Sprinkler Runtime Modifier (Weather / Sprinkler Script)
Sun Aug 01, 2010 2:45 pm
berkinet offline
Re: Sprinkler Runtime Modifier (Weather / Sprinkler Script)
dnomode wrote:
...Now I'm getting a new error:
Sprinkler Runtime Modifier GetXMLfile:URL Access Scripting got an error: Connection is invalid.(-609)
... ...I checked the network and everything looks good.
What could it be? Any ideas?
I would suggest trying the connection from a browser and then try it using curl from the command line. If it works in curl, you might want to consider changing the AS to use curl in a "do shell script..." as URL Access Scripting is notoriously unstable.
Tue Aug 03, 2010 6:13 am
midd offline
I noticed some errors this morning:
Aug 3, 2010 12:08:59 AM
  Sprinkler Runtime Modifier ParseXML:System Events got an error: Some data was the wrong type.(-1703)
  Weather NOAA        ParseXML:System Events got an error: Some data was the wrong type.(-1703)
Indigo 7, Monterey (12.1) on a 2009 Mac Pro..
Wed Aug 18, 2010 5:20 pm
midd offline
I'm having no luck with this script. Here are the errors I was getting all day yesterday:
Aug 17, 2010 11:46:41 PM
  Sprinkler Runtime Modifier GetCurrentWeather:The variable errNum is not defined.(-2753)
  Weather NOAA        Weather NOAA Script Failed:The variable errNum is not defined.(-2753)
Thu Jul 07, 2011 2:48 pm
midd offline
Have to revisit this thread. Still have not been able to get this script to work. Getting the following errors:
GetXMLfile: The variable webQueryTimeout is not defined. (-2753)
UpdateCurrentWeather: The variable currentObserveTime is not defined. (-2753)
I have assigned both in the variable list in Indigo. Quit and restarted Indigo with no luck.
