wirelesstag.net, wireless sensor tags. anyone try these?
Thu Jul 28, 2016 10:18 am
blysik offline
I'm looking for a good solution to monitor temperature in a few rooms, plus maybe some motion sensors attached to gates. I came across http://wirelesstag.net
The price is good, and they have a very robust set of APIs and sensors.
Anyone try these out? Doesn't look like any mention of them on the boards.
Thanks.
Thu Jul 28, 2016 7:29 pm
Re: wirelesstag.net, wireless sensor tags. anyone try these?
Sat Jul 30, 2016 2:15 pm
ChopOMatic offline
Yeah, I tried them and am somewhat sure my discussion about them is in an old post on here somewhere.
They worked well for a short time and I was excited. Then they started dropping off the network. I contacted the manufacturer and they sent more. Same thing. After that, their advice was something like, "It's not a big deal, just a software thing. All you need to do is disassemble the tag and then remove and reinsert the battery."
Gee, that will be a big comfort when the one on my dog's collar stopped working and I never knew that he dug out of the backyard a few hours ago.
I asked for a refund and they told me to return them. I did so, and they never responded to me again. No refund. No response to my many emails, nothing. They still have my $100+ and I still have nothing.
Sat Jul 30, 2016 5:10 pm
I tried to get some info on their Api No repose yet. Still trying.
Mon Aug 01, 2016 9:19 am
blysik offline
Yeah, I found your old post on them. Sounds no good.
Wed Apr 26, 2017 4:56 pm
Just thought I'd say thanks to those that went before and provided a warning. They really look good from their web site, but the info here waves me off.
Sun Nov 17, 2019 10:01 pm
Accularian offline
Wireless Tags - Let's Revisit This
I just ordered the motion/temperature tag and the receiver unit. It cost me about $50.00 for everything. My goal was to be able to monitor temperature in a Hot Tub.
Ordering was easy, delivery just a bit slow but not unreasonable. I contacted customer support and was able to get a person speaking broken english. He looked up my order and was able to confirm that it would go out the next day. I received numerous shipping updates and was impressed with their automation. This feels like a small startup company but I see that they have been around for awhile so they must be doing something right.
I received the order in a surprisingly small package. The setup was straight forward and simple through my iPhone.
I put the tag into a small water-tight Tupperware style container, tossed it into the hot tub and it has worked flawlessly ever since. I am getting good solid temperature readings (after an easy calibration) and I get a motion notification when the HotTub pump stirs the water when the heating cycle begins. At first, I thought this was a bit silly but have decided it's nice to know the schedule (for heating the spa) I have set up in Indigo is firing perfectly.
My next goal will be to figure out a way for Indigo to poll the tag data. All calls to tags are done through their web server. I don't think there is a way to talk directly to the receiver or the tag... it's all done through their server.
They have some documentation about the API at http://wirelesstag.net/apidoc.html but I don't really know much about AJAX or JSON so I have hit my competency level.
I was able to create a web page and store it on my web site. When I pull the page up I get the the temperature in Fahrenheit and display it on the web page. I will post my code below.
What would be nice is if I could issue a curl command within Indigo to snag that number generated by my web page then add it to a variable. I will be working on that but if you have the JSON/AJAX/CURL chops perhaps you could assist.
I think there is a lot of potential here. Care to dive in?
Wireless Tags can be found at: http://wirelesstag.net
Here is the obscured code from my two PHP pages. I cobbled this together from WirelessTags documentation.
This page presents just the number....
<?php require('HotTubTagTemp.php'); ?>
<div class="TheTemp">
<?php echo $TheTemp;?>
</div>
This is the page on the code which generates the data...
This page is a support page for Indigo Home Automation. It connects Wiresless Tags
temperature info and makes it available when it is called via a CURL command
and places it into a variable on the Rosi Server
<html lang="en">
<head>
   <meta http-equiv="content-type" content="text/html; charset=utf-8">
   <title></title>
   <script src="https://code.jquery.com/jquery-3.3.1.min.js" integrity="sha256-FgpCb/KJQlLNfOu91ta32o/NMZxltwRo8QtmkMRdAu8=" crossorigin="anonymous"></script>
   <script>
   $.ajaxSetup({
   type: "POST",
   contentType: "application/json; charset=utf-8",
   cache: false,
   dataType: "json",
   xhrFields: {
      withCredentials: true
$.ajax({url: "https://my.wirelesstag.net/ethLogShared.asmx/GetLatestTemperatureRawDataByUUID",
        data: JSON.stringify({uuid: "MyUUIDGetsInsertedHere"}),
        success: function (retval, textStatus) {
            $("#displayx").text(((retval.d.temp_degC * 1.8) + 32).toFixed(0));
            $("#datetime").text(retval.d.time);
        error: function (xhr, textStatus, exception) {
            alert(textStatus);
</script>
</head>
<body>
<?php $TheTemp = ('<span id="displayx" style="font-size: 36px;"></span>');
echo $TheTemp;
</body>
</html>
Enjoy,
Dana Haynes
MacHelp Global
http://www.machelpglobal.com
