Controlling the iKettle
Thu Jun 07, 2018 4:00 pm
steinis offline
Re: Controlling the iKettle
has someone tried to control the Ikettle 3.0? No contact when I try port 2000/2081
Thu Jun 07, 2018 4:51 pm
The iKettle 2.0 worked differently to the 1, so I’d image the 3.0 is the same. If it works the same way as the iKettle 2 then you might be able to use the cynical network plugin and the information listed here for hex commands to work (it worked for me quite well until I ditched it for a AppKettle). Or the easier route.. setup iFTTT and setup indigo to send an email to trigger a command there to turn it on. Not that I approve of having to use the cloud for something that should be a local event.
