Running IndigoServer as a daemon
Posted: Mon Apr 07, 2008 11:16 pm
For what it's worth, I am running IndigoServer 3.0b18 as a daemon (via a /Library/LaunchDaemons file) under Leopard Server (10.5.2). There is a warning about inability to connect to the windowserver on startup, but that does not seem to affect operation. I am <b>not</b> using any options to launch it, and AppleScript seems to work as long as you don't try any user interaction. The server is up and running (and working) even before the login window shows up, and nobody needs to log in.
Now, obviously I don't know if <b>everything</b> is working. I'm just getting started with Indigo, and my configuration is fairly straight-forward. All I can say is I haven't run into any problems yet. I can connect to the server both locally and from other computers. (Even the local Indigo client acts "remote" because I'm running the server as a special non-privileged user.)
So whatever trouble you all have run into in the past, don't seem to affect me at this point. If you have questions about my setup, ask away.
-- perry
-- perry
