store json in self.pluginPrefs.. vs file
Tue Apr 28, 2020 2:05 pm
I was looking at my plugin prefs files and noticed that one of the files was 10Mbyte
the culprit was a json.dumps entry.
when writing that dict to a file w
f.write(json.dumps(theDict))
instead of
self.pluginPrefs["theDict"] = json.dumps(theDict)
to the indigo plugin prefs file
the file size of the plugin.prefs file went from ~ 10Mbyte to ~30Kbyte and the jsondumps file was just 22 K
It seems that self.pluginPrefs for longer dicts creates really large files ie " --> "
That would explain a factor of 6 but not 200.. ==10,000,000/(30+20)
Tue Apr 28, 2020 3:09 pm
Re: store json in self.pluginPrefs.. vs file
That is strange. Did you look at the plugin prefs XML file to see how it was being stored? json.dumps() just returns a string so I wouldn't expect such a magnitude of change between the two files.
Tue Apr 28, 2020 5:03 pm
actually the comparison was not fair.
The file written had been initialized == many sub dicts empty.
After redoing it properly the delta was still a factor of ~two: 9.8MB --> 5.6 Mbyte
still not small.
Tue Apr 28, 2020 5:12 pm
Is it being stored in the XML as a single string node? Or is it being stored as a dict?
Tue Apr 28, 2020 6:01 pm
I suspect that the XML storage is requiring a lot of escaping of string delimiters, etc, which is causing the expansion.
Here's an example from one of my plugins:
<aggregators type="string">{&quot;1999390458:shellies/shellyht-F36DC6&quot;: {&quot;brokerID&quot;: &quot;1999390458&quot;, &quot;topic_base&quot;: &quot;shellies/shellyht-F36DC6&quot;, &quot;payload&quot;: {}}, &quot;1867973662:foobar/status&quot;: {&quot;brokerID&quot;: &quot;1867973662&quot;, &quot;topic_base&quot;: &quot;foobar/status&quot;, &quot;payload&quot;: {}}}</aggregators>
Tue Apr 28, 2020 6:19 pm
saving to prefs:
theDict= {"_background_blocking_": {"lastCPUsub": {}, "evID": 0, "cpuThreshold": 99999999999, "plugData": {"plugName": "_backgr ....
and yes a lot of &quot; in the prefs file
And BBEDIT takes 5 minutes to "unspin" when opening the prefs file. I guess it tries to understand the xml fields
And once it is not busy it is impossible to use as every time I move the cursor it takes >5 secs to actually move
No problems w the json file.
I guess the prefs file is not the place to save larger dicts
