Page 4 of 5
Re: iMessage/Messages/Siri Indigo Control Script
Posted:
Wed Jan 14, 2015 9:07 am
by MaartenT
GlennNZ wrote:http://forums.indigodomo.com/viewtopic.php?f=4&t=2927&start=15
Probably posted in the wrong older forum. But above is my modification of the first script for Yosemite that acts on received messages via iMessage and enables execution of action groups etc. Have updated it since this post enabling two way communication which is quite handy - ie. After an hours absence indigo sends a imessage listing on devices and asking if I want to turn them off - a yes reply turns them all off. Happy to post that - but a few triggers and variables with that one - if interested.
There appears to be a Yosemite issue with apple scripting which I though I had but appeared to be changes in Yosemite to imessaging given lack of defined alerts etc - anyhow the above script is for Yosemite and works really well so far.
Glenn
Thank you Glenn. I'll try to get this one working.
Posted:
Mon Jan 19, 2015 3:56 pm
by Alphaman
I've been working on this for a while, too, and think I must concur. My troubleshooting indicates that the -1708 error code indicates a missing handler. There's a nice list of handlers required by Messages in the Messages Dictionary. You
must have a handler for each one of those, for example:
- Code: Select all
on av chat started
end av chat started
...even if your code doesn't use AV Chat, that instance
must be handled. When I went through and added all those various handlers, things started working again for this script.
It should be noted that the other sample scripts in the Messages Script folder aren't complete -- not even the iTunes script that this piece of code was built from. Running the iTunes script generated the same -1708 error we've been seeing here for me.
So, it seems to be not so much an issue of Yosemite being broken, but more strict about having all the handlers it needs than it used to be with Mavericks and earlier. I wonder if this is documented on the Developers' site -- I've not had a chance to go digging through that yet...
Posted:
Mon Jan 19, 2015 4:45 pm
by GlennNZ
I believe you are quite right.
The link below
http://forums.indigodomo.com/viewtopic.php?f=4&t=2927- has all the handlers added - which is the main reason it works for Yosemite. There were also issues with different handlers if chat window open, closed, buddy selected etc.
Glenn
Posted:
Sat Jan 24, 2015 8:20 am
by Seeker
confused.
does this work with yosemite?
I don't have a...
Put the script in the Library/Scripts/Messages folder in your user directory
...so where do i put this?
Posted:
Sat Jan 24, 2015 1:16 pm
by GlennNZ
The link I posted above is working well in my Yosemite setup
Go to messages, preferences, script handlers, open directory and put it with all the others. Select it, change the buddy handle to allowed and away you go
Glenn
Posted:
Sat Jan 24, 2015 7:30 pm
by Seeker
Thanks, found that.
Now, regarding
4. Create a new Apple ID with a new or otherwise unused email address and enable it in Messages.
does this really mean a new apple ID? or just an alias email account on my main ID?
Posted:
Sat Jan 24, 2015 8:28 pm
by GlennNZ
Basically you need to be able to send iMessages from the indigo server (so need an account to do that) and this needs to be a seperate account.
My setup is with a standalone server - so I did create a appleID for the server - signed into imessage with that - can now send iMessages from the server. Need to check that works well before using the script.
Glenn
Posted:
Sun Jan 25, 2015 10:39 am
by Seeker
Thanks Glenn and DVDDave,
I have it working with Yosemite with some basic action groups.
I have a new apple ID for my mini/indigo called 'indigo'. messages to this contact work as expected and control the scenes. But siri keeps trying to text the wrong address. I'll keep poking around with this.
edit, got my contacts straightened out. works great!
Posted:
Sun Jan 25, 2015 12:48 pm
by DVDDave
Cool. Still chugging along for me too.
--Dave
Posted:
Sat Feb 07, 2015 5:41 am
by mrmatt68
Here is what finally worked for me......change name to name of iMessage account name that is sending the message. Name the file Messages Indigo Control.scpt and save in application scripts....easiest way to get there is is messages menu then preferences then apple script handler then open scripts folder and create or place the file in there.
- Code: Select all
File: Messages Indigo Control.scpt
Abstract: This script is based on the iTunes Remote Control script which demonstrates the AppleScript "Message Received" handler for Messages. It will parse incoming messages and control Indigo in response.
Version: .1
using terms from application "Messages"
on replace_chars(this_text, search_string, replacement_string)
set AppleScript's text item delimiters to the search_string
set the item_list to every text item of this_text
set AppleScript's text item delimiters to the replacement_string
set this_text to the item_list as string
set AppleScript's text item delimiters to ""
return this_text
end replace_chars
on CapitalizeFirstLetter_ofEveryWord(InputString)
set TheString to do shell script "echo " & InputString & " | tr '[A-Z]' '[a-z]'"
set wordsofTheString to words of TheString as list
set TotalCount to count of wordsofTheString
set theCount to 1
repeat until theCount is greater than TotalCount
set theWord to item theCount of wordsofTheString
set theChars to characters of theWord as list
set Capital to item 1 of theChars
set item 1 of theChars to do shell script "echo " & Capital & " | tr '[a-z]' '[A-Z]'"
if theCount is less than TotalCount then
set theWord to (theChars as string) & " "
else
end if
set item theCount of wordsofTheString to theWord
set theCount to theCount + 1
end repeat
set TheString to wordsofTheString as string
return TheString
end CapitalizeFirstLetter_ofEveryWord
on trim_line(this_text, trim_chars, trim_indicator)
-- 0 = beginning, 1 = end, 2 = both
set x to the length of the trim_chars
-- TRIM BEGINNING
if the trim_indicator is in {0, 2} then
repeat while this_text begins with the trim_chars
try
set this_text to characters (x + 1) thru -1 of this_text as string
on error
-- the text contains nothing but the trim characters
return ""
end try
end repeat
end if
-- TRIM ENDING
if the trim_indicator is in {1, 2} then
repeat while this_text ends with the trim_chars
try
set this_text to characters 1 thru -(x + 1) of this_text as string
on error
return ""
end try
end repeat
end if
return this_text
end trim_line
on getIndigoVariable(IndigoVariable)
set theVariableValue to get value of variable IndigoVariable
end tell
return theVariableValue
end getIndigoVariable
on setIndigoVariable(IndigoVariable, VariableValue)
set value of variable IndigoVariable to VariableValue
end tell
return "Variable set to " & theVariableValue
end setIndigoVariable
on executeIndigoAction(IndigoAction)
execute group IndigoAction
end tell
return "Action " & IndigoAction & " Executed"
end executeIndigoAction
on turnonIndigoDevice(IndigoDevice)
try
turn on IndigoDevice
end tell
return IndigoDevice & " was told to turn on"
on error
return "error turning on " & IndigoDevice
end try
end turnonIndigoDevice
on turnoffIndigoDevice(IndigoDevice)
try
turn off IndigoDevice
end tell
return IndigoDevice & " was told to turn off"
on error
return "error turning off " & IndigoDevice
end try
end turnoffIndigoDevice
-- handler to respond to all incoming messages.
on runIndigoRemoteControl(theMessage)
try
-- use default "unknown" command, just in case.
set theResponse to "Unknown command."
set theMessage to trim_line(theMessage, "to ", 0)
set theMessage to replace_chars(theMessage, "the ", "")
if theMessage contains "status" then
set theResponse to "Alive and Well!"
else if theMessage is "arm alarm" then
set theResponse to setIndigoVariable("AlarmArmed", "true")
else if theMessage is "disarm alarm" then
set theResponse to setIndigoVariable("AlarmArmed", "false")
else if theMessage contains "raise heat" or theMessage contains "lower AC" or theMessage contains "raise temperature" then
set theResponse to executeIndigoAction("Thermostat Higher")
else if theMessage contains "lower heat" or theMessage contains "raise AC" or theMessage contains "lower temperature" then
set theResponse to executeIndigoAction("Thermostat Lower")
else if theMessage starts with "turn on" then
set targetDevice to CapitalizeFirstLetter_ofEveryWord(trim_line(theMessage, "turn on ", 0))
set theResponse to turnonIndigoDevice(targetDevice)
else if theMessage starts with "turn off" then
set targetDevice to CapitalizeFirstLetter_ofEveryWord(trim_line(theMessage, "turn off ", 0))
set theResponse to turnoffIndigoDevice(targetDevice)
else if theMessage starts with "execute" then
set targetAction to trim_line(theMessage, "execute ", 0)
set targetAction to trim_line(targetAction, "action ", 0)
set targetAction to trim_line(targetAction, "group ", 0)
set targetAction to CapitalizeFirstLetter_ofEveryWord(targetAction)
set theResponse to executeIndigoAction(targetAction)
else if theMessage is "help" then
-- display available commands on "help"
set theResponse to "Available commands: status, Turn on or off device, Raise or lower temperature, Arm or disarm alarm, Execute action"
end if
return theResponse
on error
return "Error processing message " & theMessage
end try
end runIndigoRemoteControl
-- When first message is received, accept the invitation and send a greeting message from iTunes Remote Control.
on received text invitation theMessage from theBuddy for theChat
if full name of theBuddy is "Matthew A. Morgano" or full name of theBuddy is "Matthew A. Morgano" then
accept theChat
end if
send "Welcome to Indigo Remote Control. " & runIndigoRemoteControl("help") to theChat
end received text invitation
-- On subsequent messages, pass the message directly to iTunes Remote Control.
on message received theMessage from theBuddy for theChat
if full name of theBuddy is "Change Name here" or full name of theBuddy is "Change Name Here" then
set theResponse to runIndigoRemoteControl(theMessage)
-- send back the response.
send theResponse to theChat
end if
end message received
--locally test commands
display dialog "Send a command to Indigo Remote Control:" default answer "status"
set theMessage to the text returned of the result
display dialog theResponse
# The following are unused but need to be defined to avoid an error
on received audio invitation theText from theBuddy for theChat
end received audio invitation
on received video invitation theText from theBuddy for theChat
end received video invitation
on received remote screen sharing invitation from theBuddy for theChat
end received remote screen sharing invitation
on received local screen sharing invitation from theBuddy for theChat
end received local screen sharing invitation
on received file transfer invitation theFileTransfer
end received file transfer invitation
on buddy authorization requested theRequest
end buddy authorization requested
on message sent theMessage for theChat
end message sent
on chat room message received theMessage from theBuddy for theChat
end chat room message received
on active chat message received theMessage
end active chat message received
on addressed chat room message received theMessage from theBuddy for theChat
end addressed chat room message received
on addressed message received theMessage from theBuddy for theChat
end addressed message received
on av chat started
end av chat started
on av chat ended
end av chat ended
on login finished for theService
end login finished
on logout finished for theService
end logout finished
on buddy became available theBuddy
end buddy became available
on buddy became unavailable theBuddy
end buddy became unavailable
on completed file transfer
end completed file transfer
end using terms from
Posted:
Sun Feb 22, 2015 8:11 am
by mrmatt68
Hi again,
I can get this working but only if i leave the preferences window open and applescript handler set to indigo control.....as soon as i close the window iMessage no longer works.....do i have to set that script a different way so that it'll be permanent? it always defaults to none no matter what script i choose. Do I have it in the wrong folder?
Matt
Posted:
Sun Feb 22, 2015 9:45 am
by DVDDave
Hi Matt,
What you are doing should work. When you bring up preferences after closing it, is the script still selected? If not, maybe try repairing disk permissions or trashing the Messages pref file.
--Dave
Posted:
Mon Mar 30, 2015 3:20 pm
by Alain
Trying to get this very cool system going...
I'm not able to get incoming messages to have Indigo react.
I have been able to get the script to "stick" in the preferences pane (applescript handler).
If I run the script within the script editor and give it a command, I can turn on a device in Indigo.
But if I send a message with the same command, nothing happens (I see it in the Messages app, but it seems like the script is not kicking in).
I have placed the file according to the instructions (located via the preferences dialog).
Anything I should try?
Thank you
Alain
Posted:
Sat Apr 18, 2015 1:30 pm
by noel1983
Hi all,
Really keen to get this working however i'm stuck at the script stage never mind the iMessage bit. I've downloaded the latest script (I think) from above in this thread. opening it in script editor and running it I'm trying status, that works and responds alive and well.
If I run and type 'turn on bed' then I get 'error turning on bed'
I'm sure i've had this working before but then came across the errors everyones mentioned so parked it for a while and have come back to find the updated scripts.
I've confirmed that a standalone applescript can turn on bed ok but not the Messages Indigo Control Script sample.scpt file I have.
Any suggestions please?
Noel
Posted:
Sun Apr 26, 2015 4:54 am
by mrmatt68
Mine will work sometimes and sometimes not and i don't understand why. I wish i could help more because it is nice when it works. I wish indigo would build this functionality in or at least develop the plugin further.
Matt
