Setting up Somfy shades
Mon Jan 07, 2019 4:03 pm
rgspb offline
We are getting some new Somfy rollup shades installed and I am trying to figure out how to integrate them with Indigo. I've got the MyLink module that will at very least allow me to connect them to Alexa. What is the best way to connect them to Indigo. From what I've read so far it looks like I need an ADDITIONAL device to plug in to my Mini, but there are no USB ports available. Is there not just a simple plugin that will connect to the MyLink module?
Mon Jan 07, 2019 6:28 pm
jblackburn offline
Re: Setting up Somfy shades
I've few SOmfy and I think the best integration with Indigo is the zWave module ZRTSI:
https://www.somfysystems.com/products/1811265/zwave-to-rts-interface
This is a bridge between RTS and zWave. I think the API for the MyLink is not offcially available!
Joël
Mon Jan 07, 2019 7:06 pm
norcoscia offline
If you have the my link ip interface you can just run a script from indigo and control them... works great
And there is a plug-in too but not sure it is out of beta
_______
Norm
Mon Jan 07, 2019 7:38 pm
norcoscia offline
This is what you do
You can set up a python script in a schedule or action - looks like this (for up) -- just replace the xxx in both auth and targetID with your info. And replace the IP 192.168.1.XX with yours. You don't need the commented out lines.... For the up command just change mylink.move.up to mylink.move.down
use embed python
import telnetlib
payload = '{ "id":1, "method": "mylink.move.up", "params": { "auth": "xxx", "targetID" : "CCxxxxx.1"} }'
tn = telnetlib.Telnet ("192.168.1.XX", "44100")
# Write the JSON payload
tn.write(payload)
# Close the connection
tn.close()
NOTE — You get targetID auth from the SOMFY IOS app - one is under integration and one is under info (tap the hamburger on the top left of the app to see choices) The current system ID (on the integration page) is what goes after auth. The ID (under info ) - is what goes after the target ID. I think you will need to add a .1 to it....
_______
Norm
Mon Jan 07, 2019 10:34 pm
rgspb offline
Wow, I’ve never done any kind of scripting. I’ll see if I can figure that out! As far as the ZWAVE TO RTS INTERFACE that’s really pricey, that will probably be my second choice.
Tue Jan 08, 2019 7:08 am
norcoscia offline
If you need any help just let me know, it is pretty easy and works great! And of course you should assigns a static IP to your MyLink device.
It will look like this.... you put your info in where the orange boxes are.
_______
Norm
Tue Jan 08, 2019 3:52 pm
rgspb offline
Great, thank you!
Tue Feb 12, 2019 1:56 pm
rgspb offline
So I got this working...on one shade. How do I make a script for a different shade? (So far only one motorized has been installed so I've only got that one to play with)
Tue Feb 12, 2019 2:16 pm
norcoscia offline
I only have one awning so not 100% sure - just guessing, maybe the target ID? Glad it is working....
_______
Norm
Tue Feb 12, 2019 3:24 pm
rgspb offline
Thanks, hopefully i'll get the rest of the shades in soon and will be able to explore that. We'll have to see what info pops up once I get more setup! I'll report back.
Tue Feb 12, 2019 3:38 pm
norcoscia offline
Sounds good, seems like it almost has the be the target ID, since the IP is for the Somfy IP bridge and that will not change. It will be interesting to see if the .1 needs to become .2 (for the second shade) or it the rest of the target ID changes when you add a shade.
I just did a FW update to my IP bridge - went fine, I'm on ver 5.17 now....
_______
Norm
Tue Feb 12, 2019 4:21 pm
rgspb offline
Yay, I just figured out how to get the MY position programmed! Reading one of your older posts I used the "stop" command. Works like a charm!
Tue Feb 19, 2019 3:26 pm
rgspb offline
Is there a way to lower the shade partially but not use the “favorite” position? Maybe in the script?
Tue Feb 19, 2019 5:37 pm
norcoscia offline
I don't think there is a way to command it to a position, but you could just run a counter for some amount in the script and then send the stop command. I have never tried it but I don't see why that would not work. Might not be that accurate -- you could try this (but I don't know if it would work -- I'm not a programmer).
Jay, would know what it best, maybe he will see this and jump in to help on how best to implement a delay in a script.
import time
time.sleep(1) # delay for 1 seconds
_______
Norm
Thu Feb 21, 2019 4:17 pm
rgspb offline
Got all the shades installed today! Here's what I get in the IOS app. Click on the "hamburger" menu, select Integration, select RTI, then select "Get Integration report". Here's what it spit out:
Target: CC1049A9.1
Target: CC1049A9.2
Name: Master Bathroom Shade
Target: CC1049A9.3
Name: Master Bedroom Door
Target: CC1049A9.4
Name: Master Bedroom East
Target: CC1049A9.5
Name: Master Bedroom South 1
Target: CC1049A9.6
Name: Master Bedroom South 2
Scenes
Obviously from this you just change the .# on the CC line for each different shade. Now I wonder if the ID:000X can be used for anything??
