when applying trying to remove the AppleUsdftdi.kext i am told it’readonky
unable to change permissions
so guess it back to my unix reference manual unless som3
e has a simple solution
captcurrent wrote:it was a clean install but I did a time machine back up
wil try again your way
2021-02-02 16:59:20.662 Application Connected to PowerLinc 2413U interface on port usbserial-AK05Z8BU
2021-02-02 16:59:20.662 Application PowerLinc address 53.C1.81, firmware version 9.14
2021-02-02 16:59:53.903 PowerLinc Linking - syncing PowerLinc links (address 53.C1.81)
2021-02-02 16:59:53.903 Error "LaundryControlMB" on to 100; send failed (no acknowledgment)
2021-02-02 16:59:53.904 PowerLinc Linking - . . adding: INSTEON plc link to controller 39.44.1C, flags 03, group 01, data 00 00 FF
2021-02-02 16:59:54.621 Error resending previous command (busy or unexpected command)
2021-02-02 16:59:54.972 Error resending previous command (busy or unexpected command)
2021-02-02 16:59:55.324 Error resending previous command (busy or unexpected command)
2021-02-02 16:59:55.678 Error resending previous command (busy or unexpected command)
2021-02-02 16:59:56.033 Error resending previous command (busy or unexpected command)
2021-02-02 16:59:56.388 Error resending previous command (busy or unexpected command)
2021-02-02 16:59:56.741 Error resending previous command (busy or unexpected command)
2021-02-02 16:59:57.091 Error resending previous command (busy or unexpected command)
2021-02-02 16:59:57.446 Error resending previous command (busy or unexpected command)
2021-02-02 16:59:57.797 Error resending previous command (busy or unexpected command)
2021-02-02 16:59:58.147 Error resending previous command (busy or unexpected command)
2021-02-02 16:59:58.499 Error resending previous command (busy or unexpected command)
2021-02-02 16:59:58.854 Error resending previous command (busy or unexpected command)
2021-02-02 16:59:59.205 Error resending previous command (busy or unexpected command)
2021-02-02 16:59:59.555 Error resending previous command (busy or unexpected command)
2021-02-02 16:59:59.905 Error ManageAllLinkRecord failed to add link record
2021-02-02 16:59:59.909 PowerLinc Linking - sync complete
2021-02-02 16:59:59.909 PowerLinc Linking - PowerLinc links updated
2021-02-02 17:00:00.165 PowerLinc Linking - sending engine version request to 39.44.1C
2021-02-02 17:00:00.919 Error resending previous command (busy or unexpected command)
2021-02-02 17:00:01.287 Error resending previous command (busy or unexpected command)
2021-02-02 17:00:01.655 Error resending previous command (busy or unexpected command)
2021-02-02 17:00:02.023 Error resending previous command (busy or unexpected command)
2021-02-02 17:00:02.391 Error resending previous command (busy or unexpected command)
2021-02-02 17:00:02.758 Error resending previous command (busy or unexpected command)
2021-02-02 17:00:03.126 Error resending previous command (busy or unexpected command)
2021-02-02 17:00:03.494 Error resending previous command (busy or unexpected command)
2021-02-02 17:00:03.861 Error resending previous command (busy or unexpected command)
2021-02-02 17:00:04.229 Error resending previous command (busy or unexpected command)
2021-02-02 17:00:04.597 Error resending previous command (busy or unexpected command)
2021-02-02 17:00:04.965 Error resending previous command (busy or unexpected command)
2021-02-02 17:00:05.332 Error resending previous command (busy or unexpected command)
2021-02-02 17:00:05.700 Error resending previous command (busy or unexpected command)
2021-02-02 17:00:06.068 Error resending previous command (busy or unexpected command)
2021-02-02 17:00:06.419 Error SendInsteonMessage failed
2021-02-02 17:00:12.519 PowerLinc Linking - no response from device
2021-02-02 17:00:12.519 PowerLinc Linking - sending engine version request to 39.44.1C
2021-02-02 17:00:13.278 Error resending previous command (busy or unexpected command)
2021-02-02 17:00:43.478 Error PowerLinc not responding -- attempting reset
2021-02-02 17:00:43.731 Power Failure possible power failure
2021-02-02 17:00:46.982 Error resending previous command (busy or unexpected command)
2021-02-02 17:00:47.111 Interface Failure lost connection with interface
2021-02-02 17:00:47.349 Error resending previous command (busy or unexpected command)
2021-02-02 17:17:39.349 Application Started interface "INSTEON Commands 7.5.0"
2021-02-02 17:17:50.842 Application Connected to SmartHome PowerLinc USB E
2021-02-02 17:17:50.881 Application PowerLinc address 15.CD.0F, firmware version 2.13
2021-02-02 17:17:52.697 Application PowerLinc standalone operation disabled
2021-02-02 17:17:52.697 Application Indigo directly controlling automation logic
2021-02-02 17:18:06.000 PowerLinc Linking - batch syncing all links for "LowerHallControlSwitch"
2021-02-02 17:18:06.000 PowerLinc Linking - batch syncing all links for "LowerHallOfficeEndSwitch"
2021-02-02 17:18:06.000 PowerLinc Linking - batch syncing all links for "LowerStairControlMBDimmer"
2021-02-02 17:18:06.000 PowerLinc Linking - batch syncing all links for "LivingRoomControlMB"
2021-02-02 17:18:06.000 PowerLinc Linking - batch syncing all links for "MBedHallControlMB"
2021-02-02 17:18:06.001 PowerLinc Linking - batch syncing all links for "MBedBridgetControlSwitch"
2021-02-02 17:18:06.001 PowerLinc Linking - batch syncing all links for "MBedTimControlMB"
2021-02-02 17:18:06.001 PowerLinc Linking - batch syncing all links for "GarageExternalLightsControlSwitch"
2021-02-02 17:18:06.001 PowerLinc Linking - batch syncing all links for "EntryHallwayControlMB"
2021-02-02 17:18:06.001 PowerLinc Linking - batch syncing all links for "MudroomControlSwitch"
2021-02-02 17:18:06.001 PowerLinc Linking - batch syncing all links for "LaundryControlMB"
2021-02-02 17:18:06.002 PowerLinc Linking - batch syncing all links for "UpperStairControlMB"
2021-02-02 17:18:06.002 PowerLinc Linking - batch syncing all links for "MBathControlMB"
2021-02-02 17:18:06.002 PowerLinc Linking - batch syncing all links for "EntryLightRelay"
2021-02-02 17:18:06.002 PowerLinc Linking - batch syncing all links for "DiningRoomLightingRelay"
2021-02-02 17:18:06.002 PowerLinc Linking - batch syncing all links for "GBathFanSwitch"
2021-02-02 17:18:06.003 PowerLinc Linking - batch syncing all links for "KitchenCeilingLightRelay"
2021-02-02 17:18:06.003 PowerLinc Linking - batch syncing all links for "KitchenControlMB"
2021-02-02 17:18:06.003 PowerLinc Linking - batch syncing all links for "KitchenTableDimmer"
2021-02-02 17:18:06.003 PowerLinc Linking - batch syncing all links for "KitchenPantryRelay"
2021-02-02 17:18:06.003 PowerLinc Linking - batch syncing all links for "MBathLightingRelay"
2021-02-02 17:18:06.003 PowerLinc Linking - batch syncing all links for "Plug-in1"
2021-02-02 17:18:06.004 PowerLinc Linking - batch syncing all links for "Plug-in2"
2021-02-02 17:18:06.004 PowerLinc Linking - batch syncing all links for "MBedHallLightRelay"
2021-02-02 17:18:06.004 PowerLinc Linking - batch syncing all links for "FireplaceNicheDimmer"
2021-02-02 17:18:06.004 PowerLinc Linking - batch syncing all links for "BackPorchControlSwitch"
2021-02-02 17:18:06.004 PowerLinc Linking - skipping batch sync for "new device" (device communication is disabled)
2021-02-02 17:18:06.004 PowerLinc Linking - batch syncing all links for "BathFanRelay"
2021-02-02 17:18:06.005 PowerLinc Linking - batch syncing all links for "LowerLRPatioControlMB"
2021-02-02 17:18:06.005 PowerLinc Linking - batch syncing all links for "MBedTablelampPlugin"
2021-02-02 17:18:06.005 PowerLinc Linking - batch syncing all links for "Entry niche light"
2021-02-02 17:18:06.005 PowerLinc Linking - batch syncing all links for "unused"
2021-02-02 17:18:06.005 PowerLinc Linking - skipping batch sync for "PorchSensor" (device communication is disabled)
2021-02-02 17:18:06.005 PowerLinc Linking - batch sync started
2021-02-02 17:18:06.006 PowerLinc Linking - syncing PowerLinc links (address 15.CD.0F)
2021-02-02 17:18:08.385 PowerLinc Linking - . . . read: INSTEON plc link to controller 15.C6.F9, flags 03, group 01, data 00 00 FF
2021-02-02 17:18:08.465 PowerLinc Linking - . . . read: INSTEON plc link to responder 15.C6.F9, flags 02, group 13, data 03 1F 00
2021-02-02 17:18:08.465 PowerLinc Linking - . . . read: INSTEON plc link to controller 17.81.F1, flags 03, group 01, data 00 00 FF
2021-02-02 17:18:08.545 PowerLinc Linking - . . . read: INSTEON plc link to responder 17.81.F1, flags 02, group 0D, data 03 1F 00
2021-02-02 17:18:08.545 PowerLinc Linking - . . . read: INSTEON plc link to controller 15.C5.EC, flags 03, group 01, data 00 00 FF
2021-02-02 17:18:08.545 PowerLinc Linking - . . . read: INSTEON plc link to controller 15.C7.EA, flags 03, group 01, data 00 00 FF
2021-02-02 17:56:51.564 PowerLinc Linking - batch sync complete
