lanbrown wrote:Just found that the Wunderground plugin does not update automatically
lanbrown wrote:I meant it was not updating the weather from Wunderground. It just sat there and showed the last time was when the plugin was reset. The first time the last update was around 4am. I performed a reload of the plugin in the evening and I checked it an hour later and the last update was at the reload of the plugin. That is what I meant by the plugin not updating.
jalves wrote:I can also confirm that Insteon devices continue to work just fine with 10.13.6
jay (support) wrote:jalves wrote:I can also confirm that Insteon devices continue to work just fine with 10.13.6
Did you have to apply the workaround before you upgraded to 10.13.6 to make the PowerLinc work correctly?
jalves wrote:jay (support) wrote:jalves wrote:I can also confirm that Insteon devices continue to work just fine with 10.13.6
No it didn't. IIRC I didn't need that work around when I set up my new iMac a few months back after my mini died.
