python requests certificate error
Fri Feb 02, 2018 9:12 pm
when I run a python script in terminal on my mac min osx 10.13.3 its works fine when in on 10.11.3 it throws the following error:
SLError: [SSL: UNKNOWN_PROTOCOL] unknown protocol (_ssl.c:590)
import requests
requests.packages.urllib3.disable_warnings(requests.packages.urllib3.exceptions.InsecureRequestWarning)
unifiControllerSession  = requests.Session()
ret                     = unifiControllerSession.post(login_url, data =loginData, verify=False)
there is some discussion on the web on ld OSX ssl version .. when I do
openssl version i get:
OpenSSL 0.9.8zh 14 Jan 2016
on the old mac pro
is it easy to fix? anyone done this?
Fri Feb 02, 2018 9:30 pm
Re: python requests certificate error
I am trying to replace curl with requests in python.
It is a general question .. with curl everything works .. but just wanted to convert to true python ..
The server I am trying to run it against is the unifi controller (locally). And in the plugin I don't want to have to deal with ssl version control ....
guess I will stay with curl. but why can CURL do it w/o any complains, does it come with its own ssl?
Fri Feb 02, 2018 10:06 pm
yes its different ..
curl -V
curl 7.43.0 (x86_64-apple-darwin15.0.0) libcurl/7.43.0 SecureTransport zlib/1.2.5
Protocols: dict file ftp ftps gopher http https imap imaps ldap ldaps pop3 pop3s rtsp smb smbs smtp smtps telnet tftp
Features: AsynchDNS IPv6 Largefile GSS-API Kerberos SPNEGO NTLM NTLM_WB SSL libz UnixSockets
and
python
Python 2.7.10 (default, Oct 23 2015, 19:19:21)
[GCC 4.2.1 Compatible Apple LLVM 7.0.0 (clang-700.0.59.5)] on darwin
Type "help", "copyright", "credits" or "license" for more information.
>>> import ssl
>>> ssl.OPENSSL_VERSION
'OpenSSL 0.9.8zh 14 Jan 2016'
I guess I will just continue to use cURL, it works and it is fast ..
thanks for the help
and upgrading ssl runs into the apple sudo problem that it does not allow to change these preinstalled things .
sudo mv /usr/bin/openssl /usr/bin/openssl-old
mv: rename /usr/bin/openssl to /usr/bin/openssl-old: Operation not permitted
Fri Feb 02, 2018 10:56 pm
... not giving up yet. trying to do :
python
import sys
sys.path.insert(0,'/usr/local/Cellar/openssl/1.0.2n/bin/openssl')
import ssl
but it still imports from: /usr/bin/openssl.. ?
ls /usr/local/Cellar/openssl/1.0.2n/
CHANGES         LICENSE         README         include         share
INSTALL_RECEIPT.json   NEWS         bin         lib
.. I guess this will be the job for the weekend
Sat Feb 03, 2018 10:02 am
If you don't care about https validation, just tell requests to ignore certificate validation. I suspect that'll work.
[EDIT] - sorry, I see you were trying that already. Seems odd you'd get the SSL error in that case...
Sat Feb 03, 2018 11:49 am
I wonder if this would help...
Sat Feb 03, 2018 3:11 pm
Yes that would do it. But the mac needs to be rebooted in recovery mode. For that I need to add a keyboard mouse and monitor and move it out of the closet...
Sat Feb 03, 2018 3:34 pm
my question is: is this the only way ( its the only description i found after 6 hours of looking on the net) and how is anyone on el Capitan using python requests with ssl .. .. did it work once ?
Sun Feb 04, 2018 12:27 pm
viewtopic.php?t=20127&p=153954#p153954
Bottom line: it will only fail if the target site (Github in your case) starts refusing TLS 1.0 (maybe also 1.1) connections. If you are connecting to GitHub to do version checking I'd recommend not wasting your time. We'll have an API for checking versions on the plugin store pretty soon. We're also going to investigate to see if there's anything we can do on our end to ship with Indigo to help with the issue (though we're not super confident we can find a hack around this Apple bug).
Sun Feb 04, 2018 12:36 pm
No it’s not GitHub.
I have several servers that require ssl ie:
Mother/ sense
UniFi
For both curl works fine.
And under Sierra /high Sierra python requests works fine to.
Sun Feb 04, 2018 3:05 pm
IIRC, I could not get python requests to work under Sierra either with GitHub.
Sun Feb 04, 2018 5:18 pm
Yeah, for me Sierra still shows the old openssl version, but HS doesn't.
Sun Feb 04, 2018 5:24 pm
Sorry stand corrected. I only tested under high Sierra.
Sun Feb 04, 2018 7:18 pm
My point of view if you have others using your plugins you can not assume the latest ops-sys or that users will install some difficult patches. Hence I will stick with curl. ...
