Matt wrote:Here's a copy of the restart entries from the event log:
Jul 26, 2009 10:32:12 AM
Starting Indigo Server version 4.0.2
Loading attachments
Bonjour registered "Indigo - My House 4.0b7"
Indigo Cocoa client authenticated
WebServer client authenticated
WebServer started on port XXXX -- authentication disabled
WebServer loaded plugin "Device that are On!"
WebServer loaded plugin "Event Log Plugin"
WebServer enabled browser access to plugin path "plugins/Device_on/css"
WebServer enabled browser access to plugin path "plugins/itunes/css"
WebServer enabled browser access to plugin path "plugins/itunes/images"
WebServer enabled browser access to plugin path "plugins/itunes/js"
WebServer enabled browser access to plugin path "plugins/m/css"
WebServer enabled browser access to plugin path "plugins/m/images"
WebServer enabled browser access to plugin path "plugins/m/images/controls/static"
WebServer enabled browser access to plugin path "plugins/variable/css"
I don't see anything obvious... What version of Mac OS X are you running?
Have you installed a custom version of Python?
1) Download the ZIP file, and unarchive it.
2) Rename the Folder to “itunes” and place it in the following location.
/Library/Application Support/Perceptive Automation/Indigo 4/IndigoWebServer/Plugins
3) Restart the Indigo 4 Server
To Uninstall, just remove the itunes folder from the Plugins folder, and restart the Indigo Server.
