Looking at these
http://www.sensor.co.uk/switches/bathro ... 0wodrBYIVg
Hate the standard bathroom pull cord but understand for safety must be used .
Anyone got these or similar and linked them up to indigo somehow ??
Cheers
howartp wrote:Yes, if your hands are wet you might electrocute yourself.
DaveL17 wrote:howartp wrote:Yes, if your hands are wet you might electrocute yourself.
Huh. Who turns the light on AFTER washing their hands?
DaveL17 wrote:but our switches are conventional.
In the US, we're required to have ground-fault interruptor outlets when they're placed near water sources (primarily bathrooms and kitchens but also laundry, etc.) but our switches are conventional. Not sure what the rationale is as to why we don't simply GFI the whole room.
RogueProeliator wrote:I think mine were tripping when Terry plugged in his phone to charge in Alabama.
Mayhem wrote:Its also I think because you use 120 volts 60Hz in the US from a centre tapped transformer and you can only get 55/60v between one line and earth. The line to ground voltage is half the line-to-line voltageIn.
In the UK we use 230/240 Volts 50Hz and thats between Live and neutral and Live and ground/earth.
So we need a bit more protection from the possibility of wet haps and faulty switches etc.
Please do correct me if I'm wrong anyone.
