Perl RESTful url device toggle script
Fri Feb 05, 2010 4:46 pm
chrisla23 offline
I use this little script called from LIRC, which I trigger with a buttons on a harmony remote to a hacked appletv/ubuntu box. It toggles a device off and on. It used to have some ugly text manipulation to extract whether the device was on or not from the .txt URLs. Since the new version of Indigo supports XML, I re-wrote to use XML. I sort of think toggle should be baked into the server (isOn=2 ?) for URL access, but it works until then.
I thought maybe someone could use it, or as an example of perl/restful/xml.
#!/usr/bin/perl
# toggle.pl 'light name in indigo'
use Net::HTTP;
use XML::Simple;
my $s = Net::HTTP->new(Host => "10.0.0.32:8176", KeepAlive => "TRUE") || die $@;
my $xml = new XML::Simple;
$s->write_request(GET => "/devices/$ARGV[0].xml", 'User-Agent' => "Mozilla/5.0");
my($code, $mess, %h) = $s->read_response_headers;
my $n = $s->read_entity_body($buf, 1024);
$data = $xml->XMLin("$buf");
   if ("$data->{'isOn'}" eq "True") {
   $s->write_request(GET => "/devices/$ARGV[0]?isOn=0&_method=put", 'User-Agent' => "Mozilla/5.0");
   else {
   $s->write_request(GET => "/devices/$ARGV[0]?isOn=1&_method=put", 'User-Agent' => "Mozilla/5.0");
Fri Feb 05, 2010 5:47 pm
berkinet offline
Re: Perl RESTful url device toggle script
Interesting. In your code it looks like you don't have a password set, or if you do, how did you deal with that?
In order to manage the authentication issues I ended up using a call to libcurl. It looks something like:
use WWW::Curl::Easy;
my $curl= new WWW::Curl::Easy;
    $curl->setopt(CURLOPT_VERBOSE,0);
    $curl->setopt(CURLOPT_NOBODY,1);
    $curl->setopt(CURLOPT_TIMEOUT_MS,200);
    $curl->setopt(CURLOPT_HTTPAUTH,2);
    $curl->setopt(CURLOPT_USERNAME,$iuser);
    $curl->setopt(CURLOPT_PASSWORD,$ipass);
$curl or die "no http link :$!";
$site = "$iurl/variables/alarmStatus?value=Armed_STAY&_method=put";
$curl->setopt(CURLOPT_URL, $site);
$curl->perform;
It would be interesting to compare speeds between libcurl and the http mod. I initially used a system call to "curl" but testing showed that after 5 o6 6 calls the libcurl call was faster.
Fri Feb 05, 2010 6:31 pm
chrisla23 offline
Always fun how there are a million ways to do the same thing. Indeed, no passwords, probably a touch crazy/lazy. In my old version, I did use curl partly via system calls.
Typical Old: `time`
real 0m1.992s
user 0m0.104s
sys 0m0.028s
Typical new:
real 0m0.310s
user 0m0.260s
sys 0m0.024s
I'd guess that the whole round trip from when I press the remote button to when the light turns off is maybe a 10th of a second more on top of that.
-Chris
