script for flashing
Sat Oct 10, 2020 8:35 pm
Gangotti offline
script for flashing
Does anyone have an easy way to make a light device flash in and off? Basically, I have a leak detector in the laundry room and if it goes off I want it to turn the lights on and off till I either press the light switch panel or the sensor turns off because it is dry. Thoughts?
Sun Oct 11, 2020 10:31 am
Re: script for flashing
You can do it without a script by just creating a schedule that runs every 30 seconds that turns the light on and an auto-off of 15 seconds (or whatever timing you want). You can then enable/disable the schedule as necessary from any kind of triggering event.
Mon Oct 19, 2020 12:14 pm
Gangotti offline
Thanks Jay, I forgot about all the functionality of the scheduler!
