigo 7.3 (and 7.3.1) are now available which has extensive new logic to try to avoid disabling Indigo communication with devices that are misreported by the Z-Wave interface.
Tue May 14, 2019 5:49 am
CliveS offline
Just had my first issue with 7.3.1, thankfully cleared up with the reset script I run.
I had just restarted Indigo after High Sierra had just done an upgrade.
2019-05-14 08:06:37.527   Application   Started interface "Z-Wave 2.0.124"
2019-05-14 08:06:38.159   Application   Started plugin "HomeKit Bridge 1.0.2"
2019-05-14 08:06:38.485   HomeKit Bridge   Attempting to start 'Doors'
2019-05-14 08:06:38.516   HomeKit Bridge   Attempting to start 'Cameras'
2019-05-14 08:06:38.673   Z-Wave   connected to Z-Wave 4.54 static controller interface on /dev/cu.usbmodemFD121 (firmware 1.01)
2019-05-14 08:06:38.682   Trigger   EvoHome Conservatory Temperature Change
2019-05-14 08:06:38.692   Action Collection   Conservatory Temperature is 18.5
2019-05-14 08:06:38.694   Action Collection   Conservatory Setpoint is 12.0
2019-05-14 08:06:38.800   Honeywell   [Tue May 14 08:06:38 2019] Processed plugin preferences.
2019-05-14 08:06:38.866   Z-Wave   found module included in controller with no matching device (missing or disabled): 033 - Relay Power Switch
2019-05-14 08:06:38.988   Z-Wave   found module included in controller with no matching device (missing or disabled): 122 - Notification Sensor
2019-05-14 08:06:39.034   HomeKit Bridge   HomeKit Bridge is running the latest version, no update needed
2019-05-14 08:06:39.100   Z-Wave   found module included in controller with no matching device (missing or disabled): 143 - Notification Sensor
2019-05-14 08:06:39.122   Z-Wave   found module included in controller with no matching device (missing or disabled): 146 - Notification Sensor
2019-05-14 08:06:39.180   Z-Wave   found module included in controller with no matching device (missing or disabled): 153 - Relay Power Switch
2019-05-14 08:06:39.372   Z-Wave   found module included in controller with no matching device (missing or disabled): 183 - Multilevel Sensor (routing)
2019-05-14 08:06:39.469   Z-Wave   found module included in controller with no matching device (missing or disabled): 202 - Relay Power Switch
2019-05-14 08:06:39.510   Z-Wave   found module included in controller with no matching device (missing or disabled): 210 - Notification Sensor
2019-05-14 08:06:39.550   Z-Wave   found module included in controller with no matching device (missing or disabled): 218 - Notification Sensor
2019-05-14 08:06:42.310   Application   Started plugin "Harmony Hub 7.2.3"
2019-05-14 08:06:42.311   Harmony Hub   Starting Harmony Hub
2019-05-14 08:06:42.314   Harmony Hub   Checking for updates...
2019-05-14 08:06:42.541   Alexa-Hue Bridge   Alexa-Hue Bridge checking network access by attempting to access 'www.google.com'
2019-05-14 08:06:42.586   Alexa-Hue Bridge   Alexa-Hue Bridge network access check to www.google.com successfully completed.
2019-05-14 08:06:42.856   Harmony Hub   No updates are available
2019-05-14 08:06:43.010   HomeKit Bridge   HomeKit Bridge is loaded and ready to use
2019-05-14 08:06:43.213   HomeKit Bridge   Server 'Doors' has successfully started, you can use your HomeKit apps or Siri for this accessory
2019-05-14 08:06:43.235   HomeKit Bridge   Server 'Cameras' has successfully started, you can use your HomeKit apps or Siri for this accessory
2019-05-14 08:06:44.600   Z-Wave Error   device "Bathroom Fibaro Motion Sensor" may be asleep. configuration changes will be set during the next wake interval.
2019-05-14 08:06:45.168   Application   Emails on POP server ocelot.mythic-beasts.com will be scanned every 10 minutes
2019-05-14 08:06:45.223   Trigger   Power Switch On When Indigo Starts
2019-05-14 08:06:45.254   Sent Hue Lights   "Hall Coat Cupboard Light" off at ramp rate 0.0 sec.
2019-05-14 08:06:45.434   Z-Wave   sent "Kitchen Extractor Fan Switch" on
2019-05-14 08:06:45.629   Z-Wave   sent "Garage Freezer Switch" on
2019-05-14 08:07:41.711   Z-Wave Error   send requestMeterLevel failed after 9 attempts
2019-05-14 08:07:41.712   Z-Wave Error   restarting serial connection in 5.0 seconds
2019-05-14 08:07:45.114   Interface Failure   lost connection with interface
2019-05-14 08:08:31.831   Z-Wave Error   send getVersion failed after 9 attempts
2019-05-14 08:08:31.831   Z-Wave Error   restarting serial connection in 5.0 seconds
2019-05-14 08:08:35.113   Interface Failure   lost connection with interface
2019-05-14 08:09:22.922   Z-Wave Error   send getVersion failed after 9 attempts
2019-05-14 08:09:22.922   Z-Wave Error   restarting serial connection in 5.0 seconds
2019-05-14 08:09:26.114   Interface Failure   lost connection with interface
2019-05-14 08:10:13.031   Z-Wave Error   send getVersion failed after 9 attempts
2019-05-14 08:10:13.031   Z-Wave Error   restarting serial connection in 5.0 seconds
2019-05-14 08:10:16.114   Interface Failure   lost connection with interface
2019-05-14 08:10:39.011   Z-Wave   connected to Z-Wave 4.54 static controller interface on /dev/cu.usbmodemFD121 (firmware 1.01)
2019-05-14 08:10:39.213   Z-Wave Error   module 028 included in controller does not match device "En Suite Floor Heating Thermostat" type (controller module type: zwRelayType/zwRelayType (4, 16, 1), indigo device type: zwThermostatType (4, 8, 6))
2019-05-14 08:10:39.218   Z-Wave   found module included in controller with no matching device (missing or disabled): 033 - Relay Power Switch
2019-05-14 08:10:39.224   Z-Wave Error   module 055 included in controller does not match device "Front Door Lock" type (controller module type: zwThermostatType/zwThermostatType (4, 8, 6), indigo device type: zwLockType (4, 64, 3))
2019-05-14 08:10:39.230   Z-Wave Error   module 073 included in controller does not match device "Kitchen Fibaro Motion" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2019-05-14 08:10:39.237   Z-Wave Error   module 085 included in controller does not match device "Garden Light Switch" type (controller module type: zwLockType/zwLockType (4, 64, 3), indigo device type: zwRelayType (4, 16, 1))
2019-05-14 08:10:39.281   Z-Wave Error   module 120 included in controller does not match device ".Bedroom 1 Window Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 7, 1), indigo device type: zwOnOffSensorType (4, 86, 104))
2019-05-14 08:10:39.291   Z-Wave   found module included in controller with no matching device (missing or disabled): 122 - Routing Slave
2019-05-14 08:10:39.314   Z-Wave Error   module 135 included in controller does not match device "Bedroom 1 Jane WallMote" type (controller module type: zwCustomType/zwCustomType (4, 7, 1), indigo device type: zwCustomType (4, 24, 1))
2019-05-14 08:10:39.343   Z-Wave Error   module 139 included in controller does not match device "Motorhome Power Switch" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 7, 1), indigo device type: zwRelayType (4, 16, 1))
2019-05-14 08:10:39.355   Z-Wave Error   module 141 included in controller does not match device ".Hall Coat Cupboard Door Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2019-05-14 08:10:39.364   Z-Wave   found module included in controller with no matching device (missing or disabled): 143 - Notification Sensor
2019-05-14 08:10:39.374   Z-Wave   found module included in controller with no matching device (missing or disabled): 146 - Notification Sensor
2019-05-14 08:10:39.379   Z-Wave Error   module 149 included in controller does not match device "Loft Repeater Dimmable Load" type (controller module type: zwOnOffSensorType/zwDimmerType (4, 7, 1), indigo device type: zwDimmerType (4, 17, 1))
2019-05-14 08:10:39.386   Z-Wave Error   module 150 included in controller does not match device "Bedroom 1 Ceiling Light" type (controller module type: zwOnOffSensorType/zwDimmerType (4, 7, 1), indigo device type: zwDimmerType (4, 17, 1))
2019-05-14 08:10:39.401   Z-Wave Error   module 152 included in controller does not match device "Kitchen Neo Motion" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 17, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2019-05-14 08:10:39.404   Z-Wave   found module included in controller with no matching device (missing or disabled): 153 - Dimmable Power Switch
2019-05-14 08:10:39.409   Z-Wave Error   module 155 included in controller does not match device ".Bathroom Door Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 17, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2019-05-14 08:10:39.425   Z-Wave Error   module 157 included in controller does not match device "Kitchen Spot Lights" type (controller module type: zwRelayType/zwDimmerType (4, 16, 1), indigo device type: zwDimmerType (4, 17, 1))
2019-05-14 08:10:39.431   Z-Wave Error   module 158 included in controller does not match device "Kitchen Undercupboard Lights" type (controller module type: zwOnOffSensorType/zwDimmerType (4, 7, 1), indigo device type: zwDimmerType (4, 17, 1))
2019-05-14 08:10:39.436   Z-Wave Error   module 164 included in controller does not match device "164 - Siren" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 7, 1), indigo device type: zwRelayType (4, 16, 5))
2019-05-14 08:10:39.443   Z-Wave Error   module 165 included in controller does not match device "Living Room Twigs" type (controller module type: zwRelayType/zwRelayType (4, 17, 1), indigo device type: zwRelayType (4, 16, 1))
2019-05-14 08:10:39.449   Z-Wave Error   module 170 included in controller does not match device "Living Room BT Modem Switch" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 1), indigo device type: zwRelayType (4, 16, 1))
2019-05-14 08:10:39.454   Z-Wave Error   module 171 included in controller does not match device "Garage Door Open Alarm" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 17, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2019-05-14 08:10:39.460   Z-Wave Error   module 172 included in controller does not match device "Bathroom Neo Motion Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 5), indigo device type: zwOnOffSensorType (4, 7, 1))
2019-05-14 08:10:39.465   Z-Wave Error   module 178 included in controller does not match device "Conservatory Fan And Light Keyfob" type (controller module type: zwRelayType/zwRelayType (4, 16, 1), indigo device type: zwCustomType (4, 24, 1))
2019-05-14 08:10:39.471   Z-Wave Error   module 180 included in controller does not match device "Garage Motion Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 33, 1))
2019-05-14 08:10:39.481   Z-Wave   found module included in controller with no matching device (missing or disabled): 183 - Notification Sensor
2019-05-14 08:10:39.487   Z-Wave Error   module 186 included in controller does not match device "Conservatory Fan" type (controller module type: zwCustomType/zwDimmerType (4, 24, 1), indigo device type: zwDimmerType (4, 17, 1))
2019-05-14 08:10:39.492   Z-Wave Error   module 187 included in controller does not match device "Garage Door Left DO NOT USE - SWITCH ONLY" type (controller module type: zwValueSensorType/zwValueSensorType (4, 33, 1), indigo device type: zwRelayType (4, 16, 1))
2019-05-14 08:10:39.498   Z-Wave Error   module 188 included in controller does not match device "Dining Room Light" type (controller module type: zwOnOffSensorType/zwDimmerType (4, 7, 1), indigo device type: zwDimmerType (4, 17, 1))
2019-05-14 08:10:39.503   Z-Wave Error   module 189 included in controller does not match device "Garage Door Open KeyFob" type (controller module type: zwValueSensorType/zwValueSensorType (4, 33, 1), indigo device type: zwCustomType (4, 24, 1))
2019-05-14 08:10:39.508   Z-Wave Error   module 190 included in controller does not match device "Dining Room Samsung TV Switch" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 1), indigo device type: zwRelayType (4, 16, 1))
2019-05-14 08:10:39.519   Z-Wave Error   module 193 included in controller does not match device "Server Room Mac Mini Fan Switch" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 1), indigo device type: zwRelayType (4, 16, 1))
2019-05-14 08:10:39.525   Z-Wave Error   module 196 included in controller does not match device "Hall Repeater Switch" type (controller module type: zwCustomType/zwCustomType (4, 24, 1), indigo device type: zwRelayType (4, 16, 1))
2019-05-14 08:10:39.529   Z-Wave   found module included in controller with no matching device (missing or disabled): 202 - Relay Power Switch
2019-05-14 08:10:39.544   Z-Wave Error   module 205 included in controller does not match device "205 - Motion Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2019-05-14 08:10:39.549   Z-Wave Error   module 206 included in controller does not match device "Water Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2019-05-14 08:10:39.552   Z-Wave   found module included in controller with no matching device (missing or disabled): 210 - Relay Power Switch
2019-05-14 08:10:39.558   Z-Wave Error   module 211 included in controller does not match device ".En Suite Window Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
2019-05-14 08:10:39.578   Z-Wave   found module included in controller with no matching device (missing or disabled): 218 - Notification Sensor
2019-05-14 08:10:39.600   Z-Wave Error   module 225 included in controller does not match device "Drive Strips Temperature" type (controller module type: zwValueSensorType/zwValueSensorType (4, 7, 1), indigo device type: zwValueSensorType (4, 33, 1))
2019-05-14 08:10:39.601   Z-Wave Error   controller reported unexpected or missing module information for some devices -- will reinitialize communication in 10 minutes
2019-05-14 08:10:48.342   Z-Wave Error   device "Bathroom Fibaro Motion Sensor" may be asleep. configuration changes will be set during the next wake interval.
2019-05-14 08:11:45.285   Trigger   EvoHome Conservatory Temperature Change
2019-05-14 08:11:45.294   Action Collection   Conservatory Temperature is 19.0
2019-05-14 08:11:45.296   Action Collection   Conservatory Setpoint is 12.0
2019-05-14 08:11:45.300   Trigger   EvoHome Dining Room Temperature Change
2019-05-14 08:11:45.308   Action Collection   Dining Room Temperature is 20.0
2019-05-14 08:11:45.310   Action Collection   Dining Room Setpoint is 12.0
2019-05-14 08:11:45.311   Action Collection
2019-05-14 08:12:44.634   Z-Wave   received "Motorhome Power Switch" energy total to 233.51 kWh
2019-05-14 08:15:52.874   Trigger   EvoHome Bedroom 2 Temperature Change
2019-05-14 08:15:52.881   Action Collection   Bedroom 2 Temperature is 17.5
2019-05-14 08:15:52.883   Action Collection   Bedroom 2 Setpoint is 11.0
2019-05-14 08:16:55.353   Domotics Pad Mobile Client   Process command: updateMobileDeviceStates
2019-05-14 08:16:55.381   Domotics Pad Mobile Client   Process command: updateMobileDeviceStates
2019-05-14 08:17:07.173   Z-Wave   received "136 - .Utility Room Window Sensor" status update battery level 100%
2019-05-14 08:17:42.509   Z-Wave   received "Motorhome Power Switch" energy total to 42.55 kWh
2019-05-14 08:17:44.344   Z-Wave   received "Motorhome Power Switch" energy total to 233.77 kWh
2019-05-14 08:17:57.695   Trigger   EvoHome Bathroom Temperature Change
2019-05-14 08:17:57.702   Action Collection   Bathroom Temperature is 18.5
2019-05-14 08:17:57.704   Action Collection   Bathroom Setpoint is 16.0
2019-05-14 08:19:16.943   Z-Wave   received "126 - .Living Room Left Window Sensor" status update battery level 100%
2019-05-14 08:20:39.604   Z-Wave   reinitializing communication with interface Z-Wave 4.54 static controller
2019-05-14 08:20:41.875   Z-Wave   connection reset requested
2019-05-14 08:20:42.902   Z-Wave   connected to Z-Wave 4.54 static controller interface on /dev/cu.usbmodemFD121 (firmware 1.01)
2019-05-14 08:20:43.110   Z-Wave   found module included in controller with no matching device (missing or disabled): 033 - Relay Power Switch
2019-05-14 08:20:43.198   Z-Wave   found module included in controller with no matching device (missing or disabled): 122 - Notification Sensor
2019-05-14 08:20:43.283   Z-Wave   found module included in controller with no matching device (missing or disabled): 143 - Notification Sensor
2019-05-14 08:20:43.296   Z-Wave   found module included in controller with no matching device (missing or disabled): 146 - Notification Sensor
2019-05-14 08:20:43.333   Z-Wave   found module included in controller with no matching device (missing or disabled): 153 - Relay Power Switch
2019-05-14 08:20:43.430   Z-Wave   found module included in controller with no matching device (missing or disabled): 183 - Multilevel Sensor (routing)
2019-05-14 08:20:43.494   Z-Wave   found module included in controller with no matching device (missing or disabled): 202 - Relay Power Switch
2019-05-14 08:20:43.527   Z-Wave   found module included in controller with no matching device (missing or disabled): 210 - Notification Sensor
2019-05-14 08:20:43.561   Z-Wave   found module included in controller with no matching device (missing or disabled): 218 - Notification Sensor
2019-05-14 08:21:47.321   Z-Wave   received "137 - .Bedroom 3 Window Sensor" status update battery level 59%
2019-05-14 08:22:42.471   Z-Wave   received "Motorhome Power Switch" energy total to 42.55 kWh
2019-05-14 08:24:17.264   Z-Wave   received "225 - Drive Strips Temperature" status update battery level 100%
2019-05-14 08:24:17.266   Z-Wave   received "225 - Drive Strips Temperature" status update battery level 100%
2019-05-14 08:24:17.267   Z-Wave   received "225 - Drive Strips Temperature" status update battery level 100%
2019-05-14 08:24:17.269   Z-Wave   received "225 - Drive Strips Temperature" status update battery level 100%
2019-05-14 08:24:17.377   Z-Wave   received "225 - Drive Strips Temperature" status update battery level 100%
2019-05-14 08:24:17.628   Z-Wave   received "225 - Drive Strips Temperature" status update battery level 100%
2019-05-14 08:24:17.987   Z-Wave   received "225 - Drive Strips Temperature" status update battery level 100%
2019-05-14 08:25:39.993   Z-Wave   received "En Suite Floor Heating Thermostat" temperature update to 19.5 °C
CliveS
Tue May 14, 2019 8:43 am
Some questions on what you saw:
Did the Indigo devices have their communication disabled (it doesn't look like they did from what I can tell)?
Does the Event Log above include your script running?
What does your reset script do?
Tue May 14, 2019 11:27 am
CliveS offline
Looking at the log now, perhaps not as there is no log output from the script which only runs when a device is disabled.
2019-05-14 08:17:42.509 Z-Wave received "Motorhome Power Switch" energy total to 42.55 kWh <<??? weird
No it runs every 5 minutes, I used to trigger it from "Interface Connection Failure" but changed to 5 minute schedule.
         indigo.server.log("Enabled " + dev.name + " after trigger on Interface Error")
CliveS
Tue May 14, 2019 2:51 pm
I think your script didn't have to do anything and Indigo eventually recovered (because of the logic we added to 7.3) stable communication with the Z-Stick. Your Z-Stick definitely went out to lunch for a while there – it was not responding and it gave Indigo bogus information on the included nodes.
Tue May 14, 2019 3:03 pm
CliveS offline
Yes, you can't sort out the hardware but the new 7.3.1 software seems to fix it.
I will keep the script but hopefully it now will not be required... :)
CliveS
