So I'm moving Indigo to BigSur, and am trying to install OSC, but running Into problems. I'm guessing part of the problem is the ZSH shell in Big Sur but did find a way to change it back to bash. that was easy enough, but the
Or just install Xcode and see if that does it. But you need to actually run the app after installing it to get it to install some of the command line components.
