put my weather station data into Indigo
Fri Apr 02, 2021 12:38 pm
Dual offline
I have two weather stations. One reports to WeatherUnderground. The other reports to both WeatherFlow and WeatherUnderground. I have api access to both. When I enter the URL into a browser I get the info below. How do get this info into Indigo variables? Is there a plugin that can do this? Or sample python code?
From swd.weatherflow.com:
{"station_id":99999,"station_name":"xxxxx","public_name":"xxxxx","latitude":99.99999,"longitude":99.99999,"timezone":"xxxxx","elevation":839.02294921875,"is_public":true,"status":{"status_code":0,"status_message":"SUCCESS"},"station_units":{"units_temp":"f","units_wind":"mph","units_precip":"in","units_pressure":"inhg","units_distance":"mi","units_direction":"cardinal","units_other":"imperial"},"outdoor_keys":["timestamp","air_temperature","barometric_pressure","station_pressure","pressure_trend","sea_level_pressure","relative_humidity","precip","precip_accum_last_1hr","precip_accum_local_day","precip_accum_local_yesterday_final","precip_minutes_local_day","precip_minutes_local_yesterday_final","wind_avg","wind_direction","wind_gust","wind_lull","solar_radiation","uv","brightness","lightning_strike_last_epoch","lightning_strike_last_distance","lightning_strike_count","lightning_strike_count_last_1hr","lightning_strike_count_last_3hr","feels_like","heat_index","wind_chill","dew_point","wet_bulb_temperature","delta_t","air_density"],"obs":[{"timestamp":1617387929,"air_temperature":27.3,"barometric_pressure":915.1,"station_pressure":915.1,"sea_level_pressure":1012.5,"relative_humidity":14,"precip":0.0,"precip_accum_last_1hr":0.0,"precip_accum_local_day":0.022484,"precip_accum_local_yesterday":0.0,"precip_accum_local_yesterday_final":0.0,"precip_minutes_local_day":2,"precip_minutes_local_yesterday":0,"precip_minutes_local_yesterday_final":0,"precip_analysis_type_yesterday":1,"wind_avg":0.0,"wind_direction":0,"wind_gust":0.0,"wind_lull":0.0,"solar_radiation":787,"uv":2.7,"brightness":94489,"lightning_strike_last_epoch":1617367111,"lightning_strike_last_distance":25,"lightning_strike_count":0,"lightning_strike_count_last_1hr":0,"lightning_strike_count_last_3hr":0,"feels_like":27.3,"heat_index":27.3,"wind_chill":27.3,"dew_point":-2.5,"wet_bulb_temperature":12.3,"delta_t":15.0,"air_density":1.06103,"pressure_trend":"steady"}]}
From api.weather.com:
{"observations":[{"stationID":"xxxxx","obsTimeUtc":"2021-04-02T18:27:29Z","obsTimeLocal":"2021-04-02 12:27:29","neighborhood":"xxxxx","softwareType":"Weather logger V3.0.5","country":"xx","solarRadiation":305.8,"lon":99.999999,"realtimeFrequency":null,"epoch":1617388049,"lat":99.9999999,"uv":4.0,"winddir":258,"humidity":31,"qcStatus":1,"imperial":{"temp":51,"heatIndex":51,"dewpt":21,"windChill":51,"windSpeed":0,"windGust":0,"pressure":26.95,"precipRate":0.00,"precipTotal":0.00,"elev":2972}}]}
Fri Apr 02, 2021 1:31 pm
Re: put my weather station data into Indigo
I think GhostXML will do that for you. Into device states, anyway, which is just as useful.
Fri Apr 02, 2021 2:18 pm
Yes, GhostXML should be able to handle that JSON payload no problem.
The trickiest bit--and it shouldn't be too tricky--is to set up any needed authentication.
Fri Apr 02, 2021 3:53 pm
Korey offline
Korey
Sat Apr 03, 2021 8:35 pm
Dual offline
Thanks Joe and Dave and Korey. I implemented both GhostXML and the WeatherFlow plugin for now. Both work well. Very different approaches and devices created. Authentication was not required since my API token is built into the URL.
Sun Apr 04, 2021 5:38 am
Cool beans. Thanks for reporting back. Good luck, and please let me know if you have any questions.
