Authentication error
Sat Jul 22, 2023 2:10 pm
MarcoGT offline
In my father’s setup he gets following error
He revoked the authorization but did not help
Indigo license is shown as OK
Where is the problem?
Sat Jul 22, 2023 5:58 pm
Re: Authentication error
Is his reflector set up and running?
Sat Jul 22, 2023 11:44 pm
MarcoGT offline
Yes, it is
Sun Jul 23, 2023 9:36 am
donhoffman offline
Had this happen to me last night. Only way I found to fix it was to go “Account Home”->Authorization and revoke Alexa’s permissions, then re-link the skill. Interesting that this did not work for your father.
Sun Jul 23, 2023 11:04 am
Use the Contact Form to submit his Indigo Account username or email and include a link to this forum topic so we'll know the context.
Sun Jul 23, 2023 12:04 pm
AutoMation01 offline
This keeps recuring in my environment ...... Three times now in the last 2 days.
Is there something going on with the license or is there a plugin or base level update that I need to update? I appear to be on 2022.2.2
I seem to have to revoke the current and re-enable the skill each time to restore. Here are some log entries from the most recent occurrence:
Jul 23, 2023 at 11:57:39 AM
Web Server Error Attempt to validate token failed
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpcore/_exceptions.py", line 10, in map_exceptions
yield
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpcore/backends/sync.py", line 94, in connect_tcp
sock = socket.create_connection(
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/socket.py", line 824, in create_connection
for res in getaddrinfo(host, port, 0, SOCK_STREAM):
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/socket.py", line 955, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno 8] nodename nor servname provided, or not known
During handling of the above exception, another exception occurred:
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpx/_transports/default.py", line 60, in map_httpcore_exceptions
yield
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpx/_transports/default.py", line 218, in handle_request
resp = self._pool.handle_request(req)
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpcore/_sync/connection_pool.py", line 253, in handle_request
raise exc
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpcore/_sync/connection_pool.py", line 237, in handle_request
response = connection.handle_request(request)
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpcore/_sync/connection.py", line 86, in handle_request
raise exc
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpcore/_sync/connection.py", line 63, in handle_request
stream = self._connect(request)
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpcore/_sync/connection.py", line 111, in _connect
stream = self._network_backend.connect_tcp(**kwargs)
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpcore/backends/sync.py", line 93, in connect_tcp
with map_exceptions(exc_map):
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/contextlib.py", line 153, in __exit__
self.gen.throw(typ, value, traceback)
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpcore/_exceptions.py", line 14, in map_exceptions
raise to_exc(exc)
httpcore.ConnectError: [Errno 8] nodename nor servname provided, or not known
The above exception was the direct cause of the following exception:
File "plugin.py", line 235, in verify_token
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpx/_api.py", line 189, in get
return request(
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpx/_api.py", line 100, in request
return client.request(
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpx/_client.py", line 821, in request
return self.send(request, auth=auth, follow_redirects=follow_redirects)
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpx/_client.py", line 908, in send
response = self._send_handling_auth(
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpx/_client.py", line 936, in _send_handling_auth
response = self._send_handling_redirects(
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpx/_client.py", line 973, in _send_handling_redirects
response = self._send_single_request(request)
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpx/_client.py", line 1009, in _send_single_request
response = transport.handle_request(request)
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpx/_transports/default.py", line 217, in handle_request
with map_httpcore_exceptions():
File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/httpx/_transports/default.py", line 77, in map_httpcore_exceptions
raise mapped_exc(message) from exc
httpx.ConnectError: [Errno 8] nodename nor servname provided, or not known
yield
yield
raise exc
raise exc
raise to_exc(exc)
return request(
yield
yield
raise exc
raise exc
raise to_exc(exc)
return request(
Sun Jul 23, 2023 12:14 pm
MarcoGT offline
Now he succeeded to link the indigo skill, but the first attempt did not work
Tue Jul 25, 2023 6:37 am
mclass offline
This keeps recurring in my environment ...... Three times now in the last 2 days.
I too have been experiencing this issue over the last two days here in Australia. After revoking and re-authenticating as described by previous posters it comes good but fails again (often in a matter of minutes) with similar errors in log as reported by AutoMation01 . Reloading plugin, restarting server and rebooting modem router seems to have no effect or improvement.
Indigo 2022.2.2
Alexa plugin 2022.2.0
OAuth enabled in the Start Local Server dialog
    yield
    yield
    raise exc
    raise exc
    raise to_exc(exc)
    return request(
Any assistance appreciated
mclass
Wed Jul 26, 2023 1:36 pm
Wed Jul 26, 2023 5:48 pm
Thanks Jay ...
In my case the issues were continuing every day for several days straight (sometimes more then once a day - similar to what mclass reported from down under).
Shooting at straws and suspecting network issue of some kind, (using the traditional network philosophy that it is always DNS ;-) ), I added a public DNS server to my network configuration along with my PiHole DNS server that I was only using as the singular DNS server for the Indigo host (never had any issues with this network config before and have been running the same DNS services on this host for years without any issue) ????.
Alexa has remained active without license expiration for more than a day now, so I am hoping for the best and keeping my fingers crossed .... Could just be coincidence of timing.
My local host is already configured for proper loopback so that is not an issue in my case.
I do have both wired LAN and WiFi connections active to different networks segments (IOT and LAN), but will experiment further and turn off the WiFi interface if the current DNS testing fails. More to follow if the issues recur.
Best regards,
Dean
Thu Jul 27, 2023 5:33 am
mclass offline
Thanks from me too, Jay! Twelve hours now without error!
The local host line was in the file, but so was other mysterious stuff!!
What mystifies me though is this Alexa plugin issue occurred on a headless Mac Mini that is dedicated to Indigo, that had run the Alexa app without issues for many months and had not had any tweaks before the issue occurred.
To add to the mystery is that a number of users experienced the problem within the same period of time!
But all now seems good, thanks
mclass
Thu Jul 27, 2023 6:58 am
I suspect a recent macOS update has made it less tolerant of unexpected/missing items in the hosts file. But that's just a guess.
Note, however, that this isn't restricted to the Alexa plugin - there are reports from other plugins which use certain network library features are failing in the same way as well, which further seems to indicate that something in macOS has changed.
Thu Jul 27, 2023 8:05 am
Did you save a copy of what was in the hosts file? It would be interesting to see if everyone having the problem has the same (or similar) mysterious lines or not.
Thu Jul 27, 2023 9:12 am
Mine is pretty basic. ..... IP4, IP6 and broadcast loopback with a couple of static host definitions.
Here are my entries for comparison:
# Host Database
# localhost is used to configure the loopback interface
# when the system is booting.  Do not change this entry.
127.0.0.1   localhost
255.255.255.255   broadcasthost
::1             localhost
fe80::1%lo0   localhost
192.168.1.67   myserver5.local
192.168.1.66   myserver3.local
Thu Jul 27, 2023 4:34 pm
mclass offline
Host file prior to edit:
# Host Database
127.0.0.1       localhost
::1             localhost
# Added by Docker Desktop
# To allow the same kube context to work on the host and the container:
27.0.0.1 kubernetes.docker.internal
# End of section
Not knowing exactly what I was doing (!), I commented out all lines except the localhost. I suspect I will need to uncomment the broadcast host, but Docker is no longer installed. Not sure if the "::1 localhost" is required and any advice appreciated. Here's the content after edit that restored Alexa plugin performance:
# Host Database
127.0.0.1       localhost
#255.255.255.255        broadcasthost
#::1             localhost
#27.0.0.1 kubernetes.docker.internal
# End of section
