try to reload a plugin
Sun Jun 03, 2018 4:43 am
koburg offline
HI all
I try to make a action group to execute this python script
plugin = indigo.server.getPlugin("com.ssi.indigoplugin.Sonos.indiPref")
if plugin.isEnabled():
   plugin.restart()
but nothing seem to happen when execute no info in the log about reloading or errors ?
Sun Jun 03, 2018 5:15 am
Re: try to reload a plugin
The identifier for the Sonos plugin is "com.ssi.indigoplugin.Sonos".
"com.ssi.indigoplugin.Sonos.indiPref" is the name of the preferences file.
Sun Jun 03, 2018 5:16 am
koburg offline
Ok thanks but why do the log not show any errors ?
Sun Jun 03, 2018 11:02 am
The call to retrieve a plugin always succeeds, even if the plugin isn't installed (or doesn't exist). Indigo has no way to know if a given pluginID is invalid or if that plugin just isn't installed. This is documented (but probably not clear enough) here, "This will always return to you a plugin object."
The plugin object is returned with a display name that says it isn't installed. If after getting the plugin you add this line to the script:
indigo.server.log("plugin returned:\n" + unicode(plugin))
You will see this in the Event Log window:
   Script                          plugin returned:
pluginDisplayName : - plugin not installed -
pluginId : com.ssi.indigoplugin.Sonos.indiPref
pluginSupportURL :
pluginVersion :
The isEnabled() method returns False for that placeholder plugin, so the restart in your script is never executed.
