Use visibleBindingId with 2 values?
Sat Nov 28, 2020 9:36 am
racarter offline
I'd like a config field to become visible if one or both of two checkbox values are true. If this is possible can anyone point me in the right direction?
Thanks in advance!
Sat Nov 28, 2020 1:22 pm
Re: Use visibleBindingId with 2 values?
You cannot define it in XML directly, but you can override the method that gets the XML values before the UI is shown. For device settings it would look something like:
   def getDeviceConfigUiValues(self, pluginProps, typeId, devId):
      valuesDict = indigo.Dict(pluginProps)
      errorsDict = indigo.Dict()
      valuesDict["visibleBindingTagNameUsedInXML"] = something or something_else
      return (valuesDict, errorsDict)
Sat Nov 28, 2020 2:14 pm
racarter offline
Thanks Matt :)
Sun Nov 29, 2020 12:58 pm
Alternately, you can make the binding link to a hidden field then calculate the correct value for the hidden field in a callback. I can't recall if you can attach a callback to a checkbox change though, so you might have to change the UI controls you use (i.e. a menu with Option 1, Option 2, Option 1&2, then you definitely can do a callback when the menu changes).
Sun Nov 29, 2020 1:15 pm
racarter offline
Cool. Thanks Jay.
