Refreshing SecuritySpy images on Control Pages?
Mon Jan 20, 2014 8:36 pm
RikB offline
Re: Refreshing SecuritySpy images on Control Pages?
Not sure if anyone else is seeing this now, but I am having an issue with the url. When I type the url into the web browser with the usr:pwd in the url, I now get a prompt to accept the login info for SS. This seems to be causing errors now from within Indigo.
I am running the following versions:
SS v3.2.1
Indigo v6.0.9
Here is the example of the url I am using:
http://[USR]:[PWD]@[SS Server IP]:[SS Port]/live?cameraNum=1&viewMethod=0&imageSize=scale0.25&27941
I also get the following error in Indigo even tho the web browser connects just fine after I press OK on the dialog box.
http://[SS Server IP]:[SS Port]/live?cameraNum=1&viewMethod=0&imageSize=scale0.25&27941 returned type text/html (image required)
Thanks for any assistance...
Fri Jan 24, 2014 9:48 am
I'm not yet running SS v3.x (I need to upgrade), but for my Control Page URLs I use the format:
http://username:password@ss_ip:ss_port/++image?cameraNum=1&width=320&height=240
which returns a JPEG image that Indigo's Web server (and Indigo Touch) can display. Indigo cannot display live video feeds directly, but instead shows a refreshing image.
Fri Jan 24, 2014 1:10 pm
RikB offline
Thanks Matt.. It appears that I need to have a password for the user. I had left it black because it was a viewing user only but that was giving me errors. It is working now that I have switched to jpeg images and added a password to the user account..
so it works fine with Indigo v6.0.9 and SecuritySpy v3.2.1
Regards,
RikB
Wed Apr 23, 2014 8:27 am
Shutter offline
Try as I might I can't get the SecuritySpy image to show up in my control pages.
I've installed SecuritySpy correctly. I've setup Cynical SecuritySpy and I'm able to test it's working by creating an action the executes and sets a SecuritySpy preset - so that's ok. I've added a new element to the control page for the camera and can see the feed in there, it's just not showing up when I load the preview in the browser.
This is the URL I'm using on the control page, which displays the camera feed in Indigo:
http://XX.XX.XX.XX:8000/++image?cameraNum=1&width=320&height=240
I see the following keeps appearing in the logs:
WebServer                       http://XX.XX.XX.XX:8000/++image?cameraNum=1&width=320&height=240 load error: HTTP Error 401: Unauthorized
The IP in the URL is the same in both.
Any ideas?
Wed Apr 23, 2014 8:49 am
RikB offline
you need to set a username and password, it does not work as guest and you cannot have a blank password either.
Wed Apr 23, 2014 8:51 am
RikB offline
it should look more like this...
http://username:password@XX.XX.XX.XX:8000/++image?cameraNum=1&width=320&height=240
Thu Apr 24, 2014 2:36 am
Shutter offline
That solved it. Thanks RikB.
Not obvious at all that ones username/password was required - I did come across this in a forum search but thought it was required if one had setup SecuritySpy differently.
Thu Jul 24, 2014 3:05 pm
Sharek326 offline
would anyone know why when I run this I get this in the event log?
http://admin:trustno1:8000:192.168.1.12 ... height=240 load error: <urlopen error [Errno 8] nodename nor servname provided, or not known>
load error: too many values to unpack
Thu Jul 24, 2014 3:10 pm
Sharek326 offline
Never mind found it I had the port in twice
Fri Aug 01, 2014 8:10 pm
Dewster35 offline
I realize this is probably more of a security spy question than an indigo question, but for multiple cameras, are people here just putting in the two different urls for their two different cameras, or is there a way that security spy can publish both images together to the web server so I only need one element within the indigo control page?
Fri Aug 01, 2014 8:20 pm
I am just using multiple URLs. To reduce bandwidth be sure and specify the dimensions of the control in the URL so that SecuritySpy sends an appropriately scaled image.
Fri Aug 01, 2014 8:25 pm
Dewster35 offline
K. Thought so but I thought I would ask. Found a whole bunch of nice Foscam ptz for 22 bucks on amazon, regularly 99. Picked up three :-)
Thu Aug 14, 2014 6:44 pm
sbe08 offline
I'm currently experimenting with Indigo/Security Spy and one feature that I haven't figured if it's possible to do would be to iterate over multiple cameras in one view. (Just like an analog surveillance system, display a camera feed for 10 seconds then moving to the next).
Fri Aug 15, 2014 9:34 am
It's not something that's built-in to Indigo. I'm not sure if you can specify in SecuritySpy that a given static image URL should rotate.
Tue Feb 24, 2015 9:06 pm
philipbasile offline
Refreshing Panasonic images on a control page
I'm having a problem getting the jpeg images from my panasonic BL-C131 camera to work on control pages.
I have a foscam that works fine using the following url on a control page.
http://192.168.2.13/snapshot.cgi?user=a ... 345&strm=1
The panasonic url I'm trying is
http://192.168.2.14/snapshotjpeg?user=admin&pwd=12345
it works fine in my browser, but not on the control page.
I get the following error in the event log
Error (client) control page image URL failed to load: http://192.168.2.7/snapshotjpeg?user=admin&pwd=12345
Error (client) The operation couldn’t be completed. (NSURLErrorDomain error -1012.)
Does anyone have any suggestions ?
