[SOLVED]: Stuck device state image
Sat Aug 09, 2014 2:00 am
berkinet offline
I have a control page with a simple device state display. The problem I am having is the Icon tracks the device state in Safari on the Mac, but NOT in the Indigo-Touch app, where is is stuck in the On state.
Here is the Control Page editor with the specific device in question selected...
Screen Shot 2014-08-09 at 09.28.08 .png (109.29 KiB) Viewed 2666 times
Here are the image files:
Screen Shot 2014-08-09 at 09.32.08 .png (86.21 KiB) Viewed 2666 times
Here is the device:
Screen Shot 2014-08-09 at 09.51.48 .png (154.72 KiB) Viewed 2666 times
Here is a browser window when the device is off:
Screen Shot 2014-08-09 at 09.32.41 .png (66.02 KiB) Viewed 2666 times
And, finally, here is the Indigo-Touch display for the same, Off, state:
I have tried changing the image and get the same result. I have also quit and restarted the IoS app, and the i* devices, no joy. It looks like this device's state is cached somewhere. Other similar devices work as expected.
Sat Aug 09, 2014 6:15 am
Re: Stuck device state image
Have you tried adding a lightbulb_large+false.png image?
I've found this naming convention to be the most stable (where there is an explicit image for each possible state):
Sat Aug 09, 2014 6:29 am
berkinet offline
Thanks for the suggestion. Yes I did try it, but it made no difference. I moved the "+false" image to make the situation simpler to debug. Note, this works in a browser and for other similar devices. It is just this device in Indigo-touch that has the issue.
Sat Aug 09, 2014 6:43 am
I'm curious why the Pool Lights have a status of "false" while the House Ext. Lights and Yard Lights have a status of "off". They all three seem to be the same types of (Meta) devices.
Sat Aug 09, 2014 6:51 am
autolog offline
Not sure if this post helps or not :?:
Sat Aug 09, 2014 8:39 am
If the device state has non-standard on/off states (in this case using false and true instead of off/on), then you need an image file for each state name AND you need a base image name that has ends in +.png. So you would need:
It looks like you are missing the correct base file name. Be sure and reselect the new image base in the Control Page editor after you name the files correctly, then it will work.
Sun Aug 10, 2014 1:51 am
berkinet offline
Re: [SOLVED]: Stuck device state image
The Indigo-Touch app display is now working. Thanks to all who had various pieces of the answer. However, it is still a bit mysterious...
  1. @DaveL17"]DaveL17 noted the different state. Which I had seen and didn't really focus on. Turns out that device was built with an early version of the Meta-Data plugin before I changed it to have on/off states. I deleted and re-created the device and it then showed on and off states. But, it still didn't work. I also tried creating a Virtual-Device and that would not even change the state in the UI. See this separate post.
  2. Followed the theme suggested by @DaveL17, @autolog and specifically Matt and that fixed the problem.
However, it is still a mystery to me how similar another device has always worked with these two images alone:
Screen Shot 2014-08-10 at 09.18.10 .png (11.43 KiB) Viewed 2564 times
Sun Aug 10, 2014 6:11 am
[snip]
Glad you've got it going.
I don't know whether this would have made a difference (or that you didn't try), but I find that restarting the server can sometimes clear up some of these situations.
Cheers,
Dave
