WeatherFlow Plug-in
Mon Sep 21, 2020 9:56 am
jltnol offline
Re: WeatherFlow Plug-in
LOL.
I'm almost in the same boat Even with a near-miss of a hurricane or two, we've not had enough consistent rain for me to do anything close to troubleshooting... The data I'm looking for shows up on the webpage for myTempest, but doesn't show up in the plugin data, or at least that's what it seems.
Thu Oct 08, 2020 9:19 am
jltnol offline
- WeatherFlow Plugin allows me to create WS and UDP devices and they quickly populate with good data in Indigo, but then the Plugin stops seeing any new data.
So I have both the UDP (set up as "blank") and Websocket device working for Tempest, and while it seemed to be working fine, not I'm finding the UDP device isn't updating, but the web socket device is. Just for fun I created a 2nd UDP device(set up as Air Temperature, the first option), and it IS working/ updating... so just not sure why the original one has stopped...
I did re-start the plugin and that didn't work. and then I restarted the computer Indigo is running on, and that didn't help either..
Fri Dec 11, 2020 7:36 am
boisy offline
Hi Bruce,
I couldn't find a forum that has your plug-ins, so I'll post here.
Line 546 in your WeatherFlow plugin.py:
Change:
        except:
to:
[code]
except Exception as e:
[\code]
to prevent an error in the Indigo logs.
Fri Dec 11, 2020 8:16 am
tazswe offline
I suggest that you post your suggestions on GitHub https://github.com/bpennypacker/Weather ... gin/issues
Bruce is not very active on this forum.
