Broadlink RM Pro - Inexpensive IR/RF Integration
Posted: Wed Aug 21, 2019 8:12 pm
virgahyatt wrote:It does have to be an independent Homebridge install. Not the Indigo plugin. You can install one on the same machine as indigo that I have experienced complications with that. If you plan on using the indigo plugin to control the Broadlink in the end, then you only need the extra Homebridge to get the codes. Once you're done you can remove it.
Thank you for clarifying! Saved me some time and angst. I have more raspi’s i care to admit... one of them can get a new assignment
Edit: more importantly, I suspect there are certain RF codes that are both common and desirable- curious what they turn out to be!
