Can you stop and re-start runConcurrentThread()?
Thu May 14, 2020 8:24 pm
Re: Can you stop and re-start runConcurrentThread()?
Yeah, in this case refreshCallbackMethod is what you'll need to use. It is a bit clumsy, but it should work. We use it in the Z-Wave plugin for the inclusion process UI and the optimize UI. Here are some more details about how to use it.
Fri May 15, 2020 12:07 pm
Learns about this callback for the first time this morning...
...uses it in the plugin i'm in the middle of writing this evening....!
Fri May 15, 2020 12:26 pm
You can use it in combination with visibleBindingId / visibleBindingValue to provide rudimentary progress feedback as well.
Fri May 15, 2020 12:35 pm
Oh, I use those several times - including the mythical multiple comparison options (visibleBindingValue = X or Y).
Fri May 15, 2020 1:07 pm
hannt offline
Is there a way to put a (rudimentary progress) message to the right of a button?
Edit: I tried the <Description> tag as documented for checkbox, but it was ignored. No error, just nothing.
Sat May 16, 2020 4:12 pm
Not currently. For dynamic progress the best you can do is show/hide static text controls (using visibleBindingId / visibleBindingValue). One big limitation (which I've run into but haven't improved yet) is you cannot change what the text is, so you must have multiple controls for every possible progress message you want then hide/show them appropriately.
