http plugin?
Thu Aug 12, 2021 11:00 am
berkinet offline
http plugin?
In the Announcement for 2021.1, Jay wrote:
  • Added the ability for plugins to handle arbitrary HTTP requests.
So, I was wondering if anyone (Flying Diver?) was thinking about something like an http virtual device plugin. The idea would be to create an Indigo device for which the state was maintained by http requests from some arbitrary external system. A lot like the REST API. Except, there would be the possibility of some degree of communicating back to the external service. Though obviously only synchronous with receipt pf requests, and there would probably need to be a message queue. . Also, it would be possible to define and manipulate device states.
This might end up being functionally similar to updating variables via the REST API and then triggering some action 0ff of the variable's change. So, maybe it isn't really worth the effort.
But, just wondering.
Fri Aug 13, 2021 6:07 am
Re: http plugin?
Sat Aug 14, 2021 10:38 am
berkinet offline
Re: http plugin?
FlyingDiver wrote:
Thanks. Yes, I had forgotten about that plugin. I had used it previously as the basis for a sprinkler control system. Just a small hack to return an ACK or a NAK depending on various conditions.
One question though. The plugin description says
...The first "action" the plugin supports is "/setvar". This will set the specified variables to the values given. ...
But, instead, the plugin actually creates and up[dates states of the Indigo device. That is actually what I'd want. Just not what the plugin says it does. Did you forget to update the description when you released httpd2?
So, the only thing really missing from the functionality I described in my first post in this thread is the ability to create a custom response. Perhaps a dynamic string or the results of some arbitrary script execution. The first one should be pretty straightforward, the second idea not as much.
But, in any case, thanks!
Sat Aug 14, 2021 10:39 am
Re: http plugin?
Yes. The description is out of date. :(
Sun Aug 15, 2021 4:19 am
berkinet offline
Re: http plugin?
So... I have switched two devices from the REST API to the HTTPd 2 plugin. These devices are actually scales. One measures the weight of a butane tank the other the weight of mail, etc. in our mailbox.
While doing this I thought it would be nice to see the weight in the Display State column in the devices table. So, I offer the following hack (I.e. quickly coded and tested only to see if it does what I wanted).
In devices Devices.xml I added this property to the HTTP/HTTPS Server device:
            <Field id="displayState" type="textfield"  defaultValue="">
                <Label>Display state for devices list:</Label>
            </Field>
Then, I added this metrhod under callback for state list changes in plugin.py:
    def getDeviceDisplayStateId(self, device):
        states_list = device.states
        displayState = device.pluginProps.get('displayState', None)
        if displayState in states_list:
            return displayState
            return None
Sun Aug 15, 2021 6:08 am
Re: http plugin?
You could do a pull request in GitHub.
