Indigo Remote Log File Viewer
Thu May 21, 2009 8:28 am
bschollnick2 offline
(No subject)
The following URL is the second trial for Eventlog v1.50 B. This version should help reduce any failures from non-ascii content in the log file...
The plugin can be downloaded from the homepage...
http://www.schollnick.net/wordpress/home-automation/indigo-remote-log-viewer/
Or you can download the file directly from:
http://www.schollnick.net/wordpress/wp-content/plugins/download-monitor/download.php?id=16
Tue May 26, 2009 12:00 pm
jamus offline
(No subject)
I erased the old installation, installed the newest version 1.50b, and restarted the indigo server.
I'm now having a problem where the "Filter by Entry Type" doesn't work at all, although the "Number of Days to View" and "View a Particular Day" work flawlessly.
Tue May 26, 2009 8:02 pm
(No subject)
I found the bug.... I was cleaning up the code when I wrote the CSS support, and I accidently commented out the Filter by Entry Type section...
I'll try to post the next beta tomorrow morning...
Wed May 27, 2009 9:25 am
(No subject)
The following URL is for Eventlog v1.50 C. This version restores the Filter By Tag options...
http://www.schollnick.net/wordpress/hom ... og-viewer/
http://www.schollnick.net/wordpress/wp- ... .php?id=17
Wed May 27, 2009 12:18 pm
jamus offline
(No subject)
A minor feature request when you have a chance:
In my event log, if I have a bunch of lines that occur at the same time, only the first one has a time field.
It would be nice to have every line have a time. This would be especially helpful when I filter by event, because the event that had the time information was filtered out.
Thu May 28, 2009 10:50 am
(No subject)
Folks,
Version 1.50E is now available for the Indigo Remote Log Viewer....
This fixes a small bug that was added when I added CSS support... The Filter by Type option was not working correctly, and is now functional....
In addition to the Version C changes above, the E version includes:
* Support for resorting the columns (Click on the new headers for ascending or descending sorts)
* Resizable columns
One issue is that several new CSS elements have been added, if you have customized your CSS file, please back it up and re-integrate the changes to the new CSS file...
The second issue is that the time stamp is no longer eliminated when it has been duplicated (eg, Multiple Events that had the same time stamp only contained a time stamp on the first event). This change was made, because the empty field would confuse the Time Date Sort....
Please feel free to give some feedback, especially with the new header names.... I welcome any suggestions...
Tue Jun 23, 2009 10:34 am
Indigo Remote Log Viewer v1.52 -- update
Changes in this version (v1.52) include, a change in the parser to fix Encoding errors, and adding better iphone support...
So head over to http://www.schollnick.net/wordpress/home-automation/indigo-remote-log-viewer/ and download it.... Any suggestions for improvements are welcome.
