Page 1 of 3
Sonoff WIFI smart switch - uses ESP8266
PostPosted: Fri Oct 07, 2016 6:22 am
by roussell
I ran across this and thought I'd share. It's an inline mains-level relay controlled by an ESP8266. Best of all, it's pre-built/packaged and less than $5.00 USD each! By default it communicates with "the cloud" but it's very easy to load your own Arduino sketch on, the examples below have it doing pub/sub with MQTT. Here's the device, there are several versions available on the website, including ones with temp/humidity, or dual relays, this is a photo and link to the single relay:
https://www.itead.cc/sonoff-wifi-wireless-switch.html
Here is the original youtube video I ran across describing, and hacking it:
https://youtu.be/_389pQPLyr8
And here is the youtube guy's website with more info and links to the source he used in the video:
http://www.superhouse.tv/17-home-automation-control-with-sonoff-arduino-openhab-and-mqtt/
I've ordered a couple to play with and will add to this thread when they come in. Interestingly, the ones I ordered mention MQTT in the description, but I don't know if they're already enabled, or just can be, with the alternative firmware loaded. We'll see when they arrive. Happy hacking!
Terry
PostPosted: Fri Oct 07, 2016 11:20 pm
by mclass
But wait ..... there's also the touch switch :
https://www.itead.cc/smart-home/sonoff-touch.html
If the API is "discovered" and/or someone clever comes up with a plug in - how good would that be!!
Or could these work with the fabulous Arduino plug in??
Re: Sonoff WIFI smart switch - uses ESP8266
PostPosted: Sat Oct 08, 2016 5:55 am
by roussell
I saw that, I almost ordered one but decided to wait. It uses the ESP8266 as well so it should be just as easy to modify. I didn't get it because there is no dimming capability and we use that pretty heavily in my house.
PostPosted: Sun Oct 16, 2016 7:09 pm
by elf55
No mention of UL, CSA, or FCC approvals. This is just for playing. Wouldn't recommend installing it in a home. At least not if you ever want to make an insurance claim for a fire.
PostPosted: Tue Feb 28, 2017 11:02 am
by LulaNord
Hi...i am a new user here. As per my knowledge there are a variety of development environments that can be used to program the ESP8266. The ESP8266 community created an add-on for the Arduino IDE that allows you to program the ESP8266 using the Arduino IDE and its programming language.
turnkey assembly
PostPosted: Mon Mar 06, 2017 1:17 pm
by roussell
I see that Sonoff has a cool environmental sensor now - probably gonna have to get one of these. If it's as hackable as the switches, it will be easy to integrate with Indigo. Oh yeh, and it's only $20!
https://www.itead.cc/smart-home/sonoff-sc.html
Terry
PostPosted: Sun Mar 12, 2017 4:47 pm
by mclass
Pleased to report that my Sonoffs have arrived, and have been flashed and integrated into Indigo using Karl's excellent Arduino plug in.
Apart from not having any certifications (see elf55's previous post), these low cost devices have great potential. I am also investigating the use of the Sonoff SV (safe voltage) devices as part of my sprinkler system.
However to be really utilitarian, the next step is to figure out mods to the sketch to:
- Use the LED to indicate progress of the connection to wifi (eg flash until connection succeeds)
- Use the push button to provide local (manual) control of the Sonoff in the event of wifi and/or Indigo being unavailable
- Use the LED to indicate status of the relay (on/off)
Any assistance/advice in achieving these mods would be appreciated!
Mclass
PostPosted: Sun Mar 12, 2017 10:03 pm
by kw123
could you post your current sketch..
and also what are the functions available in the device.. = how are they connected to the ESP? for input and output ..
PostPosted: Mon Mar 13, 2017 6:15 am
by mclass
Hi Karl!
I'm currently using the latest version of your standard sketch, configured for an ESP16, and this works "out of the box"!
The Sonoff is documented in various places as being "hardwired" as follows:
- relay: D12 - GPIO12 (high to turn on)
- LED: D13 - GPIO13 (low to turn on)
- push button: D15- GPIO0 (low when switch is pressed)
I have verified that relay & LED can be operated from your plugin, but unable to verify the button - the plugin does not permit the use of D15? May need some further investigation.
I understand that other pins may be available (with varying degrees of difficulty?) including the analog pin.
If you're really keen, I'd be happy to send you a Sonoff (with flash headers already installed) so you can try one out - they're about $A12 each
PostPosted: Mon Mar 13, 2017 7:14 am
by kw123
I never got anything from down under in the mail. That would be cool.
As for the d15 .. there are different mappings for the ESP. I need to check the code if that is blocked.
I could just remove the ignore pin line.
PostPosted: Mon Mar 13, 2017 5:25 pm
by mclass
Thanks, Karl! I note you've issued a revised sketch addressing the button pin, so will give it a whirl when (if) I get time. It was a holiday weekend just gone that gave me a little spare time to play.
Happy to send you a "reward" for your great work - PM me your postal address and I'll oblige. Pretty circuitous route for a Sonoff from China, eh??
PostPosted: Sun Mar 19, 2017 7:13 pm
by mclass
Thanks, Karl - your new version of the Arduino plugin and sketch now allows accessing the push button on the Sonoff (D0).
I guess I now need to brush up on my Arduino "sketching" to add push button operation to the section "do my stuff". Any hints appreciated.
BTW, Karl, that Sonoff's still available if you want to have a go!!
PostPosted: Thu Jun 14, 2018 11:13 pm
by anothersphere
These things seem very cool. I have some usage for them in outside areas (obviously in an IP rated box) to do stuff like turn on lighting/pumps etc, where blowing up/bursting into flames is not going to smoke my house.
Google found me this: http://supersimo88.altervista.org/hacki ... utomotion/ which I am keen to try as it seems to be a nice way to move forward to what looks like a UI served by the device. Now if we can curl the URL's off that GUI then that opens up some simple Indigo functionality. When I get home I am going to surf to dx.com to get me some bits and pieces to experiment to see if I can make this happen. It needs a USB adapter, header pins and a soldering iron to flash it - should be easy once one is done. I am hoping I can get the low voltage Sonoff module to flash the same way coz that is very interesting to me for some low voltage needs I have.
Has anyone already tried this? I will post my progress.
PostPosted: Fri Jun 15, 2018 1:37 am
by racarter
I have a couple of these, and the 4-channel low voltage device too. I flashed them with ESP Easy firmware then added code to a xAP plugin I wrote, to handle the UDP comms on the Indigo side. This requires some configuration on the ESP side to send data in the required format, but once that's done they work well and seem stable. The only downside if you have a lot of them is that they each take up an IP address on your network.
I found a slight issue with the 4-channel device after flashing; when you power it up the relays all fire for half a second or so, so if you had a power cut the connected devices would switch on briefly when the power was restored. The single-channel devices don't exhibit this behaviour.
This was my starting point: http://www.instructables.com/id/Control-Sonoff-From-Raspberry-Pi/
PostPosted: Fri Jun 15, 2018 4:59 am
by mclass
I used Karl’s Arduino plugin with great success. Check out earlier posts in this thread for details!
