v4.03 is released!!!
Version 4 is all about simplifying the security script in someway, to help streamline the scripting... And to store more of the information necessary inside Indigo, instead of a Applescript that you have to modify everytime you need to make a change.
For example, I am starting to move some of the data into variables inside of Indigo. Why? Well, this allows you to use any of the indigo software packages, to change that on the fly, without having to restart the Indigo server, or reload the attachment scripts.
Also, I am in the process of transistioning to Action Groups instead of Alarm matrix... I do not believe that Action groups will completely replace the Alarm matrix, but simplifying the Alarm matrix is the #1 issue that people mention with the script.
I don't expect any revolutionary changes in the security script until the 5.0 plug-in model is available.
Version History of Security Script
More details at http://www.schollnick.net/wordpress/home-automation/indigo-security-script/
v4.03 – Minor Release
- Added support for Armed & Disarmed status via Security_Status variable
- Added support for the SecurityAlert_Email variable, contains email address(es) to email if system is armed, and security statuses change (Multiple Email addresses are Seperated by comma)
- (Added in v4.02) – Added Opened / Closed support for the Insteon Triggerlinc, etc.
- Added better logging for unknown actions for action group support
- Missed adding in Insteon Open & Close to action group support
- Added Action Group support
- Added Support for Arm / Disarm / Lights On / Lights Off security codes / Panic On / Panic Off
- fixed some minor issues with default times sometimes being set to an invalid time
- Fixed default icon for Growl Support (Now uses Indigo 4 icon)
- Added support for disabling System Beep
