halgreene wrote:I know I'm missing something, but when I program my Powerlinc V2 2414 everything works fine as long as I issue commands through the Indigo software, so I know the PL is talking to my Insteon switches fine. But when I program simple events and disconnect, the unit does NOT seem to go into what it calls "standalone" mode. The events do not seem to work (simple time-of-day on/off events, nothing fancy). When I connect I get a message that "standalone is disabled." Isn't standalone automatically enabled when I disconnect? Or do I have to explicitly enable standalone mode somehow? If I unplug the PL and move it to a different outlet, does this affect the mode of the PL?
halgreene wrote:Finally, I want to issue simple "all on" and "all off" commands. I would think that these are the MOST basic Insteon commands possible, and yet I'm informed (by Indigo) that they are NOT compatible with the PL. Is this a PL issue or an Indigo issue? I can hardly imagine that the PL can't do this command, only that the Indigo THINKS it can't. Thanks, Hal.
halgreene wrote:I'm getting this when I try your suggestion:
Mar 21, 2009 11:58:28 AM
PowerLinc Indigo clock time: Mar 21, 2009 11:58:28 AM
Error ProcessPowerLincV2IO() caught exception: TimeCalculationError -- timegm call failed
/Library/Application Support/Perceptive Automation/Indigo 4/Databases/
