Jandy Aqualink Pool / Spa Control - AppleScripts updated
Sun Jan 08, 2012 6:12 pm
Re: Jandy Aqualink Pool / Spa Control - AppleScripts updated
Yeah, if the try block's catch doesn't pass the exception up then it won't be logged.
Sun Jan 08, 2012 6:25 pm
asw24b offline
Hmmm.... it does.
def startup(self):
self.debugLog(u"Method: startup")
if valuesDict[u"showDebugInfo"] == True:
self.debug = True
self.debug = False
except:
pass
Sun Jan 08, 2012 6:29 pm
"pass" is just a NOP in python that is required because of how block syntax uses spaces/tabs. If you change the pass to raise, then it should be logged.
Sun Jan 08, 2012 6:37 pm
asw24b offline
Duh.
Thanks !!
Sun Jan 08, 2012 6:52 pm
nlagaros offline
Looks like I have some cleanup to do. Thanks everyone.
Sun Jan 08, 2012 7:02 pm
asw24b offline
No worries ! Thanks for the great plugin !
Tue Jan 10, 2012 10:22 pm
hamw offline
I have a pool/spa combo with a single pump and valves. With the pump running I tried activating the spa via a control page button set up from the plugin's "Pumps" device menu, selecting "Spa Pump" and the action "Toggle On/Off". The "Spa =" device state did not register "On" and the Autelis Spa did not register "On". The plugin generated this error:
  Autelis Jandy Error             Error in plugin execution ExecuteAction:
  File "plugin.py", line 60, in actionPump
  File "/Library/Application Support/Perceptive Automation/Indigo 5/Plugins/AutelisJandy.indigoPlugin/Contents/Server Plugin/Autelis.py", line 156, in actionGeneric
<type 'exceptions.NameError'>: global name 'Pumpdev' is not defined
Using the Autelis web page, when the "Spa" setting is turned on, the "Spa =" device state registers "On" and the Control Page device state icon changes color. Is there another way to have the Spa enabled via the plugin?
Wed Jan 11, 2012 7:29 am
nlagaros offline
I've got a typo in there - will get to it this weekend and post the update.
Sat Jan 14, 2012 9:46 pm
hamw offline
Is it possible to have device states for Pool and Spa such that we get values for "Pool Heat Enabled", "Pool Heat On", "Pool Heat Off", as well as "Spa Heat Enabled", "Spa Heat On" and "Spa Heat Off"? The current device states indicate "Pool Heater On/Off", "Pool Heater 2 On/Off" and "Spa Heater On/Off". The One Touch and the Autelis Temperature Control Menu keeps track as to whether heat is enabled, on or off.
Sun Jan 15, 2012 10:24 am
hamw offline
Here are the pics showing the states and the Autelis page. The first pic is heat off, pump off. Second is heat enabled, pump off. Third is heat enabled, pump on = heat on. This could be done with variables and triggers, but when one adds in the spa and whether the heater is actually turned on (e.g. temp is achieved and heater is shut off, leaving "heat enabled" "pump on" as correct state but the heater is not actually running) it might get more complex.
Pool Heat Off.png (79.02 KiB) Viewed 6906 times
Pool Heat Enabled.png (78.73 KiB) Viewed 6906 times
Pool Heat On.png (102.64 KiB) Viewed 6906 times
Sun Jan 15, 2012 12:02 pm
nlagaros offline
I'm going to run through these scenarios with my controller and see if the Autelis will broadcast out the proper modes. If not, will contact the vendor and see if they can modify the TCP API so we get the correct states. Stand by...
Sun Jan 15, 2012 12:09 pm
asw24b offline
I'm pretty sure that the Jandy serial box behaves the exact same way....
Mike
Sun Jan 15, 2012 12:16 pm
nlagaros offline
Ok folks. Please download the revised plugin from the wiki page. I've fixed the typo that was pointed out the other day and think I have the heat states correct for testing. Let me know if this does the trick. I was able to see my main heater zone switch states from off to enabled to on - so think this may do the trick.
Sun Jan 15, 2012 5:23 pm
hamw offline
Went to your other download site, https://vulture.lagaros.com/wiki/pages/ ... ugin.html# and it's still the v1.01 plugin. Is there another site?
Sun Jan 15, 2012 5:38 pm
nlagaros offline
I kept the version number the same - I replaced the file with the updated one. It was minor so did not change version numbers.
Page 6 of 8 1 ... 3, 4, 5, 6, 7, 8
