Plugin help
Mon Jan 08, 2024 2:45 pm
mwoodage offline
Re: Plugin help
Hi all,
I've now hard coded the username and password into the script and have it running from a schedule to update every hour. So it's working, which is good news,
Neil, I tried putting the full path to the credentials file into the script, but couldn't get this to work. I also tried moving the script (and the path) to other locations, tried saving the file in different formats and re-writing it completely as a new file, nothing worked! It was the same error every time.
Ryan, thank you for your help - i'd rather not hard code the information, but at the moment this is the only option - i'm assuming the information is safe as it's only contained on my system? Is there another way we can do the same thing but seeing the information safe?
It does seam odd that the credentials file is not accessible when running it from Indigo, but the same file works when run from terminal. Is this just an Indigo quirk?
Thanks All
Martin
Mon Jan 08, 2024 2:49 pm
Re: Plugin help
It's either a search path issue, or a user permission issue. Neither is specific to Indigo per se, but are because you're running the script from two different environments.
Mon Jan 08, 2024 2:55 pm
mwoodage offline
Re: Plugin help
Thanks Joe,
I've tried the credentials file in different locations, changing the full path in the script each time and checked the permissions each time - giving it full read/write access.
I've also moved the whole folder to different locations, and running it from terminal, which works, and from indigo which doesn't.
Anyhow, it's working for now, which is fantastic - if there's a safer way of hosting the username and password then it would be good to try that,
M
Mon Jan 08, 2024 3:03 pm
Re: Plugin help
It's all limited to that one machine, so if you get a breach of that machine, you have much bigger issues to worry about.
Mon Jan 08, 2024 3:14 pm
neilk offline
Re: Plugin help
Martin - as Joe says your credentials for other plugins and the credentials.json file is just as vulnerable as having them in this script (they are all stored in text files). The real advantage of having them external is if you share the script (on here for example) you need to be careful to redact it, whereas if the credentials are stored in a separate file you don't have that risk. (I did something similar uploading my early plugin code to GitHub that had details in I did not intend to share).
Keeping the machine secure with a strong unique passwords and you should be fine.
With the script running this way, you don't need to use the API to update the variables, you could do it directly in Python and also add updates to the indigo log if it fails/succeeds etc. Not necessary as this will work, but a good learning exercise.
Neil
Mon Jan 08, 2024 4:25 pm
mwoodage offline
Re: Plugin help
Thanks Neil, Joe,
I really appreciate the explanation and info, the machine is fairly well locked down with secure passwords so hopefully we’ll be ok
Martin
Mon Jan 08, 2024 5:01 pm
Re: Plugin help
A couple of final thoughts:
1) As much as possible, you want to use full paths when dealing with files and shell commands because the environment that the host process uses. You could get the Indigo installation folder and then construct the full path from that, which would probably have worked.
2) I never said it wouldn't work because of its use of asyncio, I said it may not work, particularly if run embedded. Embedded scripts (and linked scripts to a lesser extent) run in a special host environment and use a special way of loading. I don't believe anyone has actually tested a script that uses asyncio when running from that specific environment, therefore I wasn't sure if it would work or not.
In any event, I'm glad you found a solution. Might make for an interesting plugin if someone wanted to give it a try.
Fri Jan 12, 2024 9:52 am
mwoodage offline
Re: Plugin help
I'm feeling quite pleased with myself!!
So, this week i've been monitoring the Indigo Schedule I set up to run the indigo_variables.py script with my username and password imbedded in it. You'll remember last week we couldn't get the info from the credentials.json file to work That method has not been working that well - 9 times out of 10 it just gives an error.
So, today after a bit of Googling I stumbled across the idea of getting Indigo to run a seperate script that runs the indigo_variables.py script, and it works!
I now have the following running from a separate folder outside of Indigo, that gets executed by an Indigo Schedule every hour.
import os
def execute_python_file(file_path):
        os.system(f'python3 "{file_path}"')
    except FileNotFoundError:
        print(f"Error: The file '{file_path}' does not exist.")
file_path = "/Library/Application Support/Perceptive Automation/Python3-includes/indigo_variables.py"
This way Indigo quite happily runs the indigo_variables.py script.
Maybe I am a Python coding genius after all :lol: :lol: :lol: :lol:
