after 6.02 upgrade-- failed to connect: Service Unavailable
Fri Sep 27, 2013 2:25 am
Since I upgraded the server at home to 6.02, itouch does not connect anymore:
tried
- Wifi,
- regular 3g;
through prism and through my public IP number.
using direct IP connection I get a "Request Timed out" and thru prism I get "failed to connect: Service Unavailable"
The Laptop client 6.01 can connect through wifi.
Itouch is version 1.70
any advice?
Fri Sep 27, 2013 8:13 am
Re: after 6.02 upgrade-- failed to connect: Service Unavaila
Try stopping/restarting the Indigo Server if you haven't already. If that still doesn't work:
1) From a browser on the Indigo Server Mac can you connect to the Web server (by default that would be: http://127.0.0.1:8176/ ) ?
2) Try totally turning off the Firewall on that Mac just for troubleshooting.
3) Open the Terminal application and copy/paste:
ps -axwww | grep Indigo
then copy/paste the results into a reply for me.
Fri Sep 27, 2013 10:44 am
after restart of the server it works again
thx
