Dialog Close Notification for MenuItems
Thu Aug 06, 2020 11:00 am
hannt offline
I'm creating a plugin that does not define a device or action. Instead, it just configures an existing device. The configuration interface is implemented as a MenuItem with a ConfigUI in MenuItems.xml. Here's an example from the Plugin Dev Guide:
    <MenuItem id="menu3">
        <ConfigUI>
                <Label>Light:</Label>
            </Field>
        </ConfigUI>
    </MenuItem>
Indigo will open a configuration dialog when the user selects the menu item from the Plugin menu. When the user presses the "Execute" button (or "Turn Off" in the example above), the defined callback method is invoked. However, it doesn't appear that anything happens if the user instead presses the "Cancel" button. Is there a Dialog Close Notification method for a MenuItem callback that captures the state of the cancel button? Thanks!
Thu Aug 06, 2020 12:24 pm
Re: Dialog Close Notification for MenuItems
I'm pretty sure that if the user clicks cancel, then your call back method just doesn't get called. Why do you need to know the menu dialog was displayed if the user cancels the call?
Thu Aug 06, 2020 12:56 pm
Currently, menu item callbacks do not have a validate-on-close callback.
Thu Aug 06, 2020 2:00 pm
hannt offline
As the user is clicking around in the UI, I'm updating a dictionary in the background. When the user presses the "Save" button, that data in the dictionary will get used to update properties on a thermostat. When the user presses the "Cancel" button, I'd like to delete or maybe clear out the dictionary.
As I've thought through this more, I don't think it really matters if I clean up the dictionary. I can just initialize the dictionary the next time the UI is opened.
Thanks for the info guys.
