Sponsor plugin development? Geiger Counter, Radon meter
Tue May 14, 2019 5:24 pm
shapa offline
I've got a few devices which I'd really like to add to Indigo.
First one should be very easy to support - "GM-45 Geiger Counter Radiation Detector"
https://www.blackcatsystems.com/GM/prod ... unter.html
Just to read data from Serial->USB and display in the UI (+ to be able to use info to put in a variable / create graphics and use triggers).
The protocol is well described, some open-source tools are already exists (including source codes). Not changed for 5+ years :)
I'm not a developer and will be happy to sponsor (reasonably :) ) . BTW the device is not expensive, but really precise and not requiring any cloud connection.
The second one I believe is only cloud-based API support - Radon Meter RadonEye Plus2 (with WiFi).
http://radonftlab.com/radon-sensor-product/rd200/
Anyone interested?
Tue May 14, 2019 5:39 pm
It should be easy to integrate the first detector in into pibeacon.
I am out for 3 weeks but I can oder one and check it out when I am back.
Tue May 14, 2019 6:19 pm
Re: Sponsor plugin development? Geiger Counter, Radon meter
the interface is extremely easy .. ready the USB port 1/minute, get number of bytes received, send data to indigo.
indigo put data into device states
counts per minute
counts per 10 minutes
counts per hour
counts per day
then plot that state field over time,
add some triggers on number of counts > xx
Tue May 14, 2019 8:35 pm
roussell offline
Ok I have zero need for this (and hope I never do), but I REALLY want one! Time to build the bunker!
Terry
