FYI, Husqvarna has published their official Automower API at
https://developer.1689.cloud It's a reasonably simple API. You have to register as a developer and then generate an Authorization Token. I did that with an Action Group. I didn't bother parsing the JSON and just copied the token over.
- Code: Select all
import requests
grant_type = 'password'
client_id = '<YourHusqvarnaDeveloperAppID>'
username = '<YourHusqvarnaAppUserName>'
password = '<YourHusqvarnaAppPassword>'
post_url = 'https://api.authentication.husqvarnagroup.dev/v1/oauth2/token'
payload = {
'grant_type': grant_type,
'client_id': client_id,
'username': username,
'password': password,
r = requests.post(post_url, data = payload)
indigo.server.log(str(r.text))
From there, it was straightforward to use GhostXML to pull the mower status. Only 10K calls a month are allowed, so don't poll more than once every five minutes. Here's the raw cURL needed. First is to get mower list (run once). Second to get Mower status.
- Code: Select all
https://api.amc.husqvarna.dev/v1/mowers
-X GET \
-H "accept: application/vnd.api+json" \
-H "X-Api-Key: < YourHusqvarnaDeveloperAppID>" \
-H "Authorization: Bearer <YourHusqvarnaTokenFromStep1>" \
-H "Authorization-Provider: husqvarna"
NOTE: data_0_id yields the MowerID
- Code: Select all
url: https://api.amc.husqvarna.dev/v1/mowers/<YourMowerFromMowerList>
-X GET \
-H "Authorization: Bearer <YourHusqvarnaTokenFrom Step1>" \
Finally, I created two action groups to allow me to park the mower and resume schedule. I created triggers to park the mower when the sprinklers are running and in case of rain.
- Code: Select all
# Park Until Further Notice
import requests
mower = (indigo.variables['husqvarnaMower'].value)
authorization = (indigo.variables['husqvarnaAuthorization'].value)
apikey = (indigo.variables['husqvarnaAPIKey'].value)
post_url = 'https://api.amc.husqvarna.dev/v1/mowers/' + mower + '/actions'
head = {
'accept': '*/*',
'X-Api-Key': apikey,
'Authorization': authorization,
'Authorization-Provider': 'husqvarna',
'Content-Type': 'application/vnd.api+json',
payload = '{"data":{"type":"ParkUntilFurtherNotice"}}'
r = requests.post(post_url, headers = head, data = payload)
if str(r.status_code) == '202':
indigo.server.log('Husqvarna Parked Until Further Notice')
indigo.variable.updateValue('husqvarnaParked', value=str('true'))
- Code: Select all
# Resume Schedule
import requests
head = {
'accept': '*/*',
payload = '{"data":{"type":"ResumeSchedule"}}'
indigo.server.log('Husqvarna Resume Schedule')
indigo.variable.updateValue('husqvarnaParked', value=str('false'))
I have triggers that run from the GhostXML device and update based on changes to certain variables, in particular data_attributes_mower_errorCode. Just to save you some time, this converts the numeric error codes into their text equivalent:
- Code: Select all
husqvarnaError = str(indigo.variables[1384099050].value) # "husqvarnaErrorCode"
dict = {
'0': 'Unexpected error',
'1': 'Outside working area',
'2': 'No loop signal',
'3': 'Wrong loop signal',
'4': 'Loop sensor problem, front',
'5': 'Loop sensor problem, rear',
'6': 'Loop sensor problem, left',
'7': 'Loop sensor problem, right',
'8': 'Wrong PIN code',
'9': 'Trapped',
'10': 'Upside down',
'11': 'Low battery',
'12': 'Empty battery',
'13': 'No drive',
'14': 'Mower lifted',
'15': 'Lifted',
'16': 'Stuck in charging station',
'17': 'Charging station blocked',
'18': 'Collision sensor problem, rear',
'19': 'Collision sensor problem, front',
'20': 'Wheel motor blocked, right',
'21': 'Wheel motor blocked, left',
'22': 'Wheel drive problem, right',
'23': 'Wheel drive problem, left',
'24': 'Cutting system blocked',
'25': 'Cutting system blocked',
'26': 'Invalid sub-device combination',
'27': 'Settings restored',
'28': 'Memory circuit problem',
'29': 'Slope too steep',
'30': 'Charging system problem',
'31': 'STOP button problem',
'32': 'Tilt sensor problem',
'33': 'Mower tilted',
'34': 'Cutting stopped - slope too steep',
'35': 'Wheel motor overloaded, right',
'36': 'Wheel motor overloaded, left',
'37': 'Charging current too high',
'38': 'Electronic problem',
'39': 'Cutting motor problem',
'40': 'Limited cutting height range',
'41': 'Unexpected cutting height adj',
'42': 'Limited cutting height range',
'43': 'Cutting height problem, drive',
'44': 'Cutting height problem, curr',
'45': 'Cutting height problem, dir',
'46': 'Cutting height blocked',
'47': 'Cutting height problem',
'48': 'No response from charger',
'49': 'Ultrasonic problem',
'50': 'Guide 1 not found',
'51': 'Guide 2 not found',
'52': 'Guide 3 not found',
'53': 'GPS navigation problem',
'54': 'Weak GPS signal',
'55': 'Difficult finding home',
'56': 'Guide calibration accomplished',
'57': 'Guide calibration failed',
'58': 'Temporary battery problem',
'59': 'Temporary battery problem',
'60': 'Temporary battery problem',
'61': 'Temporary battery problem',
'62': 'Temporary battery problem',
'63': 'Temporary battery problem',
'64': 'Temporary battery problem',
'65': 'Temporary battery problem',
'66': 'Battery problem',
'67': 'Battery problem',
'68': 'Temporary battery problem',
'69': 'Alarm! Mower switched off',
'70': 'Alarm! Mower stopped',
'71': 'Alarm! Mower lifted',
'72': 'Alarm! Mower tilted',
'73': 'Alarm! Mower in motion',
'74': 'Alarm! Outside geofence',
'75': 'Connection changed',
'76': 'Connection NOT changed',
'77': 'Com board not available',
'78': 'Slipped - Mower has Slipped.Situation not solved with moving pattern',
'79': 'Invalid battery combination - Invalid combination of different battery types.',
'80': 'Cutting system imbalance Warning',
'81': 'Safety function faulty',
'82': 'Wheel motor blocked, rear right',
'83': 'Wheel motor blocked, rear left',
'84': 'Wheel drive problem, rear right',
'85': 'Wheel drive problem, rear left',
'86': 'Wheel motor overloaded, rear right',
'87': 'Wheel motor overloaded, rear left',
'88': 'Angular sensor problem',
'89': 'Invalid system configuration',
'90': 'No power in charging station',
dict[husqvarnaError]
indigo.server.log(str(dict[husqvarnaError]))
indigo.variable.updateValue('husqvarnaErrorCodeText', value=str(dict[husqvarnaError]))
If I'm not the only person using one of these mowers, it seems easy enough to turn into a plugin.
