Dynamic List Filters
Thu Dec 17, 2020 11:49 am
At the risk of coming across like a baby that just discovered his own foot, I wanted to highlight an approach to using dynamic list filters that I only just discovered. I was under the (mistaken) impression that filters were limited to Indigo objects and object attributes (i.e., "supports.onState" and the like). It turns out that you can send "anything" in the filter field to the callback method.
In this example, Source1 and Source2 list all Indigo devices. Value1 and Value2 show the device states for the selected Indigo devices and both Value1 and Value2 refer to the same callback, with only the filter being different. By using the filter value, you can return different things to different controls using one callback. So why not use that to tell the callback which value to return to each control? Turns out this works really well. Who knew?
Devices.xml
<Field id="Source1" type="menu">
   <Label>Source 1:</Label>
   <List class="self" filter="" method="some_method" dynamicReload="true"/>
   <CallbackMethod>callback_method</CallbackMethod>
</Field>
<Field id="Value1" type="menu">
   <Label>Value:</Label>
   <List class="self" filter="Source1" method="another_method" dynamicReload="true"/>
</Field>
<Field id="Source2" type="menu">
</Field>
<Field id="Value2" type="menu">
   <List class="self" filter="Source2" method="another_method" dynamicReload="true"/>
</Field>
plugin.py
def some_method(self, filter="", values_dict=None, type_id="", target_id=0):
   return [(dev.id, dev.name) for dev in indigo.devices.iter()]
def another_method(self, filter="", values_dict=None, type_id="", target_id=0):
   return [(state, state) for state in indigo.devices[values_dict[filter]].states]
(The example code is modified from working code, but may contain errors.)
Thu Dec 17, 2020 1:47 pm
Re: Dynamic List Filters
Yeah, the filter param is super useful. I use it in the Action Collection to implement (somewhat) pluggable brand-specific actions for Z-Wave devices (Homeseer was first, Inovelli and Zooz next). I can then use a single callback function in the plugin that examines the filter and uses that to dispatch to the correct module.function. Pretty slick actually, I can encapsulate everything in one file for each vendor.
Thu Dec 17, 2020 4:32 pm
In one of my plugins, I have what amounts to eight copies of the same callback--one each for eight controls. It'll be nice to pare that back to just one.
It was the filter="stuff" example in the docs that got me to think about it differently.
