Indigo SDK Now Available
Tue Jan 31, 2012 7:24 pm
The Indigo Plugin SDK is now available for downloading.
At this point, because all of the developer documentation is online, the SDK consists just of a ReadMe with pointers to the documentation and several very useful example plugins. The example plugins, which include the full XML and python source, are a great place to start when developing new plugins.
We've included plugins that illustrate how to integrate:
  • Relay devices (including lock devices)
  • Dimmer devices (including color RGB devices)
  • Sensor devices (binary and variable value)
  • Thermostat devices
  • Speed control (fan) devices
  • Sprinkler devices
  • Energy meter devices
  • Custom devices
Also included are plugins that illustrate how to:
  • Traverse the Indigo database
  • Catch low-level X10 and INSTEON messages
  • Catch low-level Z-Wave messages
  • Communicate between plugins using the broadcast and subscribe APIs
  • Create a telnet server using the python Twisted framework
Wed May 02, 2012 6:59 pm
Re: Indigo SDK Now Available
SDK v1.0.2 posted -- includes an example sensor device plugin (requires Indigo 5.1.2).
Thu May 03, 2012 7:29 pm
roussell offline
Thanks Matt, if for SDK v1.0.3 you want to add an irrigation example, well that'd be okay with me. Just thought you should know... :wink:
Terry
Thu May 03, 2012 7:59 pm
Noted. :-) Unfortunately, the internals in Indigo for a irrigation device subclass aren't quite done yet so it'll take a bit more work. But as soon as we have it done, I'll definitely put an example in the SDK.
Tue Nov 13, 2012 8:01 pm
A new version of the SDK is posted that supports some of the new Indigo 6 APIs. Check out the Example Device - Factory plugin for an example of how to create device groups.
Thu Oct 24, 2013 7:32 pm
Indigo SDK 1.2.0 is now available (download link in original post above). The SDK now includes a sprinkler device example and an energy/power meter device example. Also included in a previous SDK version (I forgot to mention it on this thread) is the speed control (fan) device example.
Wed Mar 23, 2016 9:21 am
johnpolasek offline
Newby question... I know it's out there somewhere, (hopefully in the readme when I get home and can get on a mac, but I'm at a windows only shop at work and they don't understand dmg) but the mass of documentation I'd have to wade through is daunting: If I want to add an additional debug message to one of the opes source plugins I have running, do I just disable it, modify the .py file in the disabled plugins folder and thenre enable it?
Wed Mar 23, 2016 9:43 am
Yes. ;)
Wed Mar 23, 2016 11:55 am
I am doing it life in the running plugin and then reload the plugin
Much faster and easier to manage.
go to plugin directory
Show contents of plugin
Open the file plugin.py in your editor. Do not use text edit that will screw things up. For beginners textwrangler is the best tool to do simple edits
Wed Nov 23, 2016 5:56 am
lindehoff offline
I'm looking for the updated SDK from Indigo 7, where can I find it?
I have the beta SDK but it does not include examples for Locks like it said in the Announsment
For a detailed example of how to define a plugin color device (including commented plugin.py action callback code) see the Example Device - Relay and Dimmer plugin in the Indigo SDK download.
Wed Nov 23, 2016 6:03 am
Does http://www.indigodomo.com/Indigo7SDK have them in?
I can't open .dmg's to check here
Peter
Wed Nov 23, 2016 6:10 am
Ah, just checked on my Mac at home.
You're right, they're missing from that one - but if you've got the latest one from the beta forum, that definitely has them. (It was updated mid-beta so go back and get the link again until the live link is updated)
Peter
Wed Nov 23, 2016 6:19 am
lindehoff offline
Peter
Ok, thanks I will have a look at that one.
Wed Nov 23, 2016 6:27 am
lindehoff offline
The latest one I can find is from 28th of September and it does not have examples for locks.
Wed Nov 23, 2016 12:12 pm
I updated the DMG download. It now includes the RGB color example (dimmer device), lock example (relay device), Z-Wave message catching, and broadcast/subscribe API examples.
