Insteon Health Test Tool app now available
Mon Jun 30, 2014 10:25 pm
Re: Insteon Health Test Tool app now available
just FYI:
my PowerLinc 2413U modem connection died (at the bottom of the indigo main windows the insteon part was red ) while the survey was running.
did a indigo server shutdown
a modem power recycle
and a mac server recycle
after the second power recycle things came back..
Tue Jul 01, 2014 3:30 am
bschollnick2 offline
kw123 wrote:
using latest indigo 6.0.13,
got the following error.
 Starting plugin "Survey Plugin 2.20" (pid 8149)
  Started plugin "Survey Plugin 2.20"
  Survey Plugin                   1 Pass Survey Requested....
  Survey Plugin                   Survey Pass - 1
  Error                           resending previous command (reply mismatch)
Jun 30, 2014, 9:59:53 PM
  Survey Plugin                      LampLink ?? Timed-Out, No Reply Received
  Survey Plugin                      outsideGarageLights Timed-Out, No Reply Received
  Survey Plugin                      pool temp io linc Timed-Out, No Reply Received
  Survey Plugin                      spare micro Timed-Out, No Reply Received
  Survey Plugin Error             Error in plugin execution MenuAction:
  File "plugin.py", line 321, in survey_1pass_manualUpdate
  File "plugin.py", line 263, in gather_data
<type 'exceptions.ValueError'>: IllegalParameterError -- plugin does not define method sendDevicePing
Strange. I'll take a look at it tonight, and see if I can diagnose it.
for v5 - http://bit.ly/T6WBKu
Tue Jul 01, 2014 3:41 pm
kw123 wrote:
just FYI:
Weird, there's nothing that the survey plugin can do that would cause this, to my knowledge. All I am doing is telling Indigo to ping the device, and getting the results back.
If you could keep an eye on this..
Tue Jul 01, 2014 3:51 pm
Okay, I don't see anything that can cause this?
Can you contact me at Benjamin AT schollnick DOT net, and I'll send you an updated version with some optional debugging code?
- Ben
Tue Jul 01, 2014 6:10 pm
That error can occur if you try to call the ping method on a plugin device. See the example code I posted earlier in this thread on how you should find which devices to ping.
Tue Jul 01, 2014 6:28 pm
:? I don't see any code in your example, that is explicitly eliminating plugins, although conversely you are calling just the Zwave and Insteon devices, which could have that side effect.
But what plugins support a StatusRequest? I'm checking explicitly to see that the device supports the " supportsStatusRequest " boolean?
I'll look at this again, I just was trying to prevent having to call the Insteon and ZWave devices in separate loops. That would cause duplicate code, and seemed inefficient.
- Benjamin
Tue Jul 01, 2014 6:48 pm
Exactly.
Any plugin device that the developer has configured to support a status request.
So then look at the protocol property of the device to see if it's Zwave or Insteon (defined as a indigo.kProtocol) as well as supportsStatusRequest.
Thu Jul 03, 2014 7:47 am
Okay, with this in mind, I have made some changes.
https://dl.dropboxusercontent.com/u/241 ... 0v2.21.zip
v2.21 (2014-07-03)
* Fixed issue where pinging a Plugin device could cause a problem with the HA Interface.
* Fixed ZWave survey bug
* Added code to deal with Zwave subdevices
v2.20 (2014-06-30)
* Fixed percentage errors with Fanlincs
* First version to support ZWave devices
2.10 (2014-06-27)
* Switched to using the Ping results from Indigo’s API. This should be more accurate and dependable.
* Switched to API v1.16 Ping Command
* v2.10 REQUIRES Indigo v6.0.13 or higher, due to the dependency on API v1.16.
* Using Indigo API V1.16’s Ping command, so we can now test Insteon and Z-Wave (Pending) devices in a cross-platform manner.
* Started to update to PEP 8 standards
* v2.10 now uses the WaitUntilIdle Server command, so this should help prevent any stalls from other requests from Indigo.
* Due to the switch to Indigo’s results, I am switching the timings to Milliseconds, instead of seconds.
Thu Jul 03, 2014 8:40 am
So did you go with filtering on kProtocol?
Thu Jul 03, 2014 9:05 am
no more error message, output looks good also for z-wave
POTENTIAL ISSUE:
- the poolPump when off (no schedule / trigger to do this in indigo). It is an insteon 30A Load Controller for 220Volt
- does not display z-wave repeaters, may be they do not answer.
Jul 3, 2014, 9:56:22 AM
Stopping plugin "Survey Plugin" (pid 536)
Stopped plugin "Survey Plugin"
Upgrading plugin "Survey Plugin" to newer version 2.21 (previous version moved to trash)
Loading plugin "Survey Plugin 2.21"
Starting plugin "Survey Plugin 2.21" (pid 57481)
Started plugin "Survey Plugin 2.21"
Jul 3, 2014, 9:56:43 AM
Received INSTEON "poolPump" off (button 2)
Survey Plugin imeter1 Timed-Out, No Reply Received
Received INSTEON "poolPump" on (button 2)
Survey Plugin spare not connected Timed-Out, No Reply Received
Survey Plugin Total Successes - 67
Survey Plugin Total Failures - 5
Survey Plugin Done processing devices
[edit]: running it again, poolPump stayed on... looks fine
only Open issue from my side: z-wave repeaters do not show
This is a great tool thanks so much
Thu Jul 03, 2014 11:24 am
running it again, poolPump goes wild!
Jul 3, 2014, 12:15:37 PM
  Survey Plugin                   3 Pass Survey Requested....
  Survey Plugin                   Survey Pass - 2
  Survey Plugin                   Survey Pass - 3
  Survey Plugin                      outsideGaragePoolOutlet Timed-Out, No Reply Received
  Survey Plugin                   Total Successes - 203
  Survey Plugin                   Total Failures - 13
actually the poolPump seems a bit nervous it goes on and off during the test. could this be a signal issue?
Tthe response time looks good, see attached screen-shot
There is another device (same type) next to the poolPump and that does not give any issues. poolPump has tiny bit better response time (250mSec vs 260mSec.)
the poolHeater has a newer firmware.
Screen Shot 2014-07-03 at 12.22.27 PM.png (26.11 KiB) Viewed 5022 times
Screen Shot 2014-07-03 at 12.19.34 PM.png (41.78 KiB) Viewed 5022 times
Thu Jul 03, 2014 11:32 am
Yes. If I hadn't, I would have had to duplicate the loop, and several tests. It was jus the simplest way to do this, without having to re-engineer the core logic.
Thu Jul 03, 2014 11:35 am
I am unaware of any reason that the survey tool could do anything that would cause this.
But my first thought is, do you have any Triggers that affect the pool pump? If you disable them, does that change the behavior?
I haven't noticed anything here when testing.
Thu Jul 03, 2014 12:34 pm
yes, I have a schedule at noon to switch poolPump off and on at 7pm, --- switched that one off , same result and it is only ONE specific device.
I tend to assume it is the device.
it is actually really bad to switch this motor on and off frequently.
Jul 3, 2014, 1:29:43 PM
  Sent INSTEON                    "poolHeater" off
Thu Jul 03, 2014 2:18 pm
Matt, and Jay,
I'm stumped here? Is there anyway that sending a ping command could cause a device to randomly turn on and off?
- Ben
