Dynamic Device Creation?
Fri Feb 19, 2021 11:33 am
At the moment, in my under development plugin to link to Hubitat, I have created a number of devices in devices.xml, each with a device type such as relay, thermostat, sensor etc.
I was wondering if it is possible just to define one device type i.e. custom with all the properties associated with the other device types and just switch on the properties specific to a particular device type. Then when the device is created, to dynamically change the device type from custom to say relay?
I think the device type needs to be specific as a number of other plugins check for specific device types, e.g. Occupatum for sensors with on/off. I want the linked Hubitat devices to work with existing plugins as if they were native Indigo devices.
At the moment I am only creating one device per Hubitat device but I think a number of devices would benefit from using the Factory model which would be more Indigo like.
Is the removal of the User
At the moment, the devices defined in devices.xml share a lot of common fields e.g. selecting hub and device, listing properties of the device and selecting which ones to enable. This means a lot of cutting and pasting when things are changed as the plugin is developed.
I suspect the answer is going to no, but thought I would ask. :)
Fri Feb 19, 2021 3:07 pm
Re: Dynamic Device Creation?
Yeah, I've done this a couple times. Check out the code for https://github.com/FlyingDiver/Indigo-RFPlayer
The XML file has a bare-bones definition for a "Discovered Device". When the device is created, the protocol module for the device type sets up the device with all the appropriate features. The oregon.py module is probably the best example.
Fri Feb 19, 2021 3:27 pm
I think we can attack this problem a bit differently than trying to dynamically switch the device type.
Indigo's XML parser has the ability to substitute in an array of <Field> nodes from another file, so you can put all the reusable properties/UI into its own file. Its use it documented here. I use this technique for Indigo's Z-Wave plugin devices.
Sat Feb 20, 2021 7:19 am
Thanks Matt - I had forgotten about that feature. Now implemented. :D
Sat Feb 20, 2021 7:27 am
I think the template solution will work for me.
However, thanks for the link to your plugin. I have been studying the oregon.py file with interest. It certainly gives me food for thought. :)
Sat Feb 20, 2021 7:35 am
Templates are a super feature, which I use as much as possible. I use them "internally" with plugins when I'm repeating the same control for multiple plugin devices, but I also use them "externally" where I use the same XML blocks across multiple plugins. For example, my plugin preferences debug logging settings are the same in all my plugins -- so I can tweak the code in one place.
<OT> I also use symlinked files in a similar way. For example, I use a single file to build the footers of all my plugin wikis. </OT>
