Page 1 of 6
revised basic_mini views
PostPosted: Fri Oct 17, 2008 2:42 pm
by seaofclouds
i was bothered by the complexity and long load times of the iphone views - they look great, but even on wifi they took a while. what began as a hack to modify indigo's default mini pages, soon evolved into a plugin thanks to the efforts of jashaffner.
please see:
http://github.com/seaofclouds/indigo-mini-view-plugin/
to get the most out of these replacement files you will need experience with indigo, zip files, and possibly html and terminal. i'll do my best to answer your questions and give support for these replacements, however, the boards here are a great resource for anything that goes unanswered.
please feel free to contribute. i don't have a sprinkler system, so i'm not sure how these views look for those who do. post snapshots, if you like!
Re: revised basic_mini views
PostPosted: Sat Oct 18, 2008 9:21 am
by matt (support)
Great -- thanks for sharing!
Regards,
Matt
PostPosted: Sat Oct 18, 2008 3:50 pm
by thepainter
I followed the instructions on the page and am not sure what I'm doing wrong but when I put the folder Seaofclouds Indigo-Web .... in theIndigo2 Folder I don't get anything in the Basic pages. I'm sure I'm missing something, I'm using Indigo 3.0
Paul
updated readme, better instructions.
PostPosted: Mon Oct 20, 2008 12:36 am
by seaofclouds
@thepainter - sorry for the trouble. i've updated the readme with what i hope are better instructions. in the meantime, you'll want to:
UPDATE: information in this post is depricated. please follow instructions at http://github.com/seaofclouds/indigo-mini-view-plugin
download .zip file http://github.com/seaofclouds/indigo-mini-view-plugin/zipball/master
expand the download into:
cd /Library/"Application Support"/"Perceptive Automation"/"Indigo 2"/IndigoWebServer/
and replace existing files with the new ones. obviously, if you've made changes to your files, you will first want to back them up.
hope this helps.
PostPosted: Mon Oct 20, 2008 6:44 am
by Matt
Thanks alot for this new way of accessing Indigo from my iPhone. It beats the heck out of loading the control page from an iPhone and is much simpler than the Basic Page.
Just a note, simply replacing all files and folders, included in the zip file, with new ones will delete any custom png's, backgrounds, etc. you might have had.
I'm not sure, but I think all that needs to be replaced are the CSS and TEMPLATES folders.
PostPosted: Mon Oct 20, 2008 3:19 pm
by FaTMax
"The response could not be encoded with utf-8"
Yep, there goes my webserver. Including my controlopages..
how to restore original web server files after modifying
PostPosted: Mon Oct 20, 2008 5:33 pm
by seaofclouds
@fatmax - i'm not sure i understand your question. can you retrace your steps at getting that error?
in the meantime, if you believe that these replacement views are the cause of errors, you can always revert to your backups. if you followed my instructions in the README.textile, just remove the "IndigoWebServer" directory, and rename "IndigoWebServer-ORIGINAL" to "IndigoWebServer". Simply restart the Indigo server, and you should be back up and running.
no backups, no problem. just delete the "IndigoWebServer" directory, then reinstall the latest version of indigo 3. Installer will prompt you to UPGRADE. do so, and your settings should remain intact, and the web server will be installed with the default views. Simply restart the Indigo server, and you should be back up and running.
i've updated the readme.textile file with these tips on reverting.
Re: how to restore original web server files after modifying
PostPosted: Mon Oct 20, 2008 6:10 pm
by matt (support)
This type of functionality is an excellent candidate for the Web Server plug-in architecture. You could take your template changes and create a plug-in that doesn't replace or edit any of the existing files. It would just drop into the plugins folder.
Regards,
Matt
looking into converting this into an indigo plugin
PostPosted: Mon Oct 20, 2008 6:20 pm
by seaofclouds
thanks for the tip, matt. i'll look into that.
Regards,
Matt
PostPosted: Mon Oct 20, 2008 9:07 pm
by jay (support)
Download the IWS Variable Plugin from the filelib - I documented it very extensively so that it would be a good starting point for other plugins.
PostPosted: Mon Oct 20, 2008 10:53 pm
by FaTMax
Thats the error I get when loading the loding the basicpages. At det minipages and Control Pages I get "Internal Server Error".
Unfortunately, after examening the Terminal and Indigo files, no backup was made. It stated: "Folder already exist, no files copied". I´ll chack Time Machine later today, hopefully it has been doing its job lately.
- FatMax
PostPosted: Tue Oct 21, 2008 12:59 pm
by jashaffner
Jay, where is the "filelib"? Thanks.
seaoflclouds,
Is it possible to show devices' status in real time without having to refresh?
PostPosted: Tue Oct 21, 2008 1:09 pm
by jay (support)
PostPosted: Tue Oct 21, 2008 2:33 pm
by jashaffner
Lets say that I have two templates in my plugin. What path can I use in templateA to include templateB? I tried a couple different paths but to no luck.
Thanks.
ps: i am attempting to port seaofcloud's work into a plugin just to learn how to make use of plugin architecture thus the reason for my posts within this thread.
PostPosted: Tue Oct 21, 2008 3:11 pm
by matt (support)
The path is relative to the main IndigoWebServer folder, so your include will look something like this:
#include "plugins/PLUGIN_NAME_HERE/templates/templateB.html"
And thanks for making this into a plug-in!
Regards,
Matt
