Communicating with subprocess (via Popen)
Sun Feb 07, 2021 10:26 am
I'm using this code to test communication with a Python 3 wrapper around a Python 3 only library.
#client.py:   test client for communicating with wrapper.py
from subprocess import Popen, PIPE
from threading import Thread
from time import sleep
def read_it():
    print(u"read_it thread running")
    while True:
        for msg in process.stdout:
            print(u"subprocess output: {}".format(msg.rstrip()))
print(u"subprocess starting")
process = Popen(['/usr/bin/python3', './wrapper.py', 'arg1, 'arg2'],
                                stdin=PIPE, stdout=PIPE, close_fds=True, bufsize=1, universal_newlines=True)
print(u"subprocess running: {}".format(process.pid))
thread = Thread(target=read_it)
thread.daemon = True
thread.start()
sleep(5.0)  # wait for initial output from subprocess
When this run using Python3, it works as expected:
% /usr/bin/python3 --version
Python 3.8.2
% /usr/bin/python3 ./client.py
subprocess starting
subprocess running: 24458
subprocess output: {"msg": "status", "status": "Login Complete"}
But not when running using Python2:
% /usr/bin/python --version
Python 2.7.16
% /usr/bin/python ./client.py
subprocess starting
subprocess running: 24466
Both processes are definitely running, I'm checking that in another Terminal window.
Any ideas?
Sun Feb 07, 2021 1:38 pm
Re: Communicating with subprocess (via Popen)
In your for loop try using readline().
Sun Feb 07, 2021 1:46 pm
Hmm. Changing it like this works:
def read_it():
    while True:
        msg = process.stdout.readline()
Now to try it in the actual plugin...
