macOS High Sierra (10.13) FTDI Driver Bug Workaround
Fri Feb 05, 2021 1:33 pm
timrowledge offline
Re: macOS High Sierra (10.13) FTDI Driver Bug Workaround
Right; stop server, unplug old 2414, plug in new 2413, restart server, configure to new 2413 & usb port.
Same USB, same cable, same outlet - though I have tried differnt USB ports & cables, and other mains outlets, ad infinitum.
Starts off looking promising and then goes weird -
Feb 5, 2021 at 11:11:26 AM
   Starting Indigo Server version 7.5.0 (Mac OS X 10.14.6)
   Loading database "/Users/tim/Documents/1880AshlingRd-Indigo6.indiDb"
   Waiting for client to connect
   Bonjour registered "Indigo - 1880AshlingRd-Indigo6"
   WebServer client connected
   WebServer                       started on port 8176 -- digest authentication enabled
   Indigo Cocoa client connected
   Waiting for client to sync
   Loading disabled plugins
   Found disabled plugin "DIRECTV DVR Control 1.1.1"
   Found disabled plugin "Growl 1.1.3"
   Found disabled interface "Z-Wave 7.5.0"
   Found disabled interface "Virtual Devices 7.4.1"
   Found disabled plugin "Global Property Manager 7.4.1"
   Found disabled plugin "Vera Bridge 1.0.10"
   Found disabled plugin "Airfoil Pro 7.5.0"
   Found disabled plugin "NOAA Weather 7.4.1"
   Found disabled plugin "SQL Logger 7.5.0"
   Found disabled plugin "EasyDAQ Relay Card 7.5.0"
   Found disabled plugin "Airfoil 1.1.14"
   Found disabled plugin "iTunes 7.5.0"
   Found disabled plugin "iCal Alarm Processor 1.1.1"
   Loading internal plugins
   Loading interface "INSTEON Commands 7.5.0"
   Starting interface "INSTEON Commands 7.5.0" (pid 24580)
   Loading plugin "Action Collection 7.5.0"
   Starting plugin "Action Collection 7.5.0" (pid 24581)
   Loading plugin "Timers and Pesters 7.4.1"
   Starting plugin "Timers and Pesters 7.4.1" (pid 24582)
   Started plugin "Timers and Pesters 7.4.1"
   Started interface "INSTEON Commands 7.5.0"
   Started plugin "Action Collection 7.5.0"
   Waiting for internal plugins to initialize
   Loading external plugins
   Starting triggers and schedules
Feb 5, 2021 at 11:11:40 AM
   Interface Failure               failed to establish connection with USB interface PowerLinc 2414U
   Closed connection to PowerLinc 2414U
   Disabling interface "INSTEON Commands 7.5.0"
   Stopping interface "INSTEON Commands 7.5.0" (pid 24580)
   Stopped interface "INSTEON Commands 7.5.0"
   Enabling interface "INSTEON Commands 7.5.0"
   Starting interface "INSTEON Commands 7.5.0" (pid 24585)
   Connected to PowerLinc 2413U interface on port usbserial-AK05Z8BU
   PowerLinc address 53.C1.81, firmware version 9.14
   PowerLinc                       Linking - batch syncing all links for "LowerHallControlSwitch"
   PowerLinc                       Linking - batch syncing all links for "LowerHallOfficeEndSwitch"
   PowerLinc                       Linking - batch syncing all links for "LowerStairControlMBDimmer"
   PowerLinc                       Linking - batch syncing all links for "LivingRoomControlMB"
   PowerLinc                       Linking - batch syncing all links for "MBedHallControlMB"
   PowerLinc                       Linking - batch syncing all links for "MBedBridgetControlSwitch"
   PowerLinc                       Linking - batch syncing all links for "MBedTimControlMB"
   PowerLinc                       Linking - batch syncing all links for "GarageExternalLightsControlSwitch"
   PowerLinc                       Linking - batch syncing all links for "EntryHallwayControlMB"
   PowerLinc                       Linking - batch syncing all links for "MudroomControlSwitch"
   PowerLinc                       Linking - batch syncing all links for "LaundryControlMB"
   PowerLinc                       Linking - batch syncing all links for "UpperStairControlMB"
   PowerLinc                       Linking - batch syncing all links for "MBathControlMB"
   PowerLinc                       Linking - batch syncing all links for "EntryLightRelay"
   PowerLinc                       Linking - batch syncing all links for "DiningRoomLightingRelay"
   PowerLinc                       Linking - batch syncing all links for "GBathFanSwitch"
   PowerLinc                       Linking - batch syncing all links for "KitchenCeilingLightRelay"
   PowerLinc                       Linking - batch syncing all links for "KitchenControlMB"
   PowerLinc                       Linking - batch syncing all links for "KitchenTableDimmer"
   PowerLinc                       Linking - batch syncing all links for "KitchenPantryRelay"
   PowerLinc                       Linking - batch syncing all links for "MBathLightingRelay"
   PowerLinc                       Linking - batch syncing all links for "Plug-in1"
   PowerLinc                       Linking - batch syncing all links for "Plug-in2"
   PowerLinc                       Linking - batch syncing all links for "MBedHallLightRelay"
   PowerLinc                       Linking - batch syncing all links for "FireplaceNicheDimmer"
   PowerLinc                       Linking - batch syncing all links for "BackPorchControlSwitch"
   PowerLinc                       Linking - skipping batch sync for "new device" (device communication is disabled)
   PowerLinc                       Linking - batch syncing all links for "BathFanRelay"
   PowerLinc                       Linking - batch syncing all links for "LowerLRPatioControlMB"
   PowerLinc                       Linking - batch syncing all links for "MBedTablelampPlugin"
   PowerLinc                       Linking - batch syncing all links for "Entry niche light"
   PowerLinc                       Linking - batch syncing all links for "unused"
   PowerLinc                       Linking - skipping batch sync for "PorchSensor" (device communication is disabled)
   PowerLinc                       Linking - batch sync started
   PowerLinc                       Linking - syncing PowerLinc links (address 53.C1.81)
   PowerLinc                       Linking - comparing local and powerlinc links
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 15.C6.F9 group 01 (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 15.C6.F9 group 13 (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 17.81.F1 group 01 (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 17.81.F1 group 0D (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 15.C5.EC group 01 (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 15.C7.EA group 01 (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 13.56.E3 group 01 (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 16.62.D8 group 01 (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 16.62.D8 group 13 (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 13.58.A7 group 01 (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 17.82.96 group 01 (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 15.C7.80 group 01 (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 1A.1F.80 group 01 (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 1A.1F.80 group 0D (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 15.C7.80 group 13 (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 16.61.7E group 01 (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 13.57.76 group 01 (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 17.88.74 group 01 (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 16.62.75 group 01 (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 17.84.6F group 01 (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 17.84.6F group 0D (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 16.62.66 group 01 (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 2C.87.63 group 01 (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 17.82.5F group 01 (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 16.63.5D group 01 (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 17.56.59 group 01 (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 15.C7.40 group 01 (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 15.C7.40 group 0D (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 15.C4.39 group 01 (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 15.C7.2B group 01 (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 15.27.2B group 01 (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 17.7E.28 group 01 (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 17.7E.28 group 0D (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 16.62.23 group 01 (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 13.55.22 group 01 (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 13.55.22 group 13 (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 16.62.21 group 01 (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 39.44.1C group 01 (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 13.55.17 group 01 (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 15.C7.11 group 01 (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 14.7E.0F group 01 (adding remote link)
   PowerLinc                       Linking - .  missing: remote link not found for persistent link 17.84.0A group 01 (adding remote link)
   PowerLinc                       Linking - compare complete
   PowerLinc                       Linking - . . adding: INSTEON plc link to controller 15.C6.F9, flags 03, group 01, data 00 00 FF
   PowerLinc                       Linking - . . adding: INSTEON plc link to responder 15.C6.F9, flags 02, group 13, data 03 1F 00
   PowerLinc                       Linking - . . adding: INSTEON plc link to controller 17.81.F1, flags 03, group 01, data 00 00 FF
   PowerLinc                       Linking - . . adding: INSTEON plc link to responder 17.81.F1, flags 02, group 0D, data 03 1F 00
   PowerLinc                       Linking - . . adding: INSTEON plc link to controller 15.C5.EC, flags 03, group 01, data 00 00 FF
   PowerLinc                       Linking - . . adding: INSTEON plc link to controller 15.C7.EA, flags 03, group 01, data 00 00 FF
   PowerLinc                       Linking - . . adding: INSTEON plc link to controller 13.56.E3, flags 03, group 01, data 00 00 FF
   PowerLinc                       Linking - . . adding: INSTEON plc link to controller 16.62.D8, flags 03, group 01, data 00 00 FF
   PowerLinc                       Linking - . . adding: INSTEON plc link to responder 16.62.D8, flags 02, group 13, data 03 1F 00
   PowerLinc                       Linking - . . adding: INSTEON plc link to controller 13.58.A7, flags 03, group 01, data 00 00 FF
   PowerLinc                       Linking - . . adding: INSTEON plc link to controller 17.82.96, flags 03, group 01, data 00 00 FF
   PowerLinc                       Linking - . . adding: INSTEON plc link to controller 15.C7.80, flags 03, group 01, data 00 00 FF
   PowerLinc                       Linking - . . adding: INSTEON plc link to controller 1A.1F.80, flags 03, group 01, data 00 00 FF
   PowerLinc                       Linking - . . adding: INSTEON plc link to responder 1A.1F.80, flags 02, group 0D, data 03 1F 00
   PowerLinc                       Linking - . . adding: INSTEON plc link to responder 15.C7.80, flags 02, group 13, data 03 1F 00
   PowerLinc                       Linking - . . adding: INSTEON plc link to controller 16.61.7E, flags 03, group 01, data 00 00 FF
   PowerLinc                       Linking - . . adding: INSTEON plc link to controller 13.57.76, flags 03, group 01, data 00 00 FF
   PowerLinc                       Linking - . . adding: INSTEON plc link to controller 17.88.74, flags 03, group 01, data 00 00 FF
   PowerLinc                       Linking - . . adding: INSTEON plc link to controller 16.62.75, flags 03, group 01, data 00 00 FF
   PowerLinc                       Linking - . . adding: INSTEON plc link to controller 17.84.6F, flags 03, group 01, data 00 00 FF
   PowerLinc                       Linking - . . adding: INSTEON plc link to responder 17.84.6F, flags 02, group 0D, data 03 1F 00
   PowerLinc                       Linking - . . adding: INSTEON plc link to controller 16.62.66, flags 03, group 01, data 00 00 FF
   PowerLinc                       Linking - . . adding: INSTEON plc link to controller 2C.87.63, flags 03, group 01, data 00 00 FF
   PowerLinc                       Linking - . . adding: INSTEON plc link to controller 17.82.5F, flags 03, group 01, data 00 00 FF
   PowerLinc                       Linking - . . adding: INSTEON plc link to controller 16.63.5D, flags 03, group 01, data 00 00 FF
   PowerLinc                       Linking - . . adding: INSTEON plc link to controller 17.56.59, flags 03, group 01, data 00 00 FF
   PowerLinc                       Linking - . . adding: INSTEON plc link to controller 15.C7.40, flags 03, group 01, data 00 00 FF
   PowerLinc                       Linking - . . adding: INSTEON plc link to responder 15.C7.40, flags 02, group 0D, data 03 1F 00
   PowerLinc                       Linking - . . adding: INSTEON plc link to controller 15.C4.39, flags 03, group 01, data 00 00 FF
   PowerLinc                       Linking - . . adding: INSTEON plc link to controller 15.C7.2B, flags 03, group 01, data 00 00 FF
   PowerLinc                       Linking - . . adding: INSTEON plc link to controller 15.27.2B, flags 03, group 01, data 00 00 FF
   PowerLinc                       Linking - . . adding: INSTEON plc link to controller 17.7E.28, flags 03, group 01, data 00 00 FF
   PowerLinc                       Linking - . . adding: INSTEON plc link to responder 17.7E.28, flags 02, group 0D, data 03 1F 00
   PowerLinc                       Linking - . . adding: INSTEON plc link to controller 16.62.23, flags 03, group 01, data 00 00 FF
   PowerLinc                       Linking - . . adding: INSTEON plc link to controller 13.55.22, flags 03, group 01, data 00 00 FF
   PowerLinc                       Linking - . . adding: INSTEON plc link to responder 13.55.22, flags 02, group 13, data 03 1F 00
   PowerLinc                       Linking - . . adding: INSTEON plc link to controller 16.62.21, flags 03, group 01, data 00 00 FF
   PowerLinc                       Linking - . . adding: INSTEON plc link to controller 39.44.1C, flags 03, group 01, data 00 00 FF
   PowerLinc                       Linking - . . adding: INSTEON plc link to controller 13.55.17, flags 03, group 01, data 00 00 FF
   PowerLinc                       Linking - . . adding: INSTEON plc link to controller 15.C7.11, flags 03, group 01, data 00 00 FF
   PowerLinc                       Linking - . . adding: INSTEON plc link to controller 14.7E.0F, flags 03, group 01, data 00 00 FF
   PowerLinc                       Linking - . . adding: INSTEON plc link to controller 17.84.0A, flags 03, group 01, data 00 00 FF
   PowerLinc                       Linking - sync complete
   PowerLinc                       Linking - PowerLinc links updated
   PowerLinc                       Linking
   PowerLinc                       Linking - initializing remote device "LowerHallControlSwitch" (address 16.62.23, firmware version 3A)
   Error                           resending previous command (busy or unexpected command)
   Error                           SendInsteonMessage failed
   Error                           Linking - initializing failed
   Error                           PowerLinc not responding -- attempting reset
   Power Failure                   possible power failure
   Interface Failure               lost connection with interface
   PowerLinc                       Linking
   PowerLinc                       Linking - initializing remote device "LowerHallOfficeEndSwitch" (address 16.62.66, firmware version 3A)
   PowerLinc                       Linking
   PowerLinc                       Linking - initializing remote device "LowerStairControlMBDimmer" (address 17.56.59, firmware version 36)
   PowerLinc                       Linking
   PowerLinc                       Linking - initializing remote device "LivingRoomControlMB" (address 15.C5.EC, firmware version 36)
   PowerLinc                       Linking - batch sync canceled
   Error                           linking canceled by user
Just for the hell of it I also tried with the bought-in-december 2413 again; same log issues with link failure, resending and even the 'possible power failure'. Which implies some sort of software issue rather than the unit failing. The annoying thing is that nothing ahs been intentionally changed around the house/insteon/mac setup in a long time.
Fri Feb 05, 2021 2:51 pm
Have you tried all of the troubleshooting steps in signal troubleshooting guide? The first one would be to run a long outdoor extension cord from a totally different area of the house to the PowerLinc and see if it that behavior persists. The trouble starts when the PowerLinc is trying to talk to something else, which is why I highly recommend trying those things. It is an unusual error to get, but maybe it's just a red herring.
Fri Feb 05, 2021 4:47 pm
timrowledge offline
Thanks for the suggestions; looking at the troubleshooting list I seem to have done everything bar isolating every single device.
I have a phaselinc installed at the power panel as well as a fair number of dual band devices. I've tried this whole cycle with it connected as well as not connected, just in case it has a problem.
I have filterlinc things for both UPS. (And I've swapped them around in case one was having a problem).
I have used an extension to connect the PLM to a different mains outlet; I can try more later today.
Signal strength stuff... well we have the same 28 devices as for the last 10 years, no change there.
I don't have any new or changed things in the house - we haven't been able to afford anything! I suppose something might have started to fail though so I'll do the airgap dance around the house and see if anything changes.
The thing that really baffles me is the combination of
a) why is the log showing
which reads like it is saying the connection to the PLM has failed, which is why it looked like the FTDI bug to me
b) why is the ancient 2414 working just fine - aside from not being able to do half the job of talking to some newer insteon devices?
Sat Feb 06, 2021 12:55 pm
timrowledge offline
Just as s mall update - some googling suggests I'm far from the only person experiencing this kind of problem and it isn't only "death after warranty".
See https://forum.insteon.com/forum/main-ca ... e-failures
A relevant part -
Then a day later...the replacement also failed, in exactly the same way. If I reboot everything, quit/restart, unplug/replug the USB, etc..., then Indigo can communicate with the 2413U just long enough to say "yes, you're a 2413, great." But as soon as I send any commands, I get the "resending previous command" errors (and occasionally "SendInsteonMessage failed," or "Possible power failure.")
Sat Feb 06, 2021 1:38 pm
Korey offline
I wonder if the new 2234-222 PLM will ever be released :?: :|
Too bad Insteon seems to be left for dead, no new products in years. :cry:
Korey
Sat Feb 06, 2021 4:56 pm
These errors are similar to what we've seen when there is excessive power line noise (or a broken Insteon module sending junk) – it can get the PowerLinc so confused it stops accepting any commands from Indigo and eventually tells Indigo there has been a power failure. Instead of air gapping off all your modules, you could try turning off all the circuit breakers in the house except for the one with your Mac and the PowerLinc on it. If that calms things down then you can turn the breakers back on and try to isolate which one has the gremlin.
Or it could be consecutive malfunctioning PowerLincs. Are you purchasing them from Smarthome? We've had issues in the past with Amazon vendors sending really marginal interfaces, so you might have better luck with one from Smarthome.
Sat Feb 06, 2021 7:15 pm
timrowledge offline
Hi Matt,
well I've just spent an afternoon trying out both the breakers-off and airgap-everything (both all at once and one at a time, which really gives you a stair workout) tests and saw no difference at all. Same pattern in all cases; the PLM initially talks to the Mac, fails to connect to the devices that are actually 'love' and then complains about the PLM not being connected. Meanwhile, the ancient 2414 has no problems except being incredibly sllllloooowwwww to sync. Like 40 minutes :-)
I even tried some of the tests with the last-December 2413 PLM just in case, but that behaves exactly the same.
One thing I'm not sure has been noted is that the 2413 *does* see signals from the assorted devices; if I operate a switch or press a button, it sees it. Indigo obviously then tries to handle it... but with the sync failure situation, nothing happens. Might we consider that as implying some problem in the PLM firmware ?
As for the origin of the devices - I've bought all my insteon parts from AARTECH because Canada. Both the problematic 2413s are 'rev 2.5 1719'.
I'm baffled.
Sun Feb 07, 2021 12:18 pm
Since turning off the breakers didn't help and the 2414U works I think we can rule out a power line signal issue as the cause. That leaves us with either: 1) malfunctioning PowerLinc (multiple since you've tried more than one), 2) a USB problem, 3) the FTDI driver issue.
#1 is possible, but before you order yet another PowerLinc I'd suggest further trying to rule out #2 and #3. I know you've tried multiple USB ports, but have you tried USB hubs? Lastly, you can try the FTDI driver workaround issues to see if that helps. If you have access to another Mac then I'd suggest installing the Indigo trial (or temporarily deactivating your license and activating it on the other Mac) as that will help rule out a malfunctioning PowerLinc.
If none of that gets you anywhere then I'm at a loss except for it being another bad PowerLinc...
Mon Feb 08, 2021 11:34 am
Shakes the magic 8 ball: unlikely
Honestly, I do hope so, if for no other reason than a majority (by a very slim margin) of our users still use some Insteon devices (not necessarily exclusively though). Replacing hardware is expensive and a lot of our users have a big investment in Insteon, so I really hope they can hold it together, but I'm very much afraid the market has moved past the Insteon technology.
Mon Feb 08, 2021 12:16 pm
bschollnick2 offline
Replacing the Insteon with What? Zwave?
Dual band Insteon has been rock solid here. I'm very reluctant to switch away, especially since I have extra Insteon hardware... (Admitably older hardware, but...)
But if my HA was to go belly up, I'd have to re-evaluate, and decide how I want to go next...
for v5 - http://bit.ly/T6WBKu
Mon Feb 08, 2021 12:22 pm
   PowerLinc                       Linking
I had a very similar issue, but it wasn't the PLM. It was due to a noisy power supply on a 3d printer. Solved it by using ferrite chokes (eg https://www.amazon.com/Jabinco-20pcs-Fe ... 449&sr=8-3).
It was a PITA to diagnose, until I realized that the HA died very time I turned on the 3d printer, and started working shortly *AFTER* I turned it off.
I realize you said that it played breaker roulette, but is there any other devices plugged into the same outlet or surge protector? Have you tried any other outlets in the house. Any devices get moved around the house?
Mon Feb 08, 2021 1:30 pm
eme jota ce offline
In the same boat with you. I have 100 Insteon devices listed in Indigo (some are duplicates such as fan / light). They've been very reliable for 8 years - especially in some places that Z-wave has difficulty reaching, such as detached garage. That would be a co$tly project to replace.
Wondering what Matt / Jay / and others in this forum would recommend to install as Insteon devices fail and need to be replaced?
Mon Feb 08, 2021 2:49 pm
Korey offline
I'm in the same boat currently @ 94 Insteon devices in daily use.. So that's about $5K @ an average of $50 a module to replace.
So I'll be replacing my Insteon as it dies until you can no longer find replacments.. over 15 years i've lost about 5 modules total (Not counting the 3-4 PLM) most of those user error shorting the load.. :shock: :roll:
I have learned to have a spare PLM ready to go.
If I ever start from scratch I think it will be Lutron RA2. It's a lot of $$$$ but you get what you pay for.
Korey
Mon Feb 08, 2021 4:23 pm
timrowledge offline
An Update; and a strong case of WTF?
I took everything down. Turned off everyinthg (again). Thought about even starting with a fresh install and making a new file.
Did the reassembling and decided to re-try the "plug PLM into different outlet" with a longer extension and an outlet the other side of the house. Ah, it actually connected. Interesting. OK, has something magically fixed itself? Nope, same issue when plugged back in the same outlet that it has sat in for ten years. Try another couple of outlets, gradually getting closer to the server stuff.
One outlet in the office (wherein lived the server closet etc) makes it all very happy. The other one (guess which one I had tried before) doesn't. I only tried the OK outlet because the other had two things plugged in at the time.
After getting the sytem fully operational with the extension lead trailing across the floor I tried plugging back into the 'normal' one - no luck, it still refuses to communicate with any devices. This, by the way, is the outlet that the UPs and servers are plugged into, via a FilterLinc. The circuit has just this single outlet, all on its own breaker. The OK outlet in the office and the not-OK one are on a different circuit.
Somewhere, there is some magic thing affecting this circuit (which is all of 8ft of cable from the breaker) that has waited 10 years to attack. I guess now I have to work out which circuit the OK outlet sits on and try splicing an outlet in a convenient location.
There must, sruely, be some tool that I could use to track down the culprit more precisely. Do I really need to borrow an oscilloscope (not to mention someone that can twiddle the knobs in the right manner) to solve this?
And of course, I have to think of what to start replacing insteon stuff with. This level of annoyance really doesn't make me happy. Z-Wave? HomeKit stuff? Sonoff?
In the meantime, thank you for making suggestions and helping me stay (vaguely) sane) during the War Of The PLM.
Mon Feb 08, 2021 5:00 pm
We've received a lot of requests like this, both here on the forums and in support emails and support form requests. I've just created a new forum to discuss options for switching between technologies (not expressly concerning Insteon, but rather a more general place to discuss switching between technologies). Please read the rules for posting there before posting so we can keep that forum useful.
