WeatherFlow Plug-in
Mon Sep 21, 2020 9:56 am
jltnol offline
Re: WeatherFlow Plug-in
LOL.
I'm almost in the same boat Even with a near-miss of a hurricane or two, we've not had enough consistent rain for me to do anything close to troubleshooting... The data I'm looking for shows up on the webpage for myTempest, but doesn't show up in the plugin data, or at least that's what it seems.
Thu Oct 08, 2020 9:19 am
jltnol offline
- WeatherFlow Plugin allows me to create WS and UDP devices and they quickly populate with good data in Indigo, but then the Plugin stops seeing any new data.
So I have both the UDP (set up as "blank") and Websocket device working for Tempest, and while it seemed to be working fine, not I'm finding the UDP device isn't updating, but the web socket device is. Just for fun I created a 2nd UDP device(set up as Air Temperature, the first option), and it IS working/ updating... so just not sure why the original one has stopped...
I did re-start the plugin and that didn't work. and then I restarted the computer Indigo is running on, and that didn't help either..
Fri Dec 11, 2020 7:36 am
boisy offline
Hi Bruce,
I couldn't find a forum that has your plug-ins, so I'll post here.
Line 546 in your WeatherFlow plugin.py:
Change:
        except:
to:
[code]
except Exception as e:
[\code]
to prevent an error in the Indigo logs.
Fri Dec 11, 2020 8:16 am
tazswe offline
I suggest that you post your suggestions on GitHub https://github.com/bpennypacker/Weather ... gin/issues
Bruce is not very active on this forum.
Sat Dec 11, 2021 5:49 pm
jltnol offline
Posted on GitHub, but I'm getting these errors:
WeatherFlow Smart Weather Error Error in plugin execution runConcurrentThread:
  File "plugin.py", line 717, in runConcurrentThread
  File "plugin.py", line 645, in _process_message
  File "plugin.py", line 945, in process_obs_tempest
TypeError: list indices must be integers, not float
   WeatherFlow Smart Weather Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Sun Dec 12, 2021 3:46 pm
jltnol offline
Interestingly enough, errors have now stopped... Go Figure....
Sun Dec 26, 2021 8:58 am
jltnol offline
Although there is more on GitHub, this issue seems to be tied to Rain events. I'm no programmer so can't lend any help there, but others have confirmed that these errors are tied, at least to some extent, to rainfall.
Wed Dec 29, 2021 4:03 pm
aldera offline
Hmm... Not so sure it's tied just to rain events. I've been getting the same errors for the last couple of hours and there hasn't been any type of rain events, or snow, during this time.
Ralph
