Database disappeared as machine was forced to restart
Questions and comments about the Indigo Server. You can also post here if you're unclear which other forum to post to.
wjlevin
Post by wjlevin »
Hello:
I've never had anything like this before. I was trying to use Indigo touch but nothing appeared. Checked my Mac and found that it had restarted and that Indigo was completely blank. There was something about not being able to find or open the database and that it was either gone or corrupt. Well, the Database folder was empty. I managed to start up again from the Database backup folder.
I was seeing some errors show up previously - but I didn't capture them to share -I meant to write you.
Is there any way to check the integrity of the Database?
Below is what I do have in the log from today:
Any suggestions?
Many thanks,
Wayne
Jul 4, 2024 at 12:27:28 PM
   Starting Indigo Server version 2023.2.0 on macOS Version 14.5 (Build 23F79)
   Loading database "/Users/homeautomation/Documents/Indigo/13 Gladiola.indiDb"
   Error                           XML Parse Error: not well-formed (invalid token)
   Error                           In file /Users/homeautomation/Documents/Indigo/13 Gladiola.indiDb
   Error                           On character 0 of line number 1.
   Error                           failed to load database file
   Waiting for client to connect
   Retrieved unchanged location for sunset/sunrise calculation
   Indigo Cocoa client connected
   Waiting for client to sync
   Switching to database "No Database Selected"
Jul 4, 2024 at 12:27:34 PM
   Finding disabled plugins
   Found disabled plugin "Global Property Manager 2023.2.0" using API v3.3
   Found disabled plugin "Timers and Pesters 2023.2.0" using API v3.3
   Found disabled plugin "Alexa 2023.2.0" using API v3.3
   Found disabled plugin "Airfoil Pro 2023.2.0" using API v3.3
   Found disabled plugin "NOAA Weather 2023.2.0" using API v3.3
   Found disabled plugin "SQL Logger 2023.2.0" using API v3.3
   Found disabled plugin "EasyDAQ Relay Card 2023.2.0" using API v3.3
   Loading internal plugins
   Loading interface "Z-Wave 2023.2.0" using API v3.3
   Starting interface "Z-Wave 2023.2.0" (pid 720)
   Loading interface "Virtual Devices 2023.2.0" using API v3.3
   Starting interface "Virtual Devices 2023.2.0" (pid 721)
   Loading plugin "Web Server 2023.2.0" using API v3.3
   Starting plugin "Web Server 2023.2.0" (pid 722)
   Loading interface "INSTEON Commands 2023.2.0" using API v3.3
   Starting interface "INSTEON Commands 2023.2.0" (pid 723)
   Loading plugin "Action Collection 2023.2.0" using API v3.3
   Starting plugin "Action Collection 2023.2.0" (pid 724)
   Loading plugin "Email+ 2023.2.0" using API v3.3
   Starting plugin "Email+ 2023.2.0" (pid 725)
   Started interface "Virtual Devices 2023.2.0"
   Started interface "INSTEON Commands 2023.2.0"
   Started plugin "Email+ 2023.2.0"
   Started plugin "Action Collection 2023.2.0"
   Started plugin "Web Server 2023.2.0"
   Web Server                      starting internal Web server on http://localhost:8176
   Bonjour registered "Indigo - No Database Selected"
   Started interface "Z-Wave 2023.2.0"
   Z-Wave Debug                    starting serial connection loop
   Z-Wave Debug                    starting zwave packet parser thread
   Z-Wave Debug                    SENT getVersion: 01 03 00 15 E9
   Z-Wave Debug                    RCVD getVersion: 01 10 01 15 5A 2D 57 61 76 65 20 36 2E 30 37 00 01 97 (no inbound callback)
   Z-Wave Debug                    . .  getVersion: Z-Wave 6.07 static controller
   Z-Wave Debug                    SENT getHomeID: 01 03 00 20 DC
   Z-Wave Debug                    RCVD getHomeID: 01 08 01 20 E3 51 EE 58 01 D3 (no inbound callback)
   Z-Wave Debug                    . .  getHomeID: E351EE58, nodeID: 001
   Z-Wave Debug                    SENT getInterfaceFeatures: 01 03 00 05 F9
   Z-Wave Debug                    RCVD getInterfaceFeatures: 01 04 01 05 38 C7 (no inbound callback)
   Z-Wave Debug                    . .  getInterfaceFeatures: 38
   Z-Wave Debug                    SENT getInterfaceApiCapabilities: 01 03 00 07 FB
   Z-Wave Debug                    RCVD getInterfaceApiCapabilities: 01 2B 01 07 01 02 00 86 00 01 00 5A FE 87 7F 88 CF 7F C0 4F FB DF FD E0 67 00 80 80 00 80 86 00 01 00 E8 73 00 80 0F 00 00 60 00 00 90 (no inbound callback)
   Z-Wave Debug                    . .  getInterfaceApiCapabilities: supportedFuncIDs: 02 03 04 05 06 07 08 09 0A 0B 10 11 12 13 14 15 16 17 1C 20 21 22 23 24 27 28 29 2A 2B 2C 2D 2E 2F 37 38 39 3A 3B 3C 3F 41 42 44 45 46 47 48 49 4A 4B 4C 4D 4F 50 51 53 54 55 56 57 58 5E 5F 60 61 62 63 66 67 78 80 90 92 93 98 A1 B4 B6 B7 B8 B9 BA BD BE BF D0 D1 D2 D3 D4 EE EF
   Z-Wave Debug                    . .  getInterfaceApiCapabilities: serialApi 1.02, manufactureId 0086, productType 0001, productId 005A
   Z-Wave Debug                    . .  getInterfaceApiCapabilities: SDK6.60.00+ (expecting RSSI value and securityKeyType bytes)
   Z-Wave Debug                    . .  getInterfaceApiCapabilities: supportsGetClearNetworkStats
   Z-Wave Debug                    . .  getInterfaceApiCapabilities: supportsTransmissionMetrics
   Z-Wave Debug                    SENT setApiSetup: 01 05 00 0B 02 01 F2
   Z-Wave Debug                    RCVD setApiSetup: 01 05 01 0B 02 01 F3 (no inbound callback)
   Z-Wave Debug                    . .  setApiSetup: transmissionMetrics enabled
   Z-Wave Debug                    . .  getInterfaceApiCapabilities: supportsBackupRestore
   Z-Wave Debug                    . .  getInterfaceApiCapabilities: supportsS2
   Z-Wave Debug                    . .  getInterfaceApiCapabilities: supportsSmartStart
   Z-Wave                          connected to Z-Stick Gen5+ (ZW090) interface on /dev/cu.usbmodem13401 (firmware 1.02, minimum SDK 6.81.06)
   Z-Wave Debug                    SENT forceSUC: 01 05 00 54 01 01 AE
   Z-Wave Debug                    RCVD forceSUC: 01 04 01 54 01 AF (no inbound callback)
   Z-Wave Debug                    SENT getInitialNodeData: 01 03 00 02 FE
   Z-Wave Debug                    RCVD getInitialNodeData: 01 25 01 02 08 08 1D 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 C0 (no inbound callback)
   Z-Wave Debug                    . .  getInitialNodeData: is static update controller
   Z-Wave Debug                    . .  getInitialNodeData: [1]
   Z-Wave Debug                    SENT getNodeProtocolInfo: 01 04 00 41 01 BB
   Z-Wave Debug                    RCVD getNodeProtocolInfo: 01 09 01 41 D3 16 01 02 02 01 73 (no inbound callback)
   Z-Wave Debug                    . .  getNodeProtocolInfo:       node 001, class name: Static Computer Controller
   Z-Wave Debug                    . .  getNodeProtocolInfo:            class hierarchy: Static Controller : Static Controller : Static Computer Controller (02 : 02 : 01)
   Z-Wave Debug                    . .  getNodeProtocolInfo:         base class command: 00
   Z-Wave Debug                    . .  getNodeProtocolInfo:   supported class commands: 20
   Z-Wave Debug                    . .  getNodeProtocolInfo:     encrypt class commands:
   Z-Wave Debug                    . .  getNodeProtocolInfo:                   features: beaming
   Z-Wave Debug                    starting node healing thread
   Z-Wave Debug                    starting node status polling thread
   Reflector                       starting reflector connection to https://wjlevinhome.indigodomo.net
   Waiting for internal plugins to initialize
   Loading external plugins
   Loading plugin "Cynical SecuritySpy 3.1.1" using API v3.0.0
   Starting plugin "Cynical SecuritySpy 3.1.1" (pid 766)
   Cynical SecuritySpy             API version 3.4
   Cynical SecuritySpy             Python version 3.11.6.final.0
   Started plugin "Cynical SecuritySpy 3.1.1"
   Waiting for external plugins to initialize
   Starting triggers and schedules
Jul 4, 2024 at 12:27:52 PM
   Connected to PowerLinc 2413U interface on port usbserial-A906XNHF
   PowerLinc address 49.FA.D1, firmware version 9.14
Jul 4, 2024 at 7:03:59 PM
   Received INSTEON                4A.0D.41 on (button 1)
   Received INSTEON                4A.0D.41 off (button 1)
Jul 4, 2024 at 7:06:40 PM
Jul 4, 2024 at 7:21:02 PM
   Web Server Error                Error in plugin execution RawServerCommand: ElementNotFoundError -- could not find device with element ID 1290244192
   Web Server                      Indigo Touch client connected from 74.12.76.46
Jul 4, 2024 at 7:21:54 PM
   Web Server                      Indigo Touch client connected from 192.168.2.1
Jul 4, 2024 at 7:43:49 PM
Jul 4, 2024 at 8:58:32 PM
   Received INSTEON                1A.16.10 on (button 1)
Jul 4, 2024 at 9:02:16 PM
   Indigo Cocoa client authenticated (192.168.2.1)
Jul 4, 2024 at 9:02:38 PM
   Indigo Cocoa client disconnected (192.168.2.1)
Jul 4, 2024 at 9:03:26 PM
Jul 4, 2024 at 9:03:55 PM
Jul 4, 2024 at 9:05:23 PM
   Stopping plugin "Email+ 2023.2.0" (pid 725)
   Stopping plugin "Web Server 2023.2.0" (pid 722)
   Stopping plugin "Action Collection 2023.2.0" (pid 724)
   Stopping interface "INSTEON Commands 2023.2.0" (pid 723)
   Stopping interface "Virtual Devices 2023.2.0" (pid 721)
   Stopping interface "Z-Wave 2023.2.0" (pid 720)
   Stopping plugin "Cynical SecuritySpy 3.1.1" (pid 766)
   Z-Wave Debug                    stop_concurrent_thread called
   Z-Wave Debug                    stopping node status polling thread
   Z-Wave Debug                    stopping node healing thread
   Z-Wave Debug                    stopped zwave packet parser thread
   Stopped plugin "Web Server 2023.2.0"
   Z-Wave                          closed connection to Z-Stick Gen5+ (ZW090)
   Stopped plugin "Action Collection 2023.2.0"
   Stopped interface "INSTEON Commands 2023.2.0"
   Stopped interface "Virtual Devices 2023.2.0"
   Stopped plugin "Email+ 2023.2.0"
   Stopped interface "Z-Wave 2023.2.0"
   Stopped plugin "Cynical SecuritySpy 3.1.1"
   Error                           XML Parse Error: instantiation error 4
   Error                           On character 606 of line number 1.
Jul 4, 2024 at 9:05:25 PM
   Starting interface "Z-Wave 2023.2.0" (pid 3280)
   Starting interface "Virtual Devices 2023.2.0" (pid 3281)
   Starting plugin "Web Server 2023.2.0" (pid 3282)
   Starting interface "INSTEON Commands 2023.2.0" (pid 3283)
   Starting plugin "Action Collection 2023.2.0" (pid 3284)
   Starting plugin "Email+ 2023.2.0" (pid 3285)
   Starting plugin "Cynical SecuritySpy 3.1.1" (pid 3291)
Jul 4, 2024 at 9:05:37 PM
Jul 4, 2024 at 9:18:58 PM
   Stopping plugin "Email+ 2023.2.0" (pid 3285)
   Stopping plugin "Web Server 2023.2.0" (pid 3282)
   Stopping plugin "Action Collection 2023.2.0" (pid 3284)
   Stopping interface "INSTEON Commands 2023.2.0" (pid 3283)
   Stopping interface "Virtual Devices 2023.2.0" (pid 3281)
   Stopping interface "Z-Wave 2023.2.0" (pid 3280)
   Stopping plugin "Cynical SecuritySpy 3.1.1" (pid 3291)
   Reflector                       shutdown reflector connection
   Loading database "/Library/Application Support/Perceptive Automation/Indigo 2023.2/Databases (old)/13 Gladiola (v2023.1.1).indiDb"
   Database file was in old Indigo folder
   Saving converted database file "/Library/Application Support/Perceptive Automation/Indigo 2023.2/Databases/13 Gladiola (v2023.1.1).indiDb"
Indigo database deprecation check complete -- no AppleScripts or other incompatible objects were found.
   Switching to database "13 Gladiola (v2023.1.1)"
Jul 4, 2024 at 9:19:01 PM
   Starting interface "Z-Wave 2023.2.0" (pid 3331)
   Starting interface "Virtual Devices 2023.2.0" (pid 3332)
   Starting plugin "Web Server 2023.2.0" (pid 3333)
   Starting interface "INSTEON Commands 2023.2.0" (pid 3334)
   Starting plugin "Action Collection 2023.2.0" (pid 3335)
   Starting plugin "Email+ 2023.2.0" (pid 3336)
   Bonjour registered "Indigo - 13 Gladiola (v2023.1.1)"
   Starting plugin "Cynical SecuritySpy 3.1.1" (pid 3340)
Jul 4, 2024 at 9:19:13 PM
   Schedule                        Den Lamp On Right Weekday
   Sent INSTEON                    "Den Lamp Entrance" on
Jul 4, 2024 at 9:19:56 PM
   Sent INSTEON                    "Bedroom Vanity" status request (received: 0)
Jul 4, 2024 at 9:20:43 PM
Jul 4, 2024 at 9:30:00 PM
   Schedule                        Garage Door Status Requests
   Sent INSTEON                    "Garage Camaro" status request (received input sensor: closed)
   Sent INSTEON                    "Garage Honda" status request (received input sensor: closed)
Jul 4, 2024 at 9:44:33 PM
Jul 4, 2024 at 9:45:00 PM
jay (support)
Re: Database disappeared as machine was forced to restart
Post by jay (support) »
This detected that the db file was corrupt/missing:
You probably want to run disk first aid to make sure there isn't a problem with your disk since database files shouldn't just disappear. Also, we recommend moving your database to the Databases folder inside the Indigo installation folder:
Then back up the entire installation folder so you can easily recover from any issues:
Return to “Indigo Server Software”
