The Radio Thermostat plugin proof of concept (question)
Sat Aug 22, 2015 11:54 pm
jeffgtx offline
i know this what proof of concept that lacked official support, but i was using it and have now found that the devices in it are uneditable.
did something break with the newer versions of indigo?
specifically when i go to edit the device configuration, the ip address and such are greyed out and the device type has nothing listed. my thermostats moved IP addresses for some reason and i need to update them in indigo.
I can't add new ones because it won't let me select a device type.
anything can do?
Sun Aug 23, 2015 10:05 am
Re: The Radio Thermostat plugin proof of concept (question)
Sounds like the plugin is disabled. Make sure it's enabled (if it is, the reload it). Watch the Event Log for errors.
Sun Aug 23, 2015 7:50 pm
jeffgtx offline
sorry, i used the wrong field name.
after hitting edit device settings, the field for thermostat says select an item, but there are no items.
here is the event log after reload
Aug 23, 2015 6:47:23 PM
Error XML Parse Error: not well-formed (invalid token)
Error On character 77 of line number 21.
Reloading plugin "Radio Thermostat 0.5.1"
Stopping plugin "Radio Thermostat 0.5.1" (pid 4035)
Stopped plugin "Radio Thermostat 0.5.1"
Starting plugin "Radio Thermostat 0.5.1" (pid 40480)
Started plugin "Radio Thermostat 0.5.1"
Radio Thermostat Building available thermostat list - this could take several seconds...
Radio Thermostat Number of thermostats found: 1
Mon Aug 24, 2015 8:21 am
I'm not sure I'm following you (I haven't looked at that plugin for years and unfortunately I don't currently have a thermostat to test with). Can you take some screenshots of what you're seeing?
Mon Aug 24, 2015 11:46 pm
jeffgtx offline
sure. in this pop up after you create or edit a thermostat that is 3M filtrate, the select an item does to have any items to select and the fields below cannot be edited.
Untitled.tiff
Untitled.tiff (42.65 KiB) Viewed 6416 times
Tue Aug 25, 2015 1:12 pm
In the plugin's config dialog, enable debugging, then restart the plugin. Copy/paste in the debug lines that show up in the Event Log window when the plugin starts up and when you try to add a new device.
Tue Aug 25, 2015 3:41 pm
jeffgtx offline
here it is. i put xx in the things i figured i didn't want on the internet. thanks.
Radio Thermostat Debug logging enabled
Stopping plugin "Radio Thermostat 0.5.1" (pid 40480)
Radio Thermostat Debug shutdown called
Starting plugin "Radio Thermostat 0.5.1" (pid 92752)
Radio Thermostat Debug startup called
Radio Thermostat Debug Building Available Device List
Radio Thermostat Debug Getting service query responses
Radio Thermostat Debug Processing replies
Radio Thermostat Debug Processing thermostat at: http://192.168.2.xx/sys/
Radio Thermostat Debug Getting mode of thermostat at: http://192.168.2.xx/sys/
Radio Thermostat Debug Getting service list of thermostat at: http://192.168.2.xx/sys/
Radio Thermostat Debug Getting model of thermostat at: http://192.168.2.xx/tstat/model/
Radio Thermostat Debug Getting details of thermostat at: http://192.168.2.xx/sys/
Radio Thermostat Debug UUID: xx
Radio Thermostat Debug Name: xx
Radio Thermostat xx (uuid: xx)
Radio Thermostat Debug finished startup
Tue Aug 25, 2015 4:42 pm
Hmmm - unfortunately, I can't see why the one it's finding isn't showing up in the list. I don't have one to test with handy, so unfortunately I'm not sure I can help much more.
What happens when you select Plugins->Radio Thermostat->Rescan for Thermostats?
Tue Aug 25, 2015 5:33 pm
jeffgtx offline
after i click rescan it is the same as the bottom of the log i posted above. it find one device and posts its uuid number etc.
something else in the event log:
Radio Thermostat Error Error in plugin execution GetUiDynamicList:
File "plugin.py", line 478, in thermostatList
<type 'exceptions.KeyError'>: key uuid not found in dict
Tue Aug 25, 2015 5:53 pm
jeffgtx offline
Forgot to mention that I went ahead and deleted my existing thermostat devices just in case that was the problem, but no change.
Wed Aug 26, 2015 12:59 pm
Oh, well, that's much more useful. Unfortunately, I can't get back to this until the middle of next week as I'm going out of town. I'll look at it more then.
Wed Sep 02, 2015 11:07 am
Send an email referencing this post to support@indigodomo.com - I may have a patch that will fix your problem.
Wed Sep 02, 2015 1:09 pm
jeffgtx offline
Cool. Email sent.
